PDF Issues: How to Copy Odd Characters from PDF to Word/Google Translator?
Willisek 25887 10
How can I copy text from a PDF into Word or Google Translator when pasting produces random symbols and strange characters?
Check whether the PDF is copy-protected or uses a non-standard text encoding. In Adobe Reader, try File → Save as Other → Text; if that option is greyed out, the document has copy protection [#17521026] If copying is allowed but the pasted result is still garbled, the PDF likely uses a different character encoding, so the copied text is being interpreted incorrectly by Word or the browser [#17522566] Also check the PDF’s security settings in the viewer, because some documents block copying even when they look normal [#17516900]
  • #1 17516757
    Willisek
    The topic was discussed here but I did not find an answer. As in the topic: when I copy text from a PDF file to a google translator on a website or simply to word, a whole bunch of strange bushes appear instead of the copied text.
    Anyone have a method for this strange condition?
  • #2 17516827
    viayner
    Help: 1563
    Rate: 2052
    give an example,
    are you copying text or something "binary", is this a valid PDF document, is the browser interpreting it correctly? Missing font?
    best regards
  • Broken PDF text encoding causes garbled copy output
    #3 17516854
    Willisek
    viayner wrote:
    give an example,
    It copies plain text in a language other than Polish and it is nothing unusual. Other pdfs can be copied without any problems, but I don't want this one, although it looks the same. PDF document as correct as possible. Neither does the browser correctly interprets nor the word text editor. These are not missing fonts like "ą" or "ę". After copying, I just get a whole string of hearts, squares, dots, question marks, etc, etc ...
  • #4 17516900
  • #5 17516921
    Willisek
    Christophorus wrote:
    Check the file's properties in the PDF file viewer if there are no security settings, e.g. against copying the document content.
    There are no security settings
    Added after 22 [minutes]:
    I can copy it, but when I paste it into the browser or into words, strange stamps come out without text
  • #6 17517014
  • Registry fix for garbled PDF printing characters
    #7 17517016
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Maybe not entirely in the subject, but maybe something will lead to "the right path".
    I had a similar problem, just not with copying and viewing, but with printing some PDF files, it was also printing various strange characters and similar to "Chinese hieroglyphs".
    The method given here helped:
    "Delete the entry in the registry" Arial, 0 "=" Arial, 238 "Path to the entry: [HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ WindowsNT \ CurrentVersion \ FontSubstitutes]" Arial, 0 "=" Arial, 238 ""
    https://forum.dobreprogramy.pl/t/problem-z-drukowaniem-pdf-w-adobe/441958/6
    After this change, printing is "normal", there are no more "bushes" and other strange signs.
    Only with changes to the registry you should be careful not to introduce more evil than good. Before making any changes, it is essential to make a copy of the current (before changing) registry so that in case of failure or complications there is something to restore the "good" registry.
  • #8 17518369
    Willisek
    unfortunately to no avail. I am using Win 8.1
  • #9 17518388
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Are you able to attach a sample file for testing?
  • #10 17521026
    spp
    Help: 5
    Rate: 9
    A Adobe Reader -> File -> Save as Other -> Text ...
    If it is greyed out and cannot be clicked, it means there is copy protection.
The discussion revolves around issues encountered when copying text from a PDF file, resulting in strange characters appearing instead of the intended text. The user reports that while copying plain text from a valid PDF document, the output includes symbols like hearts, squares, and question marks, rather than the expected characters. Various suggestions are made, including checking for security settings in the PDF, using different PDF viewers, and exploring character encoding issues. One user mentions a potential solution involving registry edits to resolve similar problems with printing PDFs. However, the original poster indicates that these solutions have not resolved their issue, and they are using Windows 8.1. Additional advice includes using Adobe Reader's "Save as Other" function to extract text, which may be disabled if copy protection is present.
