Differences in Termet Ecocondens Silver, Gold Plus and Crystal condensing boiler
cynamonik 32544 20
What are the practical differences between Termet EcoCondens Silver, Gold Plus, and Crystal boilers?
Gold Plus is the most feature-rich and expensive version, Silver is the simpler and cheaper one optimized for faster domestic hot water, and Crystal is the older model with fewer options and was intended more for cascade systems [#17436299] Gold Plus is described as having more service parameters for the installation, including minimum/maximum pump speed, burner ramp-up, heating hysteresis, weather-curve shift, ECO function, anti-cycling time (1–60 min), and DHW pump overrun (20–180 s), plus compatibility with Easy Remote, CR11011 OpenTherm, and 0–10V control [#17436299] Silver is said to prepare hot water faster and more efficiently, have a more durable exchanger, use an Italian Nordgas controller, and lack official software repair/update support; it is also the cheapest of the three [#17436299] Gold Plus has lower DHW power (19 kW vs Silver’s 24 kW), which was presented as a reason for slightly lower gas use and better fit for low hot-water demand [#17436299] However, one owner reported that several Gold Plus features are not as good in practice as advertised: internet control is underdeveloped, TankTimer does not work, weather-curve control is blocked with Round WiFi OT, and full OpenTherm control works only with the CR11011 controller [#17505131][#17521965]
  • #1 17420010
    cynamonik
    Rate: 143
    I plan to buy a boiler, I collected the difference in individual models:
    GOLD
    + slightly lower nominal gas consumption because the power for domestic hot water 19 kW (Silver 24 kW) as found for low hot water demand
    + about 4 cm lower than silver
    + cooperation with the regulator EASY REMOTE and OpenTherm CR11011
    + Connection of a regulator with a 0-10V signal
    + control board of the Polish company Tester (constantly updated and treated as development with the possibility of updating to gain access to adjusting new parameters!)
    + b.works well with trays
    + several different service parameters in the control system related to the possibility of adjusting the boiler to a given installation (setting the minimum and maximum pump revolutions, the rate of burner power increase in the initial heating phase, which affects the
    economics and stability of the installation, the ability to set the hysteresis of temperatures in the central heating system, the parallel shift of heating curves for the weather forecast, self-setting the difference between the supply and return from the installation - the ECO function (this is not in Crystal) and several other parameters (according to Arek Komar from Termet ) the driver is not specified :(
    + Anti cycling time, adjustable 1-60 min
    + DHW pump overrun time (adjustment 20-180 sec)
    + in a few months it will be possible to control via the Internet and a smartphone using a new adapter, everything is already in Termet, it is only being tested :)
    - the most expensive of the compared (differences are eliminated by funding available in many communes!)
    SILVER
    + prepares hot water faster and more efficiently, designed in particular for instantaneous hot water heating
    + has a more durable exchanger, but I don't remember which one
    + is the cheapest
    - higher nominal gas consumption because the power for domestic hot water 24 kW
    - Italian Nordgas driver, no official possibility to repair and update the software with new functions
    CRYSTAL
    - older model (not development)
    - intended more for cascade assembly
    Feel free to post your comments, especially your experiences.
  • #2 17432846
    Nix
    Help: 17
    Rate: 189
    Hello!
    I'm considering a condensing boiler as well
    Termeta, because it is a domestic manufacturer, easy access to spare parts and relatively cheap parts...
    Is there no access to the above-mentioned various service parameters in Silver as in gold?
    At the moment I am leaning towards Silver 2F 25KW, these are on sale in a well-known network
    Ca-sto-xxxx together with the room controller, but as someone wrote, there is a regulation limiting the power of the boiler for central heating with coaxial cables exposed through the outer wall to 21KW, and this one has 25KW.
    kisses Nix
  • #3 17432971
    ls_77
    Help: 500
    Rate: 947
    Up to 21 kW power from TERMET are:
    Crystal II 20
    GoldPlus 20
  • #4 17433062
    Nix
    Help: 17
    Rate: 189
    Okay, why not Silver?
    Termet EcoCondens Silver 20 single-function condensing boiler
    -code WKJ4401000000
    or
    Termet EcoCondens Silver 20 combi condensing boiler
    - code WKD4391000000
    Aren't they 20kW?
    kisses Nix
  • #5 17433079
    ls_77
    Help: 500
    Rate: 947
    In the technical data on the manufacturer's website you have the following parameter:
    "Heating power (at 50/30°C) 3.0 - 22.0 kW"
    and it already exceeds 21kW
    Here link
  • #6 17433093
    Nix
    Help: 17
    Rate: 189
    Yes, however
    Heat output (at 80/60°C) = 20KW.
    And does the regulation specify for what conditions it should be < 21KW?
