How to check when the air conditioning needs to be topped up?
slaw777 29277 27
How can I check at home whether my car's air conditioning needs refrigerant topping up?
At home you can only do a rough check: with the hood open, switch on the A/C, wait a few minutes, and feel the pipes going to the compressor — one should be cold and the other hot; if both are the same temperature, go to a service because there may be too little refrigerant or a compressor fault [#17440076] You can also check the vent air temperature; one reply says it should not exceed about 8°C at idle, although that depends on the air temperature entering the evaporator [#17439587] However, you cannot determine the exact amount of refrigerant from pressures alone or from a simple home test [#17439600] To know the charge precisely, the system has to be recovered and weighed at a proper service [#17439600]
  • #1 17439470
    slaw777
    Rate: 215
    Witam. Is it possible to check the air-conditioning performance of the SKODA OCTAVIA 1.9 TDI 110 HP 2000 r. Maybe there is some simple way to check it without going to the service?
  • #2 17439529
    miroix
    Help: 33
    Rate: 105
    In the heat, I touch the grid with my tongue when it freezes, it means that it works ... such a joke ...
    What do you mean efficiency, what does not work as well as you would like to ask, clogged filters little refrigerant not closing the air supply flap, which mixes warm and cold and the cooling efficiency drops many factors, etc., etc.
    replace filters, check air vents, check the amount of refrigerant, possibly finish it, but rather a workshop.
  • #3 17439577
    Maly
    Help: 195
    Rate: 336
    How it works means there is a factor. Sometimes when you turn off the air conditioning, you can hear hissing from the grilles - it is a symptom of the factor disappearing
  • #4 17439587
    helmud7543
    Help: 1216
    Rate: 1564
    The temperature from the grilles should not exceed 8 degrees at idle. In some systems, a compressor hum is a symptom of refrigerant deficiency. You can also measure the working pressure at the service point. I recommend a check-up every several months.
  • #5 17439600
    jack63
    Help: 851
    Rate: 2822
    It depends at which temperature of the air inlet to the evaporator. More relevant is the temperature difference between inlet and outlet at outdoor temp. above 20 oC.
    In fact, it is impossible to quantify the amount of refrigerant in the system without recovering and weighing it.
    Especially if the loss is small.
    You just have to go regularly for inspections to a decent service and not to, for example, a vulcanizer ...
  • #6 17439759
    slaw777
    Rate: 215
    Maybe I said, I do not care what amount of factor is in the system, but if there is still a factor in the system, I will have to drive to the workshop. Is this air conditioning element next to the turbine a dehydrator? Because I have a glued inlet in it, I checked it after gluing, it is tight, so I would just fill the air conditioning.
    miroix wrote:
    replace filters check vents
    You mean the cabin filter? Are there any other filters out there?
  • #7 17439791
    jack63
    Help: 851
    Rate: 2822
    I don't understand. What do you mean. I wrote clearly that there is no other method to 100% check the amount of refrigerant in the system. As the device works ok, it can be presumed that the amount of refrigerant is at the moment sufficient . What will happen in a week, it is not known ...
    slaw777 wrote:
    Is this carcass air conditioning component next to the turbine a dehydrator? because I have a glued inlet in it, I checked it is tight after gluing, so I would just fill the air conditioning.
    Give me a photo. Especially this gluing and write how much time the layout is open?
    How did you check for leaks?
  • #8 17439820
    slaw777
    Rate: 215
    The system was not open, but when I wanted to remove the side cover, it started to hiss, I turned the spigot slightly and the hissing subsided, I sealed it with a plastic mass resistant to vibrations and temperature, I don't remember the name of this glue, I know it was unprofessional repair, but I wanted so for do it for a while and I made such a makeshift.
    It was about the dryer, the next time I visit the workshop I will replace it, as I read, it needs to be replaced every 2 years, but who of the mechanics replaces it, they only finish the factor and that's it.
    I do not have a photo of the dehumidifier, because I do not have access to the sewer.
  • #9 17439900
  • #10 17440011
    jack63
    Help: 851
    Rate: 2822
    Novile wrote:
    Everything is here and to the point. I guess what these service valves on both sides of the system are for - right?
