[Solved] BOSCH Classixx 6 Washing Machine WAA20262PL/01 - Error E3: Meaning, Causes, and Solutions
xmagdam 26490 5
  • Intermittent E3 error after completed Bosch wash
    #1 16306821
    xmagdam
    Good morning, I have an error E3 for a few weeks when I switch on the laundry. My washing machine is BOSCH Classixx 6 WAA20262PL / 01.
    The washing machine normally turns on, I can turn on the laundry, but when I finish washing, and I want to start another wash I get an error E3. The washing machine squeals from time to time, and I totally do not know what's going on. I did not notice any signs of corruption. Everything works normally, just this message .. After waiting, several attempts, the laundry finally turns on.
    Does anyone of you know what is wrong with her? What broke down? What does this error mean at all?
    I would be grateful for any help! greetings
    Piotr2608
    Help: 851
    Rate: 4487
    E3 - it looks like a problem with a door lock
    ZimTech Piotr Zimny
  • #3 16306928
    xmagdam
    Even if the door normally blocks? The error pops up, but after a few attempts the door normally locks and begins to wash
    Piotr2608
    Help: 851
    Rate: 4487
    Yes, even when they block and the door looks closed.
    ZimTech Piotr Zimny
    Bridgestone
    Help: 30
    Rate: 105
    Let the friend check if the connecting block from the blockade has come loose. If the peg is plugged in correctly, it will be necessary to replace the door lock.
  • #6 16339698
    xmagdam
    Problem has been solved. As everyone thought - the door lock did not work.