  • #7 17433196
    ls_77
    Help: 500
    Rate: 947
    There is nothing in the "regulation" about temperatures - you need to see exactly what is on the rating plate and there can be 22kW.
  • #8 17433219
    wnoto
    Help: 58
    Rate: 744
    And what are the risks of installing a larger boiler with a chimney through the wall? e.g. 22kW
  • #9 17433225
    ls_77
    Help: 500
    Rate: 947
    I don't know - maybe you should ask in some building inspection
  • #10 17433237
    Nix
    Help: 17
    Rate: 189
    I've been to a few wholesalers, but now the "nameplate" is a piece of foil
    sticked on the inside of the boiler... It is impossible to see anything, or almost nothing, without removing the boiler casing... another flower...
    In one of the shops I found a table where the heating power of 20KW for the boiler is specified:
    EcoCondens Silver 20 single-function condensing boiler code WKJ4401000000
    It's just that I don't know where this table comes from...
  • #11 17436299
    cynamonik
    Rate: 143
    nix,
    Junkers' engineers also decided to put a sticker with basic information under the cover, additionally covered with tubes - for me it's just thoughtlessness!!! Because how to provide the designation / model, e.g. to a service technician ???
    Coming back to the topic, I decided on the Gold version. Both 20 kW and 25 kW start modulating from the same values. Besides, thanks to the co-financing from the commune, the silver/gold price difference will remain around PLN 200-300. I am attaching two interesting leaflets on the differences:
    Differences in Termet Ecocondens Silver, Gold Plus and Crystal condensing boiler Differences in Termet Ecocondens Silver, Gold Plus and Crystal condensing boiler
    Side thread, we don't write about it HERE! Moderators please move to the appropriate section.
    The worst thing is that it's currently hard with appointments with fitters in the western area of Warsaw. If the manufacturer had placed all the necessary information in one place, and the Termet hotline had more competent employees, I could have made the decision 1-2 months ago.
    Maybe someone will recommend a fitter / service in a private message so as not to lose the transparency of the topic. I would prefer it to be ONE person who will install and set up the stove (I know there are such people :) ) There is an opportunity to prove yourself, because knowing life in a few years when there is a problem, I will write about it here and after a while there will be pointing out mistakes: "and who installed / connected like this " :)
    So I invite these sages in the first place. Currently, there is a gas stove, all you need to do is modify the connections and insert the insert into the chimney.
  • #12 17436716
    Nix
    Help: 17
    Rate: 189
    In fact, I have not seen Termet before - but yesterday on the Castora_xxxx network - I watched Silver 2F - this one has a sticker on the side, but the outer wall - so here you can read the parameters without any problems.
    Interestingly, in addition to the classic nameplate, there is also a second one with the description:
    "Co power set = 24KW"
    "DHW power set = 24KW"
    I have given the powers as examples, it is a pity that I did not take a photo of this sticker.
    What made you choose Gold?
  • #13 17505131
    zygmunt22
    GOLD
    - the most expensive of the compared (the differences are not compensated by the funding available in many communes!)
    SILVER
    + is the cheapest
    - Italian Nortgas driver, no official repair and software update with new functions
    CRYSTAL
    you presented the advantages of Gold Plus too rosy (I have this type), which look good on paper, but the practice, at least for me, has shown that the new control via the Internet is underdeveloped and works poorly with the boiler. Currently, the board is in Termet (over 1 month) and problems with obtaining all parameters.
    Despite the descriptions in the instructions that the boiler has a Tank-Timer, it is not true and a scam. This feature does not work. Weather theses.
    In the latest models, they even withdrew from it, but not in Gold (advertisement more important than the customer). It is but it doesn't work.
    Gold does not work with Easy Remote only Round on-off and opentherm (half), cr 11011 (not all functions), all room 0-1.
  • #14 17517132
    Nix
    Help: 17
    Rate: 189
    And what's with this weather forecast, why doesn't it work? Did you pursue the topic?
  • #15 17521965
    zygmunt22
    I know the problem perfectly, but only for Ecocondens Gold Plus produced after November 1, 2017 with control number b.11 and operation in the Opentherm option.
    The control can be carried out by simple on-off programmers including Round wifi on-off or by a digital signal of the OT protocol. Also the 0-10V signal works fine.
    And here is the problem because the software version b.11 works correctly using the heating curves using the above-mentioned 0-1 programmers, but in the case of the opentherm signal with Round wi-fi OP it is programmed in such a way that the OT gate blocks information about the WG temperature from the heating curves.
    Practically, the gate is superior and so that there are no two regulators for one object, the control using heating curves is blocked and the gate modulates the signal using only one value of the set temperature of the WG.
