Evaporative Evaporation System (EVAP) - valve control circuit
akorvek 13167 3
  • #1 17437845
    akorvek
    Hello, is anyone able to advise, namely the check engine light is still on. I connected the car to the computer and an error appeared, as in the topic of the fuel vapor removal system (EVAP) - valve control circuit. Literally everything was checked, filters, oils, the condition of the cables, two lambda probes were replaced and the error is still present and it is impossible to even remove it, it also jerks the engine at idle speed and more burns. There are no symptoms such as hissing from the tank or undulating revolutions when idling. Somewhere I read that this evap valve is a solenoid valve that I also checked and it is fine. The mechanics spread their hands and don't know what's up. Do you have any suggestions on what might be causing this? The car model is peugeot 307sw 1.6 hdi gasoline 2003.
    • Evaporative Evaporation System (EVAP) - valve control circuit received_345169809560366.jpeg (41.15 KB) You must be logged in to download this attachment.
    • Evaporative Evaporation System (EVAP) - valve control circuit 20180830_145318.jpg (1006.13 KB) You must be logged in to download this attachment.
    • Evaporative Evaporation System (EVAP) - valve control circuit 20180830_145309.jpg (1.34 MB) You must be logged in to download this attachment.
  • #2 17437884
    ociz
    Help: 1379
    Rate: 3486
    Mechanics aren't free fairies. You go to the workshop only to ask "what can it be", it is obvious that they will put you off. Have it repaired, you will have it fixed.
    akorvek wrote:
    hdi
    At the gas station, although you know which ones to pour?
  • #3 17438353
    mario 77
    Help: 66
    Rate: 335
    What kind of advice do you need?
    akorvek wrote:
    Literally all filters, oils, cable condition were checked, two lambda sensors were replaced and the error is still present
    Keep listing that. Maybe next in line should be e.g. a bearing in a wheel ...
    Approx. Two wires go to the valve. On one side there is a power supply (12V) and on the other the weight is supplied from the engine controller. So you check what is missing if the valve is already checked. You can also test EVAP with a diagnostic device.
  • #4 17438536
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Is it diesel (hdi) or gasoline?
    akorvek wrote:
    two lambda sensors replaced
    Diesel does not have Lambda probes.
    Connect to DiagBox (Peugeot Planet 2000) and check EVAP valve control and position status.
