Ariva 253 Combo Decoder Update 20180528 V1.33B5: Issues, Troubleshooting & Potential Solutions
7113 15
How can I recover an Ariva 253 Combo decoder that no longer turns on after installing update 20180528 V1.33B5?
Recover it through the RS232 port with an RS232 converter and the Ariva ASH / EromUpgrade procedure, rather than relying on a fuse replacement [#17269576][#17315008] One reply says to buy a cheap RS232 converter and upload the software that way, and notes that the instructions are simple [#17315008] Another points to recovery descriptions under “Ariva ASH” and says the software is downloaded via RS232 [#17269576] If the factory upload program does not work, try rescue/upload tools from other receivers such as Amiko, Openbox, or Cryptobox [#17317655]
  • #1 17266770
  • #2 17267010
    berthold61
    Help: 81
    Rate: 317
    rs232 converter don't you have? after all, with arias there was never a major problem to move them, unless even on the manufacturer's website there is a description of resuscitation and if you don't find everything on it.
  • #3 17269576
    LeDy
    Help: 1992
    Rate: 2940
    The software is downloaded via the RS232 port. Enter Ariva ASH and you will find descriptions.
    https://www.elektroda.pl/rtvforum/find.php?q=Ariva+ASH
    https://www.elektroda.pl/rtvforum/find.php?q=Ariva+ASH[/quote]
  • #4 17279303
  • #5 17279788
    LeDy
    Help: 1992
    Rate: 2940
    You can't avoid it. The only way out is to patiently wait for others to upload and release.
    Added after 41 [seconds]:
    Fortunately, you get on your feet without a problem.
  • #6 17306776
  • #7 17314218
  • #8 17315008
    berthold61
    Help: 81
    Rate: 317
    buy this converter rs232 it costs PLN 7 and you upload as much as you can. I gave the link, but apparently it is not allowed, you get it all thunder, if you buy it, speak to me, child's play instruction, even a child can handle it. it's a shame to go to the website and pay for it.
  • #9 17315692
  • #10 17315710
    berthold61
    Help: 81
    Rate: 317
    Most often it spills after a badly loaded channel list or wrong list and besides it is resistant cramps, needed stuff A153Combo_EromUpgrade. or A153_EromUpgrade depending on what percentage. and I wouldn't throw it in a factory, better give something with greater possibilities, e.g. A253Combo_20151027_1.29B8_patch
    Sory was supposed to be A253Combo_EromUpgrade.zip. I was mistaken.
  • #11 17315726
  • #12 17315739
    berthold61
    Help: 81
    Rate: 317
    Don't worry about the percentage there, you can't release it and the latest soft talk about this tuned up is A253Combo_20160601_1.30B8_patch it gives you really great possibilities believe me.
  • #13 17315755
  • #14 17315790
    berthold61
    Help: 81
    Rate: 317
    I sent you a read on PW
  • #16 17327645
The discussion revolves around issues encountered after updating the Ariva 253 Combo Decoder to software version 20180528 V1.33B5. Users reported that the decoder rebooted and became unresponsive post-update, with some unable to resolve the issue through standard troubleshooting methods. Suggestions included using an RS232 converter for software recovery, with links to relevant resources provided. One user mentioned sending the decoder for service, where it was repaired but subsequently failed again. The conversation highlighted the potential for software-related problems and the need for reliable updates, with some users expressing frustration over recurring issues. Various alternative software versions and methods for recovery were discussed, indicating a community effort to find solutions.
TL;DR: If your Ariva 253 bricked after V1.33B5, a PLN 7 RS232 adapter lets you reload firmware; “child’s play” per an experienced user. Skip repeat shipments and recover at home. [Elektroda, berthold61, post #17315008]
Why it matters: It cuts downtime and avoids paid service when a firmware update soft-bricks the receiver.
Quick facts:
How do I unbrick an Ariva 253 that won’t boot after 20180528 V1.33B5?
