Dahua NVR4104-P-4KS2 vs Hikvision DS-7604NI-K1/4P: Best Recorder for Two 4MP Cameras
Tomasz _70 3828 11
Który rejestrator będzie lepszy do dwóch kamer 4 MP i czy zadziałają kamery innych firm?
Nie wskazano jednoznacznie lepszego rejestratora; najbezpieczniej dobrać rejestrator tej samej marki co kamery, a przy kamerach Dahua wziąć rejestrator Dahua [#16707436] W wątku padła też sugestia, że dla Dahua pasuje kamera IPC-HFW4431R-Z 4 MP, natomiast przy rejestratorze Hikvision nie było pewności co do wyboru kamery [#16703727] Zwrócono uwagę, że kamery IP z „średniej półki” powinny działać poprawnie [#16707436] Padła również opinia, że kamery marek H lub D będą działały poprawnie, więc urządzenia innych firm powinny być możliwe do użycia [#16707297]
  • #1 16703683
    Tomasz _70
    Rate: 10
    Hello, which of the above recorders is better? It only needs a recorder for two 4 MP cameras.
  • #3 16703727
    Tomasz _70
    Rate: 10
    sosarek wrote:
    Tomasz _70 wrote:
    two 4 MP cameras.
    What?
    If there was a Dahua recorder, it would be the IPC-HFW4431R-Z 4mp. However, if the HK recorder, I do not know which camera to choose. I have one more question: are third-party cameras suitable for these two recorders?
  • #5 16703753
    Tomasz _70
    Rate: 10
    [quote = "sosarek"] What are these cameras to observe. The cameras will be directed to the streets. They will be suspended at a height of 4 m and observe the streets at a distance of about 20 m
  • #6 16706332
    Tomasz _70
    Rate: 10
    There was silence, too bad :(
  • #7 16707297
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    H or D brdIe work properly.
    Someone will probably advise you when buying in the store.
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #8 16707436
    jpl
    Help: 240
    Rate: 223
    [quote = "Tomasz _70"]
    sosarek wrote:
    What these cameras are supposed to observe: the cameras will be directed to the streets, they will be suspended at a height of 4 m and they will observe the streets at a distance of about 20 m
    at the maximum zoom of the lens - they will see and will work
    How do you take dahua cameras - take dahua recorder. In the case of IP - look for the middle shelf
  • #9 16708089
    Tomasz _70
    Rate: 10
    Is this an original product?
    https://pl.aliexpress.com/item/Dahua-NVR2104-...-Ports-HDMI-Network/2014316022.html?spm=a2g17. search0104.3.1.YmfVxB & ws_ab_test = searchweb0_0, searchweb201602_4_10152_10065_10151_10068_10344_10342_10343_10340_10341_10304_10307_10301_10137_10060_10155_10154_10056_10055_10054_5470020_10059_100031_10099_5460020_10338_10339_10103_10102_440_10052_10053_10142_10107_10050_10051_5380020_10171_10326_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_143_10312_10313_10314_10078_10079_10073, searchweb201603_16, ppcSwitch_5 & btsid = 9076afe5-9413-4bca-a58c-2f349e7fae98 & algo_expid = 16c2f708-a826-46d1-989c-56c996b64863-0 & algo_pvid = 16c2f708-a826-46d1-989c-56c996b64863
  • #10 16708186
    jpl
    Help: 240
    Rate: 223
    So why shouldn't it be?
  • #11 16708190
    Tomasz _70
    Rate: 10
    Because it is for 50% of the price in Poland.
  • #12 16708232
    jpl
    Help: 240
    Rate: 223
    duty with transport is about 20%. To this, add 23% VAT. It is still good to earn and maintain the service in PL for two years. You already know where it came from.
