[Solved] Excel: How to Copy Filtered Cells without Hidden Rows - Enabling and Using Column Filters
karolczyzycki 18853 2
  • #1 7931229
    karolczyzycki
    Rate: 43
    This may be a silly question, but it's a big mystery to me.
    If in Excel I enable the filter on some column, will it hide the rows.
    It copies all cells with a filtered value, sometimes only the filtered values are copied, and sometimes all, even the hidden ones.
    E.g:
    If I copy the cells highlighted in black, sometimes hidden rows 50 and 51 will also be pasted when pasting
    What it depends on? whether it is copying or cutting out cells or whole rows?
  • #2 7931451
    phoszek
    Help: 22
    Maybe CTRL + select cells, try it
  • #3 7931490
    karolczyzycki
    Rate: 43
    I already have a solution:
    select the cells, Ctrl+G -> special -> visible cells only: and then either copy or delete etc.
