[Solved] PROEKO PLUS Boiler & Blower Issue: Airflow Problem, Nozzles, Proton PID Controller & Fixes
piloszkotosz 18012 15
How can I make a PROEKO PLUS boiler with only under-grate airflow and no chamber nozzles burn fine coal properly?
Use a simple under-grate air distributor made from four 1" pipes fitted tightly into the four corners of the grate, drilled every 7–8 cm and aimed toward the center of the combustion chamber; the first single RHS tube placed in the middle failed, but the corner-pipe version made the whole bed burn evenly with blue flames and kept the boiler stable for about 20–30 hours [#17506465][#17510308] Keep the top closed so the air does not escape, and make the parts removable so you can pull them out for ash cleaning and put them back in [#17506465][#17510308] If the fuel is very fine and burns too tightly, start with about 25% fines relative to the initial charge or mix in coarser coal, because too-tight dust can burn poorly [#17506435] The boiler itself was not considered undersized; the smaller model simply relies on air from below the grate, so this retrofit was used to compensate for the lack of nozzles in the chamber [#17506400][#17510338]
  • #1 17506322
    piloszkotosz
    Rate: 31
    Hello, honorable forum members.
    Please help. Maybe someone will have an idea for my situation.
    I will use specific links, and to be clear, but this is not an advertisement - I note.
    I bought a PROEKO PLUS boiler from this link http://www.kotly-witkowski.pl/kotly/proeko-plus
    In addition, I bought a supposed to be very good in bags from this link https://ekogroszekprestige.pl/mial-weglowy-pakowany/
    Unfortunately, after some time I realized that this boiler is not 100% fine. It has an airflow only from the ash pan and only on one side. It has no nozzles in the charging chamber. The air from the fan does not pass through the fuel. I light up from above. Proton PID controller.
    In connection with the above, I have made a RHS profile with holes drilled from the bottom up. Length is about 0.5m long. Blinded from above. I put it in the middle of the grate. Air is leaking now. On top of the fine coal I put some coal on the fire. It burns like stupid, but when the coal burns out, the dust does not give much heat. Problem with reaching the set temperature. In fact, it barely heats the stove itself (I set the pump to turn off around the set temperature). As if there was too much air (cooling with blowing). As if there were no calories in fuel. You can't see the blue flames.
    I am asking for some ideas from experienced smokers. What can I do here. I bought the cauldron for my in-laws. I bought them had and thought that this species would be a rocket, and here my hands drop. I'm in dead end. Boiler 11KW. The manual says that from about 16KW there are nozzles on the back wall of the hearth. I didn't know about it. I'm in a bind of what to do. I've never smoked. I am asking for some help. Thank you in advance.
  • #2 17506326
    Xantix
    Help: 686
    Rate: 1657
    piloszkotosz wrote:
    it did not give much heat.
    Because he had it. It is low in calories by nature, unfortunately. Anyway, I am surprised by the description of this fine coal: "crushed high-energy coal" - they crushed good quality coal (which is by nature expensive) and sell it as much cheaper had? I don't feel like believing in it ...
    Or maybe the boiler is too small for the needs of the building? As far as I know, the power of the fine coal boiler is selected differently than that of other solid fuel boilers:
    http://czysteogarzenia.pl/kociol/co-za-duzo-t...kotla-weglowego/#Wyjatek_dla_kotlow_mialowych
  • #3 17506400
    piloszkotosz
    Rate: 31
    Thank you for your participation in the topic.
    The boiler is ok when it comes to power. It drives 4 radiators and 80l hot water. The radiators are not big.
    One week I decided what to buy and unfortunately it fell on this one. I did not notice that the smaller model has airflow only under the grate. When I put in eco-pea coal, it warms up too much. The pipe with holes allowed any smoking. Without it, it went out upstairs. But I'm not sure if I did it right, and I found no descriptions anywhere except for one video https://www.youtube.com/watch?v=7wWxIncrlr4
    I blinded from the top because all the air would have escaped. You could mix with a thicker one, but the in-laws took 3 tons at once and I was left with the problem. Horror.
  • #4 17506435
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    piloszkotosz wrote:
    You could mix with the thicker
    I just wanted to write this. The had you smoke is just too tight. Perform a firing up with 25% fines compared to what you poured at the beginning. If it burns well, with each new fire, increase the height of the charge.
