[Solved] Ferguson Ariva 203 NC+ No Reception Issue: Uncoded Channels, CAMELEON Card, Software Update
chertan 5964 5
  • #1 17414427
    chertan
    Rate: 39
    The following problem occurred:
    I chose only uncoded channels so I sent a permission update from ICA but it did nothing.
    After talking to BOK nc +, it turned out that they unify the coding system and only the list of tuners that they posted on the site is 100% compatible.
    I use the CAMELEON card, old from the number +.
    I read that you need to upgrade the software (I uploaded A203_20180510_V1.33B5) and let go of the permissions again but somehow nothing happens.
    Does this mean that Ariva 203 will no longer work? In sales offers it is offered as supporting nc +.
    Maybe someone met with something similar and knows the solution.
  • #2 17414512
    _kli_
    Help: 757
    Rate: 1033
    It is likely that your Cameleon got the FEDC instruction that prevents you from working with an independent decoder. You have at least two options:
    - purchase of a converter that will enable Ariva to work with Cameleon ( temporary solution )
    - use of a dedicated decoder by the operator
    Here you have a lot about it.
  • #3 17414586
  • #4 17414660
    chertan
    Rate: 39
    Can I replace the decoder during the contract and extend it to multiroom?
    With nc I have Segemcom DCI83, which I got in 2014.
    What do you recommend to make HD quality work?
  • #5 17414870
    _kli_
    Help: 757
    Rate: 1033
    It should not be a problem.
    Run it, update the software and you'll have a cameleon pickup.
  • #6 17415067
    chertan
    Rate: 39
    so it remains to go to the living room.