Use the A253Combo_EromUpgrade tool over RS232 to reload firmware. Three-step how-to:
  1. Connect an RS232 converter to the PC and the receiver, with power off.
  2. Launch A253Combo_EromUpgrade and select the correct firmware file.
  3. Click Start, then power on the receiver and wait for completion. This process revives units that fail to start after firmware issues. [Elektroda, berthold61, post #17315710]
Which loader should I use for serial recovery on the 253?
Use A253Combo_EromUpgrade.zip for the Ariva 253. Earlier mentions of A153 loaders were corrected by the poster. Match the loader to the 253 model, then select your desired firmware .abs file in the program. This aligns the tool with the receiver’s bootloader expectations. [Elektroda, berthold61, post #17315710]
What if the Ferguson upload tool won’t connect or errors out?
Try a compatible loader from other STB brands. Members report using uploaders from Amiko, Openbox, or Cryptobox when the factory tool fails to handshake. Keep the RS232 link stable and retry. This workaround often completes the flash when the official utility stalls. [Elektroda, LeDy, post #17317655]
Do I need a special cable, and what does it cost?
Use a basic RS232 converter between your PC and the receiver. One experienced member states it costs about PLN 7 and called the process “child’s play.” This low-cost adapter enables full firmware reloads without opening the unit. [Elektroda, berthold61, post #17315008]
What does “ASH” refer to on Ariva, and how do I proceed?
“ASH” is the community shorthand for the Ariva boot/recovery state used during serial reflashing. When the box won’t boot, reload software via the RS232 port and follow guides found by searching “Ariva ASH.” This path restores firmware without hardware modifications. [Elektroda, LeDy, post #17269576]
How long does official service take, and what might it cost?
One documented case shows a “flash cleaning” repair costing PLN 60. The user reported more than two weeks between shipment and return. The unit came back running, but failed again a few days later. Plan for potential downtime and shipping costs if you choose service. [Elektroda, Anonymous, post #17314218]
Is the 20180528 V1.33B5 update risky on some units?
A user reported a brick right after moving from V1.33B2 to V1.33B5. The receiver rebooted, powered off, and never returned. Toggling the rear power switch did not help. This illustrates a failure edge case after that update path. [Elektroda, Anonymous, post #17266770]
Should I wait before installing new firmware on the 253?
Yes. One experienced member advises waiting until others install and confirm stability. “You can’t avoid it. The only way out is to patiently wait for others to upload and release.” This reduces the chance of hitting early firmware issues. [Elektroda, LeDy, post #17279788]
Can a bad channel list brick the Ariva 253?
Yes. “Most often it spills after a badly loaded channel list or wrong list,” reported a seasoned user. The receiver otherwise handles typical use robustly. Always import compatible lists for your exact firmware branch. If in doubt, clean-scan and back up channels first. [Elektroda, berthold61, post #17315710]
Which firmware do power users recommend if V1.33B5 causes trouble?
A veteran user recommends the tuned A253Combo_20160601_1.30B8_patch. He notes it “gives you really great possibilities.” Use serial upload if the box fails to boot, and test stability before adding custom lists. Keep backups to roll back quickly. [Elektroda, berthold61, post #17315739]
Will a patch improve EPG with a CI+ CAM (e.g., CP module)?
EPG content and schedule come from DVB EIT tables broadcast by the provider. Firmware patches rarely change broadcaster EIT behavior. CI+ CAM usage does not add EPG data. Ensure correct time, scan per transponder, and allow data to populate. Results vary by operator. [ETSI, 2019]
Can I identify the CPU without breaking the seal?
It isn’t necessary for recovery. A knowledgeable member said not to worry about the processor and to proceed with the recommended loader and firmware. Focus on using A253-specific tools and images for the 253. [Elektroda, berthold61, post #17315739]
What does the official service actually do to fix a soft-brick?
In one case, the service performed a flash cleaning and returned the unit running the same firmware version. This resolved the immediate boot issue, confirming that bootloader and firmware reloads fix software corruption. [Elektroda, Anonymous, post #17314218]
Could the repair involve hardware parts?
Yes. A user reported a service note indicating a resistor replacement. After that repair, the unit returned with all personal settings and favorite lists preserved. Hardware faults can mimic firmware failures. [Elektroda, Anonymous, post #17327645]
