[Solved] Bosch WAB20264EN/16 Washing Machine - Error E16: Dealing with F16 Block & Heating Issues
GrzesiekF1 25656 6
  • #1 17541654
    GrzesiekF1
    Rate: 36
    washing machine as in topic. After turning the knob, error E16. F16 is a blocking error - I replaced and no effect, the heater was measured and it's ok. Anyone know how to deal with it?
    best regards
  • #2 17542995
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    Does the error appear after pressing start?
  • Reset procedure still unknown for this model
    #3 17543225
    GrzesiekF1
    Rate: 36
    The error appears as soon as you turn the program selector. I tried resets, from 6 o'clock and spin reduction and with start and 15 positions to the left, but they do not work ...
    edit:
    The triac controlling the blockade, I naturally checked, it was ok, but I had the same one. It seems to me that it's a matter of resetting the error, but I don't know which way is right in this model?
  • #4 17551297
    escort97
    Rate: 14
    Erasing errors: Turn the washing machine off, turn it on for 18 o'clock, hold the spin button (if the spin will not be the
  • #5 17556933
    GrzesiekF1
    Rate: 36
    Erasing in this model is even different ... But I know how ;)
    1. selector for OFF;
    2. press and hold "eco perfect" and "water plus" (first two buttons to the left of the selector);
    3. turn the selector to position 15;
    4. wait for the error to be cleared;
    Maybe someone else will be useful.
    Interestingly, the washing machine is unique, i.e. it has "wrong" buttons. To start it you do not press "start" but "water plus". The client claims that it was - I find it hard to believe. But other than that, the washing machine flashes. I do not close the topic, maybe someone will say about these crazy buttons.
  • #6 18287337
    marcin1907r
    I have a Bosch clasixx 6 washing machine and error E16 occurs. I am asking for help because from my observations it seems that this is something with the motherboard. I replaced the lock, the heater is new. So that's definitely not it. After switching on, the washing machine normally starts and starts washing until the heater switches on, everything is ok. After a while from turning on the heater error E16 pops up and when you press start again, the washing machine starts and in a few seconds sometimes the error returns. The lock holds so I don't know alone anymore. Programs without water heating continue without any problems. Help
  • #7 18302828
    marcin1907r
    Because nobody deigned to help. I will answer myself. It was cold February on the power board.
The Bosch WAB20264EN/16 washing machine is experiencing error E16, which is associated with a blocking issue (F16). The user has replaced the lock and confirmed the heater is functioning correctly, yet the error persists immediately upon turning the program selector. Various troubleshooting steps were discussed, including attempts to reset the machine. A specific reset procedure was provided: turn the selector to OFF, press and hold "eco perfect" and "water plus," then turn the selector to position 15 to clear the error. Another user suggested that the issue might be related to the motherboard, as their machine operated normally until the heater was activated, at which point the error reappeared. Ultimately, one user resolved their issue by identifying a problem with the power board.
