Unable to Print PDFs with HP & Brother Printers - Adobe Issues, Timetable Preview Stuck
Ulciak 37188 7
  • #1 14292972
    Ulciak
    I have a problem printing documents from PDF.
    I have two HP and Brother printers installed, they print everything but PDF documents for me.
    When I execute a print command, nothing happens at all. When I try to print a timetable directly from the page, the preview is loading all the time and nothing else.
    I suppose it's a problem with Adobe.
    Please help, I'm not very skilled at this.
  • #2 14293025
    Edward J
    Put a photo of the print command screen in PDF, maybe you didn't see something there. It looks. Otherwise it will be difficult to help.
    copyman
    Photocopiers specialist
    Help: 1106
    Rate: 834
    Try to download (save) these documents and then print them. Make them the default Adobe Reader application and use it to print these files. The devices / drivers themselves are not a problem here. The way of managing the print is to blame. What system are you using? Win, OsX, Linux?
    C.
  • Chrome printing fails for some PDFs while saved invoices print successfully
    #4 14296925
    Ulciak
    I am using Windows Vista and Chrome. I read somewhere that people in Chrome have a printing problem.
    In fact, I had an invoice, and when it opened in my browser, calling the print command didn't do anything (neither pressing the printer symbol nor the shortcut ctrl + P). When I saved it to the desktop, it printed without a problem.
    On the other hand, it is impossible to print the timetable, bank statement or transfer confirmation. Loading appears for me and nothing is done.
  • #5 14297390
    rys57
    Moderator
    Help: 212
    Rate: 436
    Give me this photo.
    Yes. They have a problem when they don't read the icon commands :D .
  • #6 14301429
    Ulciak
    How can I take a photo when I don't get a print command when I print.
    Use File > Print and change the PDF viewer if needed
    #7 14301471
    Edward J
    Don't use keyboard shortcuts. After opening the document for printing, select the FILE option from the menu (acrobata in which the document was opened), then PRINT. The print management screen is then displayed with many options to set, including the indication of the printer, print range, size, number of pages to be printed ... etc. If it is not as described, change the program to open PDF - s. They give them everywhere, even on the websites of banks, ............
  • #8 14301775
    Ulciak
    Thanks, this time it worked :) I hope it will be okay already.
The discussion revolves around issues with printing PDF documents using HP and Brother printers. The user reports that while other documents print successfully, PDFs do not respond to print commands, particularly when using Chrome on Windows Vista. Suggestions include saving the PDF files before printing and ensuring Adobe Reader is set as the default application for PDFs. The user also learns to navigate the print menu directly instead of using keyboard shortcuts, which ultimately resolves the printing issue.