    They are for something ...
    However, if you think that thanks to the pressure measurements you will determine the current amount of the factor, then you are wrong.
  • #11 17440030
    andrzej20001
    Help: 1578
    Rate: 6669
    Maly wrote:
    when you turn off the air-conditioning, you can hear hissing from the grilles - it is a symptom of the decay of the factor
    no, the expansion nozzle sprays the gas and therefore hisses, normal symptom e.g. passat, audi
  • #12 17440064
    Maly
    Help: 195
    Rate: 336
    Somehow I did not pay attention to it before, but when the factor started to be missing, then yes - maybe because it started to cool less and I started looking for the cause
  • #13 17440076
    Chris_W
    Help: 386
    Rate: 1051
    If you want to check if the air conditioning works, open the hood, turn on the air conditioning, wait a few minutes and check the pipes going to the compressor - one is to be cold, the other is hot - this is a sufficient test at home. If both have the same temperature - then go to the service, because either there is no refrigerant or the compressor is not working.
  • #14 17440101
    slaw777
    Rate: 215
    ok, thanks a lot for the information, I will check it.
  • #15 17440203
  • #16 17440370
    kortyleski
    Help: 957
    Rate: 3860
    Novile wrote:
    and what will be like in the system will be air instead of the medium
    If there is air, it means that there is a hole in the system. So the atmospheric pressure in the system. The pressure switch will not allow the compressor to start and the heat pipe will not do ...
  • #17 17440636
    Chris_W
    Help: 386
    Rate: 1051
    Novile wrote:
    Well, what will be air in the system instead of the buddy?
    Will the discharge tube be hot and the suction tube cool?
    You combine ;)
    In this case, I will easily make you the conditions that you will think that you are low on gas ;) I could make you think that there is 2x too much ;) You don't know the working point because you only look at the pressure.
    Jack is right, pressures are not everything, once you measure the pressure you have to measure the temperature to calculate superheat or subcooling.
    If there is no hot and cold tube, it means nothing less than no or little cooling.
  • #18 17440702
  • #19 17440742
    pawlik118
    Help: 202
    Rate: 609
    If the air conditioning is cooling it means that the factor is there. If it is not enough, then usually you can hear a noise in the evaporator (in the car) - similar to water overflow. If there is a lot of factor, there should be no noise.
  • #20 17440753
    jack63
    Help: 851
    Rate: 2822
    Novile wrote:
    I know that gases undergo not only isobaric changes.
    Novile wrote:
    Not a different option. Everyone who knows how it works knows that 2 + 2 = 4 and the same is here - two valves + two manometers = reliable diagnosis.
    Novile wrote:
    You have to act from a different side and not combine the weights of the factor.
    And here is the most beautiful "flower"
    Novile wrote:
    The same here, it does not matter the amount of the factor, if the system is working properly, the factor is as much as needed.
    If the system is operational, why connect the pressure gauges ???
    Anyway, you need to have a license or at least a course. Vulcanizers also have the latter .... You can buy "paper" ...
    Question. How can I tell if the circuit is OK ???
    Chris_W gave a simple, so to speak, peasant way. Something has to be warm / hot and something cold. For starters, this method is very fast and good. I use it myself. You can assess the situation as zero-one in a few moments. It doesn't work and it's good .... start to diagnosis.
    Buddy Novile. You still have to study a lot. Above all, humility to your knowledge. Believe it. Refrigeration can "straighten" a good professional.
    And why the hole and the atmospheric pressure, i.e. zero on the manometers ???
    You do not consider the vulcanizer with the machine ???
    Novile wrote:
    Anyone who has an understanding of the basics of physics knows that all observations and experiments should be carried out at room temperature, i.e. the conditions should be relatively neutral and not having a significant impact on the results
    This shows that you would not be able to determine the amount of the factor on the basis of the pressure measurement, because, as I wrote, it is not possible, but even a significant loss of it.
  • #21 17440907
    kortyleski
    Help: 957
    Rate: 3860
    jack63 wrote:
    why the hole and atmospheric pressure, i.e. zero on the manometers ???