    Therefore, the heating curves symbol is not visible on the boiler display.
    Full OT control is provided only by the universal controller CR 11011 but not by Round wi-fi OT.
    This will be changed in software version B.12, which will appear in new boilers in about a month. There, Round will be able to use the temperature resulting from KG and modulate the signal for the boiler on this basis.
    TankTimer in the new generation boiler will probably not be installed.
    If someone has an older control, it is possible to reprogram it to the latest one in the Tester via the Termet service.
  • Questioning the source and timing of b.12 firmware update
    #16 17543760
    Kropek3
    Rate: 19
    zygmunt22 wrote:
    I know the problem perfectly well but only for Ecocondens Gold Plus produced after November 1, 2017 with control number b.11 and operation in the Opentherm option.
    In practice, the gate is superior and so that there are no two regulators for one object, the control using heating curves is blocked and the gate modulates the signal using only one value of the set WG temperature.
    I would like to ask where did you get the information about the upcoming version of the b12 firmware? Will it be out in a month or so in December?
  • #17 17545587
    zygmunt22
    I had a long conversation directly with the IT specialist who is preparing the program. There will also be a period of testing by Termet
  • #18 17591408
    Rob
    Level 19  
    Help: 25
    Rate: 33
    I'll stick to the topic of differences in boilers:
    EcoCondens Silver vs TermGas Condens
    That is, I was recommended to buy an EcoCondens Silver boiler. So I started looking for information about him, I found his symbol in the company's price list: WKD4351
    Then I started looking for the best deal with these boilers and found it in a DIY store. Exactly the same symbol but named TermGas Condens.
    Differences in Termet Ecocondens Silver, Gold Plus and Crystal condensing boiler Differences in Termet Ecocondens Silver, Gold Plus and Crystal condensing boiler Differences in Termet Ecocondens Silver, Gold Plus and Crystal condensing boiler
    Same symbols and different names. I tried to call Termet but to no avail. So I decided to ask the question here.
    Are these EcoCondens Silver and TermGas Condens boilers the same boilers, only the name is some kind of marketing change?
    Or maybe what goes to DIY stores is some depleted version (or maybe enriched :) )?
    If anyone knows the differences, please explain.
    I would also like to mention that on the Termet website I could not find anything about TermGas Condens boilers.
  • #19 17591448
    GETomek
    Help: 7
    Rate: 123
    It's almost the same but almost makes differences .... because the one from the market has a different fan, i.e. a more plastic one to make it cheaper, and the gas valve has a different one, because the stove in the supermarket must be cheaper.
  • #20 17596698
    Rob
    Level 19  
    Help: 25
    Rate: 33
    They are probably some kind of crap that, if necessary, can be replaced with better ones.
    I mean more important things, such as a heat exchanger or, for example, a pump, controller, its software, etc.
  • #21 17637355
    Rob
    Level 19  
    Help: 25
    Rate: 33
    For those interested, I put a common installation instruction for stoves:
    Silver, Termgas and Termmax .
    See page 14 for the different gas valves for each model. IS-TERMGAS...ONDENS.pdf (3.96 MB)You must be logged in to download this attachment.
The discussion revolves around the differences between Termet's Ecocondens Silver, Gold Plus, and Crystal condensing boilers. Key points include the Gold model's lower nominal gas consumption (19 kW for domestic hot water compared to Silver's 24 kW), its compatibility with the EASY REMOTE regulator and OpenTherm CR11011, and its advanced control board features. Users express concerns about the availability of service parameters in the Silver model, with some leaning towards the Silver 2F 25KW due to its availability and pricing. There are also discussions about the power limitations imposed by regulations, with mentions of the EcoCondens Silver and TermGas Condens potentially being the same boiler under different names, albeit with some differences in components. Users report mixed experiences with the Gold Plus model, particularly regarding its internet control features and reliability.
TL;DR: "Heating power (at 50/30°C) 3.0–22.0 kW" defines Silver’s range; use it to size and check 21 kW limits. This FAQ summarizes model differences and controller gotchas so you can pick confidently. [Elektroda, ls_77, post #17433079]
Why it matters: It helps homeowners and installers choose among Silver, Gold Plus, and Crystal while avoiding 21 kW venting and OpenTherm pitfalls.
What are the practical differences between Termet EcoCondens Silver and Gold Plus?
Silver focuses on fast instantaneous DHW and lower cost. Gold Plus focuses on control. It uses a Polish Tester board with updates. You get OpenTherm CR11011 and 0–10 V support. Extra service parameters include hysteresis, weather‑curve shift, and ECO ΔT. Anti‑cycling is 1–60 minutes. DHW pump overrun is 20–180 seconds. Gold Plus DHW power is 19 kW; Silver’s is 24 kW. Gold is also about 4 cm shorter. [Elektroda, cynamonik, post #17420010]
Does Silver offer the same service parameters as Gold Plus?