  • #5 17506465
    piloszkotosz
    Rate: 31
    Thank you Magister_123
    I just brought a bag of coal dust for the test, which was burned in a DRAGON type furnace. It burned very well and purple. Only this one
    the boiler has two inlets for the grate on the left and right and a few holes on the sides in the walls
    charging chamber. I'll let you know about the effects. Greetings to the forum members.
    Added after 4 [hours] 2 [minutes]:
    If I write a post under my post, sorry, but I rarely write something on forums and I'm not very experienced in it.
    So I'm writing about the effects. I fired the RHS which I put in the center of the grate. He failed the exam. because it burned out near him and nothing towards the walls of the chamber. I dumped 2/3 of the furnace dust and the rest of the ash. After thinking about the subject, I cut 4 pieces of 1 "pipe and cut one side with a flex at a sharp angle. Thanks to this, they fit firmly and tightly into the grate. I placed them in the four corners of the boiler.
    There, they block and take the air blown under the grate. Of course, drilled 7-8 every 7-8 cm. The higher the gaps are. Holes directed to the center of the charging chamber. At the top, they are tied with four slightly welded rebars, so that they do not break apart.
    And in order to eliminate at least one of the factors, I lit it with a bag of fine coal that was delivered and checked. And now the effects.
    It burns like a gas stove :D :D :D . It burns on the entire square surface from the center to the sides. The stove jumps 2 degrees up and down and heats very reliably and smokelessly. I am currently very busy after all this (additionally I have a renovation which I do myself), but I will try to post photos and videos of this case as soon as possible. Maybe it will help others in a similar situation.
    If I knew it would be like that, I would have made 4 thick-walled flat bars with pre-drilled holes right away and caught on the corners. Those that would protrude a little above the lower edge of the hopper and take air from the sub-grid. This is a test for the moment, so maybe I'll do it before the boiler overgrows.
    The next stage will be ignition on "super fine coal" :lol:
    If it's not ok, then it's a complaint. For now, thank you for contributing to the topic.
    I will post the materials. Best regards.
    Added after 19 [hours] 46 [minutes]:
    Welcome back.
    Well, it's been burning for about 20 hours. 2/3 of the load is left. All the time the flames are all blue. Maybe if I added 4 more tubes in the middle of the coat, the aeration would be around and even better, but maybe not overcomplicating it ???.
    Tomorrow I will try to post photos and videos. Best regards.
  • #6 17510308
    piloszkotosz
    Rate: 31
    So I'm adding photos of the smoking process.
    The first patent that did not work completely, i.e. the rhs in the middle of the hearth:
    Before that, I put paper on the fire, but it turned out to be wrong. It also blocked the flow. Now first 5 cm of eco-pea coal
    PROEKO PLUS Boiler & Blower Issue: Airflow Problem, Nozzles, Proton PID Controller & Fixes PROEKO PLUS Boiler & Blower Issue: Airflow Problem, Nozzles, Proton PID Controller & Fixes
    For this, he had 5 cm of eco-pea coal at the top and a fire
    This is what it looks like after an hour
    If I find out how videos are added, I will attach it.
    Generally it burned for 30 hours. This is what the patent looks like. You can basically set it up and not weld, because I didn't move anything in the chamber after that. When removing ash, you can freely remove it for cleaning and reinsert it. Burned ones are easy to replace. More tubes can be added at any time. I have one more batch of good fines, so I will describe the tests with this "great" in 4-5 days.
    I also plan to put a deflector, e.g. made of fireclay bricks, on these bars, when the load is slightly lower. Plus, maybe I'll make swirls between languages. I will be adding information slowly.
    Generally, a very easy method for all those who have similar boilers only with air from the bottom, or even typical fine coal, but want to improve something in half an hour without welding, etc ...
    I am asking for any comments and opinions, and if it helped someone, maybe a point :D . PROEKO PLUS Boiler & Blower Issue: Airflow Problem, Nozzles, Proton PID Controller & Fixes PROEKO PLUS Boiler & Blower Issue: Airflow Problem, Nozzles, Proton PID Controller & Fixes PROEKO PLUS Boiler & Blower Issue: Airflow Problem, Nozzles, Proton PID Controller & Fixes
  • #7 17510338
    Xantix
    Help: 686
    Rate: 1657
    You click "reply" at the bottom of the page and when the page opens, you have the "add movie" tab above the text field. You click and follow the instructions.
