Bosch WAN2026FPL Washing Machine: Error E20, Heater NTC, Hydrostat & Module Replacement Options
phiter 15540 5
  • Suspected control module fault causing E20 error
    #1 16903143
    phiter
    Level 19  
    Help: 33
    Rate: 188
    Hello, I have a problem with the Bosch WAN2026FPL washing machine (one-year hardware, but no warranty). Immediately after turning the knob, the E20 error crashes, an error related to heating, but I checked everything, I changed the heater NTC also (with Bosch Maxx) analog hydrostat. I have no way to check the engine (the engine is the size of a massacre fist), the module shows no signs of damage, but I suspect that it will be replaced.
    Anyone have any idea? please help, possibly where can I find this module because I can't track it. Greetings.
    Bosch WAN2026FPL Washing Machine: Error E20, Heater NTC, Hydrostat & Module Replacement Options Bosch WAN2026FPL Washing Machine: Error E20, Heater NTC, Hydrostat & Module Replacement Options
  • #2 16903199
    mrhari
    Help: 835
    Rate: 3239
    The heater relay is not stuck together?
    E20 also means that the heater heats up, although it should not.
  • Suspected LD33A triac on heater module
    #3 16903258
    phiter
    Level 19  
    Help: 33
    Rate: 188
    There is no voltage on the heater even for a moment, the relays are checked ... After applying voltage to the module, the relay marked in red turns on immediately and then an error pops up, the relays from the heater are green, they are not stuck together. There is one suspicious element, it is distorted - triac or (transistor?) With the designation LD33A , I do not know how to check it (the meter has a short circuit between two legs), I cannot find one for comparison or documentation.
  • #4 16903463
    Piotr2608
    Help: 851
    Rate: 4487
    LD33A = LD1117AS33TR is a 3.3V 1.2A SOT223 stabilizer
    Error E20 in this washing machine is a fatal error Fatal Error - damaged heater, heater relay.
    Be sure to follow the service procedure when replacing damaged components.
    ZimTech Piotr Zimny
  • #5 16903551
    phiter
    Level 19  
    Help: 33
    Rate: 188
    Thank you, or maybe a friend tell me what this procedure is about? Erasing the error, i.e. the knob at 6 o'clock and the spin button I have already practiced, is there anything else?
  • #6 17163684
    abuhamza
    Home appliances specialist
    Help: 383
    Rate: 1032
    Worst Bosch module in years, I guess :P I do not know any service procedures when replacing the heater or contactor and everything works, probably some myth. Unless the module is blocked after the brushes run out, and that's probably a myth ..
    Check the heater for leakage and then take the contactor.