The discussion centers around comparing the Dahua NVR4104-P-4KS2 and Hikvision DS-7604NI-K1/4P as suitable recorders for two 4MP cameras. Users inquire about the compatibility of third-party cameras with these recorders and the specific use case of monitoring streets from a height of 4 meters. There are mentions of the Dahua IPC-HFW4431R-Z camera and considerations regarding the authenticity and pricing of Dahua products from online sources. The conversation highlights the importance of selecting the appropriate recorder based on camera brand compatibility and the potential costs associated with importing equipment.
TL;DR: For a two‑camera, 4MP street setup, match brand to brand and budget for import costs. "duty with transport is about 20%" and Poland adds 23% VAT. Choose Dahua cams → Dahua NVR; same for Hikvision. [Elektroda, jpl, post #16708232]
Why it matters: This avoids compatibility headaches and surprise costs for small two‑camera builds, especially when comparing local vs. overseas prices.
Which NVR is better for two 4MP cameras—Dahua NVR4104‑P‑4KS2 or Hikvision DS‑7604NI‑K1/4P?
Pick the recorder that matches your camera brand. If you choose Dahua cameras, use a Dahua NVR; do the same with Hikvision. This reduces setup friction and preserves full feature support. As one expert put it, “take dahua cameras – take dahua recorder.” [Elektroda, jpl, post #16707436]
Will two 4MP cameras capture useful street detail at ~20 m?
Yes, provided you use appropriate lens zoom. The guidance shared was that at maximum lens zoom the cameras “will see and will work” for a ~20 m street view. Mounting height around 4 m aligns with the described scenario. [Elektroda, jpl, post #16707436]
Should I mix Dahua cameras with a Hikvision NVR (or vice versa)?
The thread raises this question but does not confirm cross‑brand compatibility. To avoid surprises, plan on same‑brand pairing for cameras and NVRs in this two‑camera build. [Elektroda, Tomasz _70, post #16703727]
Do Hikvision or Dahua NVRs work reliably for small two‑camera installs?
Yes. A contributor noted that either brand works properly in this class of setup. This aligns with typical two‑channel, PoE‑powered residential or small‑business deployments. [Elektroda, Fotodetektor, post #16707297]
Are Dahua NVRs on AliExpress original products?
A responder questioned why they wouldn’t be original, but no proof was provided either way. If authenticity matters, weigh local warranties and authorized channels against price. [Elektroda, jpl, post #16708186]
Why are local Polish prices higher than Chinese listings?
Expect import duty plus transport around 20% and add 23% VAT; local sellers also fund two‑year service. Those factors explain sizable retail differences versus overseas prices. [Elektroda, jpl, post #16708232]
Is buying overseas really half the cost?
One buyer observed about a 50% lower price on AliExpress compared with local offers. Add total landed costs and potential lack of local service before deciding. [Elektroda, Tomasz _70, post #16708190]
What lens or zoom should I plan for ~20 m street coverage?
Use the camera’s maximum lens zoom for that scene width and distance. This was the practical guidance given, and it matches many varifocal 4MP builds. [Elektroda, jpl, post #16707436]
How high should I mount the cameras for this scenario?
About 4 m was the stated mounting height for viewing a street at roughly 20 m distance. Keep that as a starting point, then fine‑tune angle and zoom. [Elektroda, Tomasz _70, post #16703753]
Quick way to choose between these two NVRs?
Follow this three‑step check: 1. Decide the camera brand first. 2. Match the recorder to the same brand. 3. For a 20 m street view, set lens at maximum zoom and verify coverage. [Elektroda, jpl, post #16707436]
What’s the hidden risk when importing NVRs/cameras?
Edge case: You may miss local two‑year service support when buying abroad. Local pricing reflects duty (~20%), VAT (23%), and service overheads. [Elektroda, jpl, post #16708232]
Who is this guidance for?
It targets users planning a simple two‑camera, 4MP, street‑facing install at ~20 m distance, weighing Dahua vs. Hikvision NVRs. [Elektroda, Tomasz _70, post #16703683]
