Choosing the Best Video Recorder: Viofo vs Dod-Tech, for Day, Night & Weather Conditions (90 chars)
madret 7812 14
Which dash cam should I choose for clear recording in sunlight, rain, and dark night roads, with license plates still readable?
For all-weather, day/night recording, the key feature is WDR/HDR rather than IR LEDs, because it handles strong sunlight, headlights, and changing lighting better [#17461211][#17496524] In the Mikavi line, PQ1 uses HDR, while PQ2 and PQ3 add WDR; the reply says the parameters are very similar and the image should be good on any of them, with PQ2/PQ3 having the edge on dynamic range [#17496524] The thread also advises checking real sample videos, preferably uncompressed, and comparing fps plus recording angle, since wider coverage helps capture more detail [#17465084] For Viofo, one user recommends the A119 V3, praising its image quality, detail, stability, and memory-card failure warning [#19891306] So the safest picks from this discussion are Mikavi PQ2/PQ3 or Viofo A119 V3, with WDR/HDR and real footage being the main decision factors [#17496524][#19891306]
  • #1 17460029
    madret
    Rate: 11
    I need help choosing a video recorder. There are tons of topics and opinions about it everywhere, and each opinion is a different proposition. Generally, the recorder is only supposed to record, I don't need any goodies. But the quality of the recording should be very good, no matter if it is sun, rain or an unlit road at night. That in such conditions the recording would be legible and it would be possible to read the numbers from the license plate. After browsing through many entries, I initially take into account such manufacturers (I count on you for specific models), unless you suggest something else:
    - Viofo,
    - Dod-Tech.
  • #2 17460116
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1011
    I don't know what your budget is, but consider the MIO MiVue series.
  • #3 17461211
    arekwij
    Help: 9
    Rate: 24
    If you care about recording in all conditions and with different and changing lighting, the recorder should have WDR mode. It works better than the IR LEDs that illuminate only at night. I would add Mikavi to this list, for example PQ3 https://www.wideore regatory24.pl/kamera-samochodowa-mikavi-pq3-gps-4k, or PQ1.
  • #4 17461776
    Level 37  
    Help: 211
    Rate: 1011
    LED diodes in car cameras are a strange thing.
  • #5 17462375
    madret
    Rate: 11
    When it comes to the budget, I think around PLN 500. The rear camera is unnecessary because I can't see the power being pulled to it.
    And so, first of all, I care about recording in all conditions and with various changing lighting.
  • #6 17465084
    arekwij
    Help: 9
    Rate: 24
    Well that's PQ1. But before buying, watch the videos both on YT and without compression on the websites of producers or video recorders24. Also see beyond WDR what is fps and recording angle. The more such a webcam is able to catch, the better.
  • #7 17471116
    madret
    Rate: 11
    But how I look at it is PQ1
    http://mikavi.pl/produkt/rejestrator-jazdy-pq1-gps-seria-premium-quality/
    there is no WDR, only in the description of PQ3 it says about it
    http://mikavi.pl/produkt/rejestrator-jazdy-pq3-gps-4k-wifi-seria-premium-quality/
    Do I get it wrong?
    And also the PQ2 model
    http://mikavi.pl/produkt/rejestrator-jazdy-pq2-gps-dual-seria-premium-quality/
    What does it look like in terms of parameters, because I do not know anything about it, and I liked this webcam, which additionally records the interior of the car?
  • #8 17477250
    seba694637
    Help: 11
    Rate: 114
    MIO is crap. I have had mio 608 for a year. The quality of the recordings is not worth the price. Two memory card slots where the second is not useful. Twice guaranteed. Breakdown of memory hopeless. I turn off the car, fire up - the time will be deleted and you have to set it up every time. From the news, the battery lasted 10 minutes. After a year, a few seconds
  • #9 17496524
    arekwij
    Help: 9
    Rate: 24
    Do I get it wrong?
    Because in Mikavi PQ1 there is HDR - High Dynamic Range, i.e. a large dynamic range, and WDR is an extended dynamic range. The principle of operation is very similar. If you have strong sunlight or headlights of an approaching car, this effect will be minimized. You can see the differences, for example, here https://www.wideoreawodatory24.pl/kamera-samochodowa-mikavi-pq3-gps-4k. The movies are included without compression. In PQ2 you already have WDR. The parameters are very similar, the equipment is on good components. This is distinguished by dual - interior recording, which of course you can turn off. Generally, each of these devices is quite good. If you compare the specification, a lot of things overlap. But most importantly, the image will be good on any of these cameras.
  • #10 17497194
    madret
    Rate: 11
    Ok thanks for the detailed answer :)
  • #11 17497201
    kacha36
    Help: 48
    Rate: 90
    I can recommend the Viofo WR-1 webcam, I have been using it for several months, it is doing very well.
  • #12 17520404
    induss
    And what did you choose ??
    I recently bought a Viofo A129 in dual
  • #13 17604461
    jacekRCA
    Help: 14
    Rate: 35
    Madret- did you decide on something? If I had to choose, my choice would be mikavi pq3, it has great parameters. Full HD recording, wifi and an additional rear view camera. On yt you can find recordings made with this webcam.
  • #14 19891122
    madret
    Rate: 11
    Years later I was reminded of the subject ;)
    Ultimately, the purchase was the 70mai A800S 4K.
    However, for the second car I am going to buy the Viofo A129 PLUS DUO to have a comparison.
  • #15 19891306
    Level 37  
    Help: 211
    Rate: 1011
    I recommend. I have had the Viofo A119 V3 for almost a year now and I am very satisfied. Good image quality, detail, stability.
    The camera has a very important function: signaling the failure of the memory card.
