[Solved] Samsung UE65NU8002 vs SONY KD65XF8505: Which 65-inch TV (5000-5500 PLN) is Worth Buying?
R3tmax 3264 9
Which 65-inch TV should I buy in the 5000–5500 PLN range: Samsung UE65NU8002 or Sony KD65XF8505?
Samsung UE65NU8002 is the better pick here, and that is the model the advisor would choose [#17581030] Samsung uses a VA panel while Sony uses IPS; IPS gives better side viewing angles, but VA gives better blacks, especially for evening viewing, so if Samsung’s viewing angles are enough, it is the safer choice [#17580921][#17580965] Both models were described as good mid-range TVs with 120 Hz panels, good motion processing, and solid smart TV features [#17580965] At this price, no clearly better 65-inch alternative was seen [#17580998]
  • #1 17580803
    R3tmax
    I am thinking of buying a 65 inch TV (5000-5500 PLN) and two models caught my eye:
    Samsung UE65NU8002 and SONY KD65XF8505
    Help which model is worth buying because in one store they say SONY and in another that Samsung :) and I don't know.
    Thank you for your help.
    best regards
  • #2 17580921
    Ludwik XVI
    Help: 1325
    Rate: 788
    Samsung is VA, Sony is IPS.
    Answer the questions from my signature ... we will choose which one is better for you.
  • #3 17580943
    R3tmax
    1. How far are you sitting from the TV screen? 5-7m
    2. Are you sitting in front of the screen or sideways to the screen? straight and sideways
    3. What TV do you currently have? Samsung
    4. What brand do you prefer? it doesn't matter, there must be a good TV
    5. What size TV are you looking for? 65cali
    6. What signal and devices will be connected to the TV? NC +
    7. What kind of programs do you watch most often? all
    8. Will you play games, and if so on a console or a PC? no
    9. Will you actively use the TV's SMART system? occasionally
    10. Do you watch in the evenings or during the day? day and night
    11. How much money can you spend on buying a TV? 5000-5500
  • #4 17580965
    Ludwik XVI
    Help: 1325
    Rate: 788
    Points 2 and 10 are key because IPS has better side angles but worse black at evening viewing.
    So if you assume that the VA side matrix katy is enough, it's better to take Samsung.
    Both tvs are medium shelf on good 120Hz matrixes, with good fluidization systems and efficient smart TV.
  • #5 17580981
    R3tmax
    Can you buy something better at this price?
    Added after 6 [minutes]:
    Can you recommend something really good for PLN 5000-6000 ??????????
  • #6 17580998
    Ludwik XVI
    Help: 1325
    Rate: 788
    Both of these are really good.
    Rather, I don't see better 65-inch models at this price ....
  • #7 17581014
    R3tmax
    This is the last question !!!!
    Which TV would Louis XVI choose ?????????? :)
  • #8 17581030
    Ludwik XVI
    Help: 1325
    Rate: 788
    Samsung UE65NU8002
  • #9 17581047
    R3tmax
    I bet on Samsung too.
    Thank you for your help :)
    best regards
  • #10 17581194
    R3tmax
    best regards
    Added after 1 [hours] 10 [minutes]:
    I solved the problem by talking to the moderator Louis XVI.
    best regards
The discussion revolves around choosing between two 65-inch TVs: the Samsung UE65NU8002 and the Sony KD65XF8505, both priced between 5000-5500 PLN. Key considerations include viewing distance (5-7m), seating angles (straight and sideways), and usage patterns (day and night). The Samsung model features a VA panel, which is better for dark scenes, while the Sony has an IPS panel, offering superior viewing angles but poorer black levels in low light. Participants generally favor the Samsung UE65NU8002 for its performance, especially in evening viewing conditions. The consensus is that both models are solid choices, but the Samsung is preferred for its better black levels and overall value.
