Samsung J5 2017 - a message pops up every now and then
12723 10
How can I stop the "Google Play services keeps stopping" error on a Samsung J5 2017 and restore access to Google Play Store and Google Play apps?
Uninstall updates for Google Play services, clear its cache, restart the phone, and then update it again from the Play Store [#19192724] If the error keeps blocking navigation, use the error dialog’s “about the application” path to reach the app settings more quickly and do the steps as fast as possible [#19192724] In the reported case, a fresh software install fixed the problem, while a factory reset did nothing [#19197095]
  • Request for more data on Google Play services crash
    #1 19191942
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Any error in the software, restore factory settings, as it will not help to upload a new soft. If the soft will not want to be uploaded, the memory is damaged and the phone is practically scrapped.
    Mateusz3322
    Help: 12
    Rate: 73
    Samsung J3 and J5 2017 have problems with emmc memory and I tend to the last variant given by the tino2003 user. Probably a scrap phone. To be sure, win soft, you'll find out.
    gathor10
    Help: 100
    Rate: 137
    None of the above. Go to settings, then applications. Uninstall updates to google play services and clear their cache. Restart the phone. After rebooting, go to the play store to download new updates.
    Uninstall Google Play services updates and clear cache
    #5 19192964
    Mateusz3322
    Help: 12
    Rate: 73
    It is impossible to do it in the state of the phone. This message appears every now and then and effectively prevents you from navigating through the settings. Or he will put the soft back on, and if it fails, the phone will be in the garbage can.
    eMMC failure unlikely on J330 and J530
    #6 19193271
    blahfff
    Help: 1036
    Rate: 1301
    It is possible, although you have to be stubborn and patient. It's not like that every time you click "close applications" or "ok", you reload on the home screen. Moreover, clicking on "about the application" should take it immediately to the right place.
    So far I have not met either the j330 or the j530 with the eMMC collapsed.
    eMMC failure unlikely on J5 2017 popup issue
    #7 19193291
    Mateusz3322
    Help: 12
    Rate: 73
    I had a J3 2017 that had my memory lost a week after the warranty.
    gathor10
    Help: 100
    Rate: 137
    Everything is possible. Click on close and quickly the next step. If you don't want to keep data, please reset your phone and then follow the steps as described above just to be on the safe side.
    We accepted thousands of these "shit" for the service in szajsung and only a small percentage of them had eMMC collapsed
  • #9 19196757
  • #10 19196953
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    JULJERYT wrote:
    Thanks you made it! You are great!
    Then write which option worked in your case, such information may be useful to another person with such a problem.
  • #11 19197095
The Samsung J5 2017 user reported persistent issues with the message "Google Play services still stops working," hindering phone usability, particularly when typing. Responses suggested various troubleshooting steps, including performing a factory reset, uninstalling updates to Google Play services, and clearing the cache. Some users indicated that the problem might be related to eMMC memory failure, common in Samsung J3 and J5 models. Ultimately, the user found success by reinstalling the software, as the factory reset did not resolve the issue.
