[Solved] Samsung Galaxy J5 2017 Call Recording Issue: Apps/Settings to Fix Aubio Source Not Available
sosino 5862 1
  • #1 17488892
    sosino
    Rate: 36
    My phone does not record calls. On the older model, I had no problem with that. Current J5 2017 not recorded, or it records every tenth conversation. I tested several recording applications and kept the same message "Failed to write, aubio source not available, or format not supported".
    I changed the settings in various applications and it was still the same.
    Maybe an application is blocking it or something needs to be changed in the phone settings?
    Someone had the same?
    Added after 1 [hours] 55 [minutes]:
    I think I have. I had "Wifi Calling" turned on. I quit and started recording. We'll see for how long.
  • #2 17546682
    sosino
    Rate: 36
    I think I have. I had "Wifi Calling" turned on. I shut down and it started recording. We'll see for how long.
