Sharan 1.9 TDI 110 AFN - Tightening Torques for Heads, Camshaft, Injection Pump & More
gebels1973 41118 2
  • #1 17473805
    gebels1973
    Help: 10
    Rate: 101
    Hello. Please tell me how much power we tighten in 1.9 tdi 110 afn:
    heads
    camshaft
    injection pump wheel
    the camshaft on the shaft
    on the shaft
    connecting rod feet
    tightener
    flywheel
    Thanks in advance
  • #2 17473903
    Daro122
    Help: 165
    Rate: 751
    I have such data.
    • Sharan afn.pdf (951.97 KB) You must be logged in to download this attachment.
  • #3 17474051
    msati123
    Rate: 35
    You have everything I have:
    Head: Replace the screws
    Stage 1 40 (Nm)
    Stage 2 60 (Nm)
    Stage 3 90 (°)
    Stage 4 90 (°)
    Connecting rod foot bearing cover
    (Replace screws)
    Stage 1 30 (Nm)
    Stage 2 90 (°)
    Main bearing cover
    (Replace screws)
    Stage 1 65 (Nm)
    Stage 2 90 (°)
    Engine oil drain plug 30 (Nm)
    Injector 20 (Nm)
    Glow plugs 15 (Nm)
    Starter 45 (Nm)
    Valve cover 10 (Nm)
    Camshaft bearing caps 20 (Nm)
    Camshaft gear 45 (Nm)
    Crankshaft pinion
    (Replace screw (s), lightly greased threads)
    Stage 1 90 (Nm)
    Stage 2 90 (°)
    Crankshaft pulley
    (External screws) 25 (Nm)
    Flywheel
    (Replace screws)
    Stage 1 60 (Nm)
    Stage 2 90 (°)
