Bosch WAB2028 Washing Machine - Flooded Water & Error E:21 Displayed: Meaning & Fix
Agata Ciernioch 7827 6
  • #1 16248183
    Agata Ciernioch
    The washing machine was flooded with water and error E: 21 is displayed all the time. What does he mean and how to fix this error?
  • #2 16248353
    electrogt
    Rate: 24
    Error E21 in Bosch washing machines usually indicates the end of the brushes on the motor.
    Please follow the instructions:
    Rotary switch to position Zero.
    Turn the dial to six o'clock.
    Then press my finger on the spin reduction button and hold for about 10s.
    After 10 s finger we do not release we turn the knob for seven o'clock, hold for 10 seconds and release the finger.
    We give the position zero.
    We turn on the washing machine and it should be ok.
    Sometimes he doesn't let go the first time.
    If the washing machine starts, set it to spin and see if the engine will go if it goes to wash.
    And if not, the motor brushes to replace
  • #3 16248494
    Agata Ciernioch
    Hello. Thank you for the message, but I was unable to start the washing machine in the way you wrote.
  • #4 16248640
    Paw_el
    Home appliances specialist
    Help: 592
    Rate: 1551
    the answer is here
    :D
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #5 16249132
    zhudomel
    Help: 1280
    Rate: 3373
    Something more? How?
  • #6 16251942
    Agata Ciernioch
    Hello sir.
    I read about fuses in the user manual, but there says that if the display indicator lights do not work during operation, then see if there was a power outage. Or if the fuses did not work, but it was during the washing machine operation. So this is not a disadvantage because the washing machine still did not work. Now I will try to apply the action which the Lord wrote to me and see if something moves. Thank you for further help.
  • #7 16269817
    tod.1977
    Help: 65
    Rate: 149
    It's best to call the service.
The Bosch WAB2028 washing machine displays error E:21, which typically indicates an issue with the motor brushes. To troubleshoot, users are advised to reset the machine by turning the rotary switch to position Zero, adjusting the dial, and pressing the spin reduction button for specific intervals. If the machine does not respond, it may require motor brush replacement. Some users reported difficulties in following the reset procedure, while others suggested contacting service professionals for assistance.