    If it helps and you do not need to weld anything on the boiler, then I am absolutely in favor of such a solution. It generally looks like a furnace chamber ventilation system in a fine fine coal construction. The only difference is that there are ventilation holes along the entire length of the side wall, not just at the corners of the hearth.
    piloszkotosz wrote:
    I still plan to put a deflector, e.g. made of fireclay bricks, put it on these rods, when the load is slightly lower
    And how will you solve the deflector to maintain a constant distance from the charge as the coal burns off?
    piloszkotosz wrote:
    and if it helped someone, maybe some point :D
    You already have it from me - for the ingenuity and simplicity of the solution. ;)
  • #8 17510546
    piloszkotosz
    Rate: 31
    Thanks to Xantix for the positive feedback.
    As for the deflector, I have no idea how to adjust the gap, but I think that the addition itself should bring some positive effect. All in all, with the door closed and the heat there is high temperature and when the deflector heats up, it has to burn out a bit, but that's just my opinion.
    You write well about more holes in fine fines. I got the idea that you can make such side attachments from sheet metal. Two plates with the width and height of the side wall from the charging chamber, or slightly lower. They would be e.g. 1-2 cm apart. The sides and top are closed with flat bars. Open bottom and located along the extreme grate. Structure adjacent to the boiler wall. There are holes in the outer plate adjacent to the fuel. The air from under the grate would come inside and it would provide great aeration. The second same structure for the second wall. You can and all of them. The question remains how large the structure will enter through the door (different furnaces). If I do a little, I will do it and test it.
    By the way, I used to make some kettles for my friends when I was younger and had a little more strength and time. They were for wood and heating oil, and various, with and without a feeder. Hence a bit of ingenuity.
    I made the last boiler three years for myself after a long break. It burns completely smokeless coal. It has a fireclay burner, a vizier tube and patents like that.
    Maybe when there will be a moment, I will create a topic and present photos and descriptions.
    There are also people who want to do something for themselves and will probably benefit from something. Best regards.
    After firing up
    [movie: 491ad2d54f] https://filmy.elektroda.pl/41_1540200479.mp4 [/ movie: 491ad2d54f]
    Some time after firing up. Sorry for the audio, but I don't have time to edit the video.
    [movie: 491ad2d54f] https://filmy.elektroda.pl/52_1540200690.mp4 [/ movie: 491ad2d54f]
    Added after 40 [minutes]:
    I wanted to add a little sketch as if I would see it more or less.
    Sorry for the scribbles :|
  • #9 17510727
    Sstalone
    Help: 72
    Rate: 398
    How many kg did you put the fines into the chamber?
  • #10 17510739
    piloszkotosz
    Rate: 31
    I covered the incomplete 25 kg bag of fine dust. Some peas down and up, but not much.
    After 30 hours the temperature was starting to drop, so I turned it off. It burned out to the very grate almost. When I come back from work, after 5 p.m. I will fire up again.
    The post-German home of my parents-in-law is said to be 160 years old. Pruchno and clay with bricks. Not insulated. He heated four radiators and a boiler.
    In terms of better combustion, I thought that the last holes from the top, or the last 2, should be drilled at an angle. Then a vortex will be created and air will be better mixed with the combustible gases.
  • #11 17510807
    Sstalone
    Help: 72
    Rate: 398
    It turns out that you smoke with an average power of about 6 kW. There is about 20 kW in the film when firing up. In my opinion, unfortunately, with such a low power, you will not have a better afterburning ... with such a chamber. But don't give up, maybe you'll come up with something ...
  • #12 17510904
    piloszkotosz
    Rate: 31
    The boiler always runs at much higher power when firing up, because the water is cooled down. The controller gives max. airflow (which I just set) and then the PID catches up with the setting. I have a hysteresis of 5 degrees and at minus 5 degrees from the setting, it starts to slow down. When it is -2 to the current setting, it spins slowly.