    For this super-capacitor and I don't need anything else for happiness.
✨ The discussion revolves around selecting a video recorder that performs well in various lighting and weather conditions, specifically focusing on Viofo and Dod-Tech brands. Users emphasize the importance of high-quality recording, particularly for capturing license plate details in challenging environments. Recommendations include the Viofo WR-1 and A129 models, as well as Mikavi PQ1, PQ2, and PQ3, with features like WDR (Wide Dynamic Range) and HDR (High Dynamic Range) being highlighted for improved performance. Users also share personal experiences with different models, noting the significance of factors such as image quality, stability, and memory card reliability.
TL;DR: One owner reports almost 1 year of stable Viofo use, and "The camera has a very important function: signaling the failure of the memory card." For plate clarity day/night, prioritize WDR/HDR and a super‑capacitor over batteries. [Elektroda, Szyszkownik Kilkujadek, post #19891306]
Why it matters: This FAQ helps drivers pick a dash cam for clear, reliable footage in sun, rain, and at night.
Quick facts:
Viofo vs Dod-Tech: which is better for day/night and bad weather?
This thread leans toward Viofo due to real-user endorsements. A Viofo A119 V3 owner praised image quality, detail, and stability. They also highlighted memory-card failure alerts and a super‑capacitor, which boosts reliability. Quote: "The camera has a very important function: signaling the failure of the memory card." If choosing between brands, Viofo models earned specific praise here. [Elektroda, Szyszkownik Kilkujadek, post #19891306]
Do I need WDR or HDR on a dash cam? What’s the difference?
Yes. WDR and HDR both widen dynamic range to handle bright sun and headlights. In this thread, Mikavi PQ1 uses HDR, while PQ2 offers WDR. The poster notes, "The principle of operation is very similar." Either feature helps plate readability in mixed lighting and at night. Prioritize cams with WDR/HDR when driving under changing light. [Elektroda, arekwij, post #17496524]
Are IR LEDs on car cameras actually useful?
Prefer WDR/HDR over IR LEDs. IR illumination only helps at night and can add glare or limited value through glass. As one user said, "It works better than the IR LEDs that illuminate only at night." Dynamic-range processing better preserves detail under oncoming headlights or streetlights. [Elektroda, arekwij, post #17461211]
What budget should I plan for a good front dash cam?
A workable target in this thread was around PLN 500 for a front-only unit. The original poster skipped a rear camera to avoid running power/cables. That budget focus still aimed for clear recordings across lighting conditions. Expect to pay more for dual-channel or advanced features. [Elektroda, madret, post #17462375]
Should I buy a dual-channel (front + rear) dash cam?
Choose dual-channel if you want rear impact evidence and broader coverage. One user bought a Viofo A129 Dual specifically for front and rear recording. Dual systems add protection but increase cost and installation effort. Single-channel remains fine if you prioritize simplicity. [Elektroda, induss, post #17520404]
Is wiring a rear camera a hassle?
It can be, depending on your car and tolerance for routing cables. The original poster skipped a rear camera because they didn’t want to run power to it. If you want easier installation, a single front camera simplifies things. [Elektroda, madret, post #17462375]
How do I evaluate video quality before buying?
  1. Watch sample clips on YouTube and vendor sites without compression.
  2. Check FPS and field of view; wider capture helps context.
  3. Compare night scenes and plates under streetlights. "The more such a webcam is able to catch, the better." This approach reveals real performance beyond spec sheets. [Elektroda, arekwij, post #17465084]
Does the Mikavi PQ1 have WDR?
PQ1 uses HDR (High Dynamic Range), not WDR. PQ2 offers WDR. Both aim to reduce blown highlights from sunlight and oncoming headlights. The poster emphasized their similar operating principle for taming extreme lighting. Either feature helps keep details readable at night. [Elektroda, arekwij, post #17496524]
Is Mikavi PQ2 good if I need to record the car interior?
Yes. PQ2 is a dual model that records the interior, and you can disable the interior camera if you don’t need it. It uses solid components and includes WDR for challenging lighting. Consider it if rideshare or fleet use requires cabin footage. [Elektroda, arekwij, post #17496524]
Are MIO MiVue models reliable?
Experiences vary. One MIO 608 owner reported poor value and reliability issues, including time resets. A notable failure: “From new, the battery lasted 10 minutes. After a year, a few seconds.” Batteries can degrade, so consider super‑capacitor models for longevity. This is a single-user report, but it flags a risk. [Elektroda, seba694637, post #17477250]
Is the Viofo WR-1 worth considering?
A user reported several months of positive use with the Viofo WR-1. They stated it “is doing very well.” This suggests acceptable reliability and performance for a compact unit. Check sample footage before purchase to confirm it meets your needs. [Elektroda, kacha36, post #17497201]
Which Viofo models earned praise here and why?
Viofo A119 V3 drew praise for image quality, detail, and stability. The owner also valued the super‑capacitor and card‑failure alert. Quote: “The camera has a very important function: signaling the failure of the memory card.” These features boost reliability in daily use. [Elektroda, Szyszkownik Kilkujadek, post #19891306]
What did the original poster ultimately choose?
The OP later bought the 70mai A800S 4K. They plan to add a Viofo A129 PLUS DUO in a second car for comparison. This provides a real-world contrast between a 4K single and a dual-channel setup. [Elektroda, madret, post #19891122]
Is Mikavi PQ3 worth a look?
Yes. A user would choose Mikavi PQ3 for its strong parameters, Wi‑Fi, and an additional rear camera. They also noted you can find PQ3 recordings on YouTube to judge quality. Review sample clips to confirm night readability and dynamic range. [Elektroda, jacekRCA, post #17604461]
