Windows 7 Access Denied Error 0x80070005: Troubleshooting & Fixes (Logs Attached)
Gepetto 7233 2
  • #1 17101480
    Gepetto
    Please check the logs in the attachment.
    • FRST.txt (60.43 KB) You must be logged in to download this attachment.
    • Addition.txt (52.23 KB) You must be logged in to download this attachment.
  • #2 17101897
    iJuliusz
    Help: 29
    Rate: 9
    Welcome.
    When did the error occur? Have you installed Windows updates? Or maybe after installing some program?
    Did you manually delete any directories from your computer?
    It doesn't look like an infection.
    It is a huge mess.
    This can be indicated by references to non-existent files, as if someone or something had physically deleted them from the disk.
    All drivers and services do not have Digital Signatures.
    Try to check consistency first. Run CMD with administrator privileges. Enter
    sfc / scannow
    Let me know if they found bugs
    As for the error 0x80070005, it may be related to the Invalid.
    Try to fix Windows Update with this.
    Utility to troubleshoot Windows Update service