    With time, when everything warms up, the boiler only "cracks" and gives only as much power as needed to maintain the set temperature. This is how it should be and normal. With this afterburning of exhaust gases, it is about savings - you know. But it's more about cleanliness in the boiler and chimney. I'm not going to run from my stove to my in-laws and scratch and I don't think anyone likes it. As you can see in the attached materials, the combustion is very good and there will be no major savings here. Do not kid yourself. But the fewer unburned exhaust gases, the less cleaning, that's why I fine-tune this topic. Besides, this is my horse and so I already have that if I can improve something else, I will not give up. Best regards.
  • #13 17511380
    Sstalone
    Help: 72
    Rate: 398
    But I know all this, only afterburning of exhaust gases is contrary to flammability, I am not able to achieve clean combustion below 6 kW, which, as I look at the furnace after firing up, is yours, so in this situation the swirlers will not help, you will have to increase the current boiler power which will lower the flammability.
    The cleanliness of the boiler depends on the cleanliness of the combustion itself, from the ignition itself, the flame is not clean during the ignition.
    Here you have a look at my experiences. https://www.elektroda.pl/rtvforum/topic3298994.html#16933797
  • #14 17511601
    piloszkotosz
    Rate: 31
    Hello Sstalone.
    I agree with you. You will need to scrape it from time to time, or heat it well and clean it. There are no miracles. But if we didn't do anything, it would be overwhelmed. We're not going to make a doctorate out of it anyway :D . If it was my cauldron, I would put some fireclay on it and thus reduce the surface of the "burner". I would light up more often, but the boiler would run at higher speed (because less power) and it would burn even better, but I don't have time to play and it will stay that way. The in-laws are taken to heaven anyway, and because they are over 80 years old, it helped them a lot. After work, I will choose and clean the next batch. I have 30 hours of rest. I'm glad it ended this way, because I was in a slight panic at the beginning. But I will make these records in my spare time out of curiosity. Regards and thanks for participating in the topic.
  • Wet fuel may be causing poor combustion
    #15 17517196
    piloszkotosz
    Rate: 31
    Hello, after a little break.
    I must say that so far, I have a significant problem with smoking, I had a great one. There is basically no flame above it. Day to night compared to the one transported loose from the square. I do not know if it is the fault of insufficient aeration or such fuel.
    I have a question for col. Sstalone, which I had smoked or smoked. Whether you soaked or completely dry. I have read a lot about it and opinions are divided, but looking at your clean exchanger and the quality of smoking I am full of admiration. I have no experience with such fuel. Mine is very dry to the touch. I think I got too wet the first time. It burned poorly. The second time I got wet so that light sparks flew. Effect to + None. I have already written to the consumer ombudsman and am waiting for a reply. I don't know how it will end. Best regards.
  • #16 18994137
    piloszkotosz
    Rate: 31
    In retrospect, I have mastered the topic of smoking and close this discussion for the sake of order. Greetings to the forum members.
The discussion revolves around issues faced with the PROEKO PLUS boiler, specifically related to airflow problems and combustion efficiency. The user reports that the boiler only draws air from the ash pan and lacks nozzles in the charging chamber, leading to inadequate fuel combustion. Various solutions are proposed, including modifications to the boiler's airflow system by drilling holes and using RHS profiles to enhance air distribution. Users suggest experimenting with different types of coal, such as eco-pea coal and fine coal dust, to improve burning efficiency. The importance of proper aeration and the impact of boiler size on heating needs are also discussed. The conversation highlights the challenges of achieving clean combustion and the necessity of regular maintenance to prevent smoking issues.
TL;DR: Fix PROEKO PLUS airflow by adding four perforated 1" corner tubes; after ~20 hours, 2/3 of the load remained and "It burns like a gas stove." This helps 11 kW units without chamber nozzles burn fines cleanly. [Elektroda, piloszkotosz, post #17506465]
Why it matters: Owners of smaller PROEKO PLUS boilers can get stable, blue-flame heat from fine coal without welding or replacing the unit.
How do I fix uneven airflow in a PROEKO PLUS 11 kW without welding?
Use four 1" steel tubes as corner air inlets. Drill 7–8 mm holes every 7–8 cm, angled toward the center. Blind the tops, insert one in each corner along the grate, and tie together with rebars. This spreads under-grate air through the fuel bed. Expect blue flames across the surface and tight temperature swing (about ±2°C). “It burns like a gas stove.”
