Samsung UE50J6240: TVP VOD Connection Error & Recommended Adapter/Box for Non-Smart TV
jara200 10119 6
  • #1 17586701
    jara200
    Hello, I have two quick questions. I have a Samsung UE50J6240 and there is a problem with tvp vod. The application lands in a moment, a connection error pops up (previously it works without a problem) what could be the reason?
    2 I have a Samsung at home without a smart. I plan to buy an adapter or a box so that I can use neta.co do you suggest ?? thanks in advance for the answer. Regards
  • #2 17589621
    sebii20
    Hi
    I have the same problem with vod tvp. For about a week, connection error. Other applications are working fine. I wrote to samsung, but they will probably have it in d.
  • #3 17589862
    jara200
    Hi. Exactly the problem has been appearing for a week now. What's your TV model? I did a reset of the settings and nothing, a friend on the same model, the same. Give me if they write back to you. I wonder how it is on LG or Sony,
  • #4 17601687
    thero86
    Rate: 8
    In general, on most 2-year-old TVs there is currently this problem, something samsung mixed up in the topic because on the second LG TV with smart everything flashes
  • #5 17602375
    jara200
    i called samsung and got a reply like engineers know about the problem and they are working on it, please be patient.
  • #6 18412684
    zombek301
    Rate: 63
    Everything was fine for me. Even though I bought the TV in 2012.
    And from the month of d.pa?
    When I try to turn on any of the programs, such a message pops up.
    Updating the software did not help.
  • #7 18412739
    sosarek
    Help: 9320
    Rate: 15527
    And it won't help, no manufacturer support.
    Purchase a separate Android Box.
    Z
    Pka, Poznań, 60-850
✨ The discussion revolves around connection errors with the TVP VOD application on the Samsung UE50J6240, which has been reported by multiple users over the past week. Users have noted that while other applications function correctly, the TVP VOD app fails to connect, suggesting a potential issue with Samsung's software. Samsung has acknowledged the problem and is reportedly working on a fix. Additionally, users are seeking recommendations for adapters or boxes to enable streaming on non-smart Samsung TVs, with suggestions leaning towards purchasing a separate Android box for better compatibility with streaming services.