Silver offers fewer service parameters. Gold Plus exposes many additional tunables for pumps, burner ramp, hysteresis, weather curves, and ECO ΔT. Silver uses an Italian Nordgas controller without official software updates, limiting expansion. If you need deep tuning, choose Gold Plus. [Elektroda, cynamonik, post #17420010]
Can I use a wall‑through coaxial flue if my boiler label shows over 21 kW?
Regulations do not reference flow temperatures. Check the rating plate. If the rating plate lists 22 kW, treat it as 22 kW for flue eligibility. Another table showing 20 kW does not change that. [Elektroda, ls_77, post #17433196]
Are EcoCondens Silver 20 boilers really 20 kW?
The manufacturer’s data lists Silver 20 heating power as 3.0–22.0 kW at 50/30°C. That exceeds the 21 kW wall‑flue threshold. Always size and assess compliance from the technical data and the unit’s rating plate, not only the product name. [Elektroda, ls_77, post #17433079]
Which Termet models are within the 21 kW wall‑terminal range?
Forum checks identified Crystal II 20 and GoldPlus 20 as the 21 kW options from Termet. Verify your specific unit’s nameplate before ordering vent kits. [Elektroda, ls_77, post #17432971]
Why did some buyers pick Gold Plus instead of Silver?
One buyer chose Gold for its richer controls and minimal net price difference after local co‑financing (about PLN 200–300). Both 20 kW and 25 kW Gold variants start modulating from the same values. Choose mainly by DHW needs. Availability of competent setup was also a factor. [Elektroda, cynamonik, post #17436299]
Does Gold Plus support Internet/smartphone control reliably today?
One owner reported the new Internet control as underdeveloped and "works poorly with the boiler." Their control board stayed at Termet for over a month while resolving parameters. If you need remote control now, confirm firmware and gateway support before buying. [Elektroda, zygmunt22, post #17505131]
Why dont heating curves show when using Honeywell Round Wi‑Fi OpenTherm?
On Gold Plus with firmware b.11, the OT gateway blocks heating curve information with Round Wi‑Fi OT. The boiler then modulates only to a single set flow temperature, so the heating curve symbol disappears. "Full OT control is provided only by the universal controller CR 11011" in that scenario. [Elektroda, zygmunt22, post #17521965]
Will firmware b.12 fix the OpenTherm curve behavior, and who confirmed it?
A contributor spoke directly with the programmer. "There will also be a period of testing by Termet." Confirm b.12 timing and features with Termet, because releases can shift. [Elektroda, zygmunt22, post #17545587]
Is TankTimer available on Gold Plus?
TankTimer is absent in the new generation. One expert note says it "will probably not be installed" going forward on Gold Plus. Plan DHW comfort via other controller functions or external timers. [Elektroda, zygmunt22, post #17521965]
What room controllers work best with Gold Plus?
Simple on‑off programmers, including Round Wi‑Fi on‑off, work. Digital OpenTherm works, but use CR 11011 for full OT features on b.11. "Also the 0–10V signal works fine." Match your controller to the firmware to avoid blocked heating curves. [Elektroda, zygmunt22, post #17521965]
How do I check my units rated power for venting compliance?
Do this before flue selection.
  1. Locate the rating sticker on the outer side panel (as seen on Silver 2F).
  2. Find the extra label listing "CO power set" and "DHW power set."
  3. Use those declared values when assessing 21 kW limits. [Elektroda, Nix, post #17436716]
Are EcoCondens Silver and TermGas Condens actually the same boiler?
Retailers sell TermGas Condens under a store label. The shared installation manual covers Silver, TermGas, and TermMax. It shows different gas valves per model on page 14, so components can vary. Compare part lists and labels before mixing spare parts. [Elektroda, Rob, post #17637355]
What anti‑cycling and DHW pump overrun settings does Gold Plus offer?
Gold Plus allows anti‑cycling time from 1 to 60 minutes. It also offers DHW pump overrun from 20 to 180 seconds. These help stabilize starts and hot‑water comfort when matched to your installation. [Elektroda, cynamonik, post #17420010]
Do both Gold 20 kW and 25 kW share the same minimum modulation?
Yes. A buyer confirmed both Gold Plus 20 and 25 start modulating from the same values. Select between them mainly by domestic hot water expectations, not central heating minimums. [Elektroda, cynamonik, post #17436299]
Who can confirm if a 22 kW wall‑flue install is allowed?
Consult your local building inspection office before purchase. Ask them whether a 22 kW unit with a wall flue is acceptable for your case. [Elektroda, ls_77, post #17433225]