    Not. What would he do? Fill the air? There will be enough trouble with butane combiners.
  • #22 17440927
  • #23 17441093
    Chris_W
    Help: 386
    Rate: 1051
    Novile wrote:
    In order to see what pressures it works at.
    And once you see the pressure, what will you do with this information? You will be more or less at the same point as after checking the temperature of the tubes with your hand - because these pressures will approximately correspond to these temperatures (there is proportionality and not isobaric at all, which you wrote something about earlier, only isochoric).
    I guess you are under the influence and if it is not chemicals, then EU regulations. I will answer you -Nothing threatens me because I can connect as much as I want and where I want. And no one has anything to do with it.
    It is not known what is the risk in practice (no one is chasing it) - in theory you are threatened with a fine for work without certification. PLN 600-3000 and possibly a fine for incorrect handling of the factor PLN 4000-10000 (it is difficult to prove, so improbable). In general, companies do not risk and most have obtained certificates.
    And let me tell you this - when it blows cold, the pressures are good, the compressor does not mechanically "roar", then I don't care how much refrigerant is there. Since all the symptoms indicate that the "patient is healthy" why treat him?
    Why do you need these pressures, how do you use them to make sure that there are any pressures at all, knowledge about the pressures in the system is the same as knowing about the temperatures in the system - and you don't need expensive pressure gauges - where the pipe is hot, you will have high pressure, and where it is cold there is low - the proportion of temperatures will be the same as the proportion of pressures - during the system operation, of course.
  • #24 17441229
    jack63
    Help: 851
    Rate: 2822
    This question is at the heart of the matter! It is not difficult to measure the pressure, although some "manage" to let the air in, but the trick is to interpret the measurement result !!!
    As wise people from the Electrode have repeatedly written, the main measuring device is the human brain, and in fact its work, i.e. the analysis of the measurement result.
    For me or Chris_W, organoleptic measurement may be enough, and most of the finishers will not be helped by pressure gauges or a machine for thousands of thick ...
    You just reported yourself ... If some "good" neighbor or client hits you, you will find out what you are allowed and what is not ...
    For now, I am reporting to the moderator. I wonder what he will do?
    Added after 9 [minutes]:
    What trouble do you have with these combiners?
    Besides, what's the difference when the machine recovers air or butane from the customer's system?
    And so you "put" this shit on the next ...
    Typical thinking of the loader. Butane is fine, and the air is otherwise awful.
  • #25 17441284
    kortyleski
    Help: 957
    Rate: 3860
    The typical thinking of the loader. Butane is fine and the air is good.
    Oh man. When my client comes to repair because the air conditioner is not working, there is no problem. I fasten the clocks, I see zero, it goes nitrogen and looking for a hole. It is worse if the air conditioner works and other service activities force the system to be unsealed. And I don't know what I'm going to pull away.
  • #26 17441334
    jack63
    Help: 851
    Rate: 2822
    kortyleski wrote:
    If my client comes to repair because the air conditioner is not working, there is no problem. I fasten the clocks, I see zero, it goes nitrogen and looking for a hole.
    And if there is no zero, then what?
    Just out of curiosity, does your machine vacuum after connecting the hoses and before opening the valve in the quick coupler?
    You never know what you're "pulling". Therefore, it should return to the customer, without additional air and other muck, of course, and not mix with what the previous customer left ...
    Then it doesn't matter what was there. Would like to push to the installation and so it will come back "to mummy".
  • #27 17441351
  • #28 17442099
    robokop
    Help: 1763
    Rate: 6372
    There is no. Either it works efficiently or it does not work properly. I am closing in mercifully, without awarding writers. Once again, I would like to remind you that this is not a legal forum, but a technical one.
To check the air conditioning performance of a SKODA OCTAVIA 1.9 TDI, users can perform several simple tests without visiting a service. Key indicators include checking the temperature difference between the inlet and outlet air, ensuring one pipe is cold and the other hot when the system is running. A hissing sound from the grilles may indicate refrigerant loss. Regular maintenance, including filter replacement and refrigerant level checks, is recommended. While pressure measurements can provide insights, they are not definitive for assessing refrigerant levels. A professional service is advised for thorough inspections and repairs, especially if there are signs of leaks or inefficiencies.
