Solve Error 0x800ccc0f in Outlook 2007: How to Start in Safe Mode & Fix the Issue
virat8586 3330 3
  • #1 17459844
    virat8586
    Hey friends,
    I have been facing this Error 0x800ccc0f in Outlook 2007 and have read it somewhere that starting Outlook in safe mode may help me out in resolving this issue.
    So if you have any idea regarding this kindly share.
    As tried getting an answer but was unsuccessful.
    Thanks in advance
  • #2 17459893
    peesek
    Help: 26
    Rate: 15
    Dear friend,
    there is a lot informations over Internet how to do this, example:
    https://www.youtube.com/watch?v=6q_X3XmPIDw
    https://www.outlook-tips.net/beginner-user/start-outlook-in-safe-mode/
    You need to use command line. Or you can create shortcut to 'exe' file and then in shortcut details add '/safe' like this:
    then hit OK. But remember, in this way you will always start Outlook in safe mode- until you clear '/safe'.
    Best regards.
  • #3 17460166
    Abrienne
    To start Microsoft Outlook in safe mode follow the steps:
    - Go to Start Menu and click on search
    - Type Outlook exe /safe
    This is the basic step you opt to "Outlook error 0x800ccc0f" by disabling the suspicious add-ons.
    Other solutions to resolve this error:
    1. By checking connectivity
    2. Check Windows firewall
    3. Outlook profile might be wrong.
    Article Courtesy
    Learn more about Safe mode in Outlook: https://it.toolbox.com/blogs/abrienne/how-to-open-outlook-in-a-safe-mode-061518
  • #4 17556871
    William Fred
    Try searching "Outlook Safe Mode". The official Office support will help you in better ways.