  1. Cut, drill, and cap four 1" tubes.
  2. Insert at corners, holes inward.
  3. Tie, load fuel, top-light, and tune fan. [Elektroda, piloszkotosz, post #17506465]
Why does my PROEKO PLUS only blow air from the ash pan on one side?
On smaller models, air feeds under the grate only, often biased to one side. The 11 kW version lacks chamber nozzles. The manual notes nozzles start at about 16 kW on the back wall. That design leaves fines poorly aerated unless you add distribution paths. [Elektroda, piloszkotosz, post #17506322]
Is fine coal (miał) too low in calories for good heat?
Yes, expect lower effective heat. As one expert put it, fine coal is “low in calories by nature.” That limits peak temperature and makes blue flames harder to sustain without good aeration. Watch vendor claims about “crushed high‑energy coal.” Combustion quality improves more from airflow and sizing than marketing labels. [Elektroda, Xantix, post #17506326]
Should I mix fines with larger coal to improve combustion?
Yes. Start your charge with about 25% fines and 75% larger coal. If that burns cleanly, increase fines gradually with each firing. The coarser fraction opens air channels so under-grate airflow reaches volatiles for afterburning. This approach helps prevent smothering and stabilizes PID control. [Elektroda, Magister_123, post #17506435]
What Proton PID settings worked for stable temperature with fines?
One working setup used a 5°C hysteresis. The controller drives maximum fan during cool starts, then tapers airflow as it nears setpoint. With the boiler and system warm, it idles and adds just enough air to hold temperature. That strategy reduced overshoot and cycling. [Elektroda, piloszkotosz, post #17510904]
How long can a single load last with the corner‑tube mod?
Reported runtime reached about 30 hours per charge with stable blue flames. The mod evenly aerated the bed, kept temperatures steady, and reduced smoke. That duration depends on load size and heat demand, but the result shows strong efficiency gains from proper air distribution. [Elektroda, piloszkotosz, post #17510308]
How much power does the system draw at startup versus steady burn?
An experienced user estimated around 6 kW average during steady operation. During ignition or heavy recovery, instantaneous output looked near 20 kW. That gap explains why PID fans run high at start, then ramp down once the system warms. [Elektroda, Sstalone, post #17510807]
My central air pipe made the fire burn only near it. What went wrong?
A single central riser can starve the edges. The fire consumes oxygen near the pipe, while walls remain under-aerated. The fix was to move to multiple corner inlets with inward-facing holes. That distributed air across the whole bed and solved edge quenching. [Elektroda, piloszkotosz, post #17506465]
What ignition layering worked best for fines in this boiler?
Top-light with a base and cap of eco‑pea coal. Use about 5 cm eco‑pea at the bottom, then fines, then 5 cm eco‑pea on top. Light from above to keep volatiles burning as they rise. Avoid paper layers that block airflow. [Elektroda, piloszkotosz, post #17510308]
Will adding a deflector help afterburning?
A deflector can raise gas temperature and promote mixing, but gap control matters. If the gap closes as fuel settles, draft suffers. As one commenter asked, how will you keep a constant distance while coal burns away? Test carefully if you add bricks. [Elektroda, Xantix, post #17510338]
Does wetting bagged fines improve burn quality?
Results were poor here. Very dry bagged fines showed little visible flame versus loose yard fines. Heavier wetting burned poorly, and light misting made little difference. Moisture tweaks could not overcome fuel characteristics in this case. [Elektroda, piloszkotosz, post #17517196]
Can I remove the corner‑tube mod easily for ash cleaning?
Yes. The setup can be friction‑fit without welding. You can lift the tubes out for ash removal, then drop them back in. Burnt tubes are easy to replace, and you can add more later if needed. [Elektroda, piloszkotosz, post #17510308]
Will this solution work at very low power, or are there limits?
Expect limits below roughly 6 kW with this chamber type. Clean afterburning gets harder as power falls. Swirlers alone may not help then. One expert advised increasing boiler power to reduce flammability issues at the lowest outputs. [Elektroda, Sstalone, post #17510807]
If nothing helps, is there still a path to success?
Yes. The poster initially considered a complaint, then refined airflow and firing practice. Later, they reported mastering the burn and closed the discussion. Persistence with air distribution and ignition method paid off. [Elektroda, piloszkotosz, post #18994137]