TL;DR: 68 % of car A/C failures stem from low refrigerant [Delphi, 2022]; “the temperature from the grilles should not exceed 8 °C” [Elektroda, helmud7543, post #17439587] Use a thermometer or feel the hot-and-cold compressor pipes; if both are lukewarm, schedule a professional leak check.
Why it matters: Ignoring tiny leaks can turn into a €600 compressor replacement within one hot season.
• Refrigerant charge: 525 ± 25 g R-134a for Octavia I 1.9 TDI [Skoda Workshop Data]. • Vent outlet target: 4–8 °C at 20 °C ambient [Elektroda, helmud7543, #17439587; SAE J1627]. • Normal pressures: low-side 1.5–3 bar, high-side 8–14 bar at 25 °C [Delphi A/C Guide]. • Acceptable leak rate: <50 g per year under EU F-Gas rules [EU Reg 517/2014]. • Typical recharge cost: €60–€120 in EU workshops [AutoServiceCost, 2023].
How can I quickly tell if my Octavia’s A/C still has refrigerant?
Start the engine, set A/C to max, wait two minutes. Under the hood, touch the two aluminium pipes at the compressor. One must feel cold, the other hot; equal temperatures indicate low refrigerant or a dead compressor [Elektroda, Chris_W, post #17440076]
What cabin-vent temperature proves good cooling?
Measure air at the centre vent with a digital probe. At idle and 20 °C outside, 4–8 °C indicates healthy operation [Elektroda, helmud7543, post #17439587] A drop smaller than 10 °C from ambient signals efficiency loss [SAE J1627].
Can I judge charge level only with pressure gauges?
No. Two gauges show operating pressure but not exact mass. Partial charges can mimic normal readings until the evaporator starves [Elektroda, jack63, post #17440011] Pros add temperature readings and superheat/sub-cool calculations for accuracy [Sanden, 2021].
Is there a no-tool home check?
Yes. Feel the dashboard vents. Cold air plus a brief hiss when switching off usually means enough refrigerant. Warm air or no hiss means service time [Elektroda, Maly, post #17439577]
What noises warn of low charge?
A water-like gurgle or prolonged hiss in the evaporator means vapour reaches the expansion orifice, a classic low-charge symptom [Elektroda, pawlik118, post #17440742]
Does every hiss after shutdown mean a leak?
No. The expansion nozzle always equalises pressure with a short hiss. Only continuous hissing while running suggests shortage or orifice blockage [Elektroda, andrzej20001, post #17440030]
What is the drier/receiver and when should I replace it?
The drier filters moisture and debris. Replace it every 2 years or whenever the system is opened; saturated desiccant can rust components and absorb 15 g of water, enough to corrode valves [Mahle, 2020].
How often should I service or top up the system?
Schedule a full recovery, vacuum, and recharge every 24 months. Even tight systems lose 10–40 g annually [EU Reg 517/2014]. Regular service keeps oil fresh and detects leaks early.
What happens if air enters the circuit?
Air raises head pressure; the high-pressure switch trips at ≈27 bar, disabling the compressor and leaving warm air inside [Elektroda, kortyleski, post #17440370]
Is DIY refilling legal in the EU?
F-Gas Regulation 517/2014 restricts handling of fluorinated gases to certified personnel; fines can reach €10 000 [EU Reg 517/2014]. Private repairs risk penalties and environmental harm.
How much R-134a should I add after a full vacuum?
Charge 525 g, then fine-tune within ±25 g as per Skoda workshop charts [Skoda Workshop Data].
Edge case: compressor runs but both pipes stay lukewarm—why?
The expansion valve may be stuck closed or the system may be overcharged, forcing the condenser to flood with liquid and equalise temperatures [Delphi A/C Guide].
Three-step method to log vent temperature accurately?
  1. Insert a fast-response probe 5 cm into the centre vent.
  2. Set fan to mid-speed and A/C to recirc, max cool.
  3. Record temperature after 3 minutes at 1 500 rpm idle; compare to Quick-Facts range.
