Connecting VCR to Samsung UE22ES5000W TV: Step-by-Step Guide for Old Video Playback
krzysztof kulma 96207 20
How do I connect an old VCR to a Samsung UE22ES5000W TV, and which TV socket should I use?
Connect the VCR to the TV with either a SCART/Euro cable if both devices have SCART, or with cinch (RCA) cables to the composite input. The most specific wiring given is: VCR video out to the TV’s Y/VIDEO input and VCR audio out to the TV’s Audio L input [#13859424] [#13861184] After that, open the TV Input Source menu and select the Composite/AV input [#13861184] [#13861249] If you still get no picture or sound, check that the cable is plugged into the correct outputs/inputs and that the VCR itself is working; dirty heads or a faulty socket were also suggested as possible causes [#13861235] [#13861432]
  • #1 13859134
    krzysztof kulma
    Rate: 45
    I have a problem with the VCR, I do not know how to connect it to the Samsung UE22ES5000W TV. I need help where to connect the cable. Old VCR and new TV. Hope to get a reply soon.
  • #2 13859216
    adam158
    Help: 36
    Rate: 232
    What connectors in the video, what to write on the TV or, preferably, give a photo.
  • #3 13859219
    Colina2
    Help: 10
    Rate: 101
    The VCR probably has an antenna output and an antenna input. Connect the antenna to the input and the TV antenna input to the output. Ew look for cinch outputs and connect with them. I can see the TV set with such inputs.
  • #4 13859424
    chisel
    Help: 102
    Rate: 171
    Via SCART socket with EURO-EURO cable.
  • #5 13860392
    krzysztof kulma
    Rate: 45
    I'll take a picture well
  • #6 13860474
    _PREDATOR_
    Help: 1864
    Rate: 2315
    I remind you statute :
    3.3. The user is obliged to immediately follow the moderator's instructions.
    :arrow: https://www.elektroda.pl/rtvforum/topic2877904.html#13859134
    ELMAX
    Małe Przedmieście 20/4, Olesno, 46-300 | Tel.: 535 XXX XXX (Show) | Company Website: http://ftp.interka.pl/~elmax/about.php
  • #7 13861047
    krzysztof kulma
    Rate: 45
    TV set :
    - 1 audio input:
    a) -R
    b) -L
    - 1 input Pr
    - 1 Pb input
    - 1 Y / VIDEO input
    - 1 HDMI / DVI IN
    - 1 PC IN
    - antenna
    - DVD cable
    - 1 USB input
    - one common interface entry
    - 1 input on Digital Audio out (optical)
    VCR (video):
    - audio:
    a) in
    b) out
    - video:
    a) in
    b) out
    - RF in
    - RF out
  • #8 13861064
    Colina2
    Help: 10
    Rate: 101
    Well, connect it with either an antenna connector or cinch (audio and video connectors)
  • #9 13861077
    krzysztof kulma
    Rate: 45
    but where what
    Added after 1 [seconds]:
    but where what
  • #10 13861143
    Colina2
    Help: 10
    Rate: 101
    I have already written before. Aerial output from the VCR to the aerial input of the TV.
    Ev. insert a picture of the VCR connectors.
  • #11 13861151
    adam158
    Help: 36
    Rate: 232
    I wrote to you above, give photos if you don't get it, there are already 15 posts and nothing else.
  • #12 13861184
    Polon_us
    Help: 1184
    Rate: 1280
    Pictures of course would be useful, but the description of the sockets is quite obvious, except for the "DVD cable". I can't figure it out :(
    The description clearly shows that the VCR has a Composite + Audio mono input / output. Actually, a bit older.
    You can use the Component input sockets for connection - from the description you can see that these sockets can be switched to Composite mode.
    Also my friend Krzysztof Kulma:
    VCR Video Out -> 1 Y / VIDEO input (TV)
    VCR Audio Out -> Audio L input (TV)
    Make the connections with CINCH cables.
    After connecting on the TV, in the Input Source menu, please find the Composite input and select it.
    Good luck :)
  • #13 13861188
    krzysztof kulma
    Rate: 45
    there's nothing on any channel, on one thing, something waving and disappearing all the time
    Thank you for your answer
    Added after 5 [minutes]:
    there is no picture or sound
  • #14 13861235
    Polon_us
    Help: 1184
    Rate: 1280
    I hope a colleague turned on some cassette to check this VCR.
    And he chose the Composite input correctly.
    This "DVD cable" is what kind of cable? My guess is that it's probably Scart from the TV side. And what are the plugs on the DVD side?
    Also bear in mind that if this is an old VCR it may be out of order. Or with very dirty heads.
  • #15 13861249
    krzysztof kulma
    Rate: 45
    so shows AV connection and no signal or weak signal
  • #16 13861432
    Polon_us
    Help: 1184
    Rate: 1280
    Well, I do not know if my friend will have any consolation from this VCR.
    I would suggest a thorough cleaning according to the rules of the art.
    For peace of mind, please also check the connection on the other CINCH cables. Just in case.
    Good luck :)
  • #17 13861454
    _PREDATOR_
    Help: 1864
    Rate: 2315
    I see you don't care ... moderators' comments!
    How do we start and finish a sentence?
    Please correct all your posts!
    :evil:
    ELMAX
  • #18 13861702
    KOCUREK1970
    Help: 3860
    Rate: 5488
    These are two possibilities:
    - damaged VCR at the outputs where you connected the cables,
    - user fault when connecting the VCR to the TV.
    Give photos of what, how, with what and where you connected, because so far we know so much that you don't know anything!
  • SCART connection records audio but no video on LG VCR
    #19 16431818
    dexiu89
    Rate: 9
    Hello. I have a problem with the correct connection of the VCR and TV. The point is that for me this configuration allows for recording and playback, while in my case, using the same connection (I will explain in a moment), the VCR only plays back, i.e. displays the image from the cassette. The problem is that the video is not recorded on the cassette, but the sound. Connection with euro video> tv. What causes it to not download the picture to the VCR? Samsung TV, LG VCR. After all, this is a universal in / out connection and I do not understand why only voice is recorded. When I turn on playback, the picture from the cassette is played, because it is visible, but it is black. You can see, because if there is a bend in the tape, the strip passes.
  • SCART connection records audio but not video
    #20 16431841
  • #21 16432642
    dexiu89
    Rate: 9
    I'm sorry, but when you do everything at once, it's hard not to omit details. What archeology again, if I wrote back as in the subject and in my opinion it is binding. Samsung UE32J5000 TV, LG V280 VCR and LG LH-C 360 SE. One of my colleagues from this forum sent me a reply via e-mail, so thank you for the friendly atmosphere. The fault was on the TV side - damaged SCART socket.
The discussion revolves around connecting an old VCR to a Samsung UE22ES5000W TV. Users suggest various connection methods, including using the antenna output/input, cinch (RCA) cables, and SCART connections. The VCR typically has RF in/out and audio/video in/out ports. Users emphasize the importance of selecting the correct input source on the TV and ensuring the VCR is functioning properly, as issues like no signal or weak signal may arise. Some users also mention the need for cleaning the VCR heads and checking cable connections. A follow-up query highlights a related issue with a different setup involving an LG VCR and Samsung TV, where only audio is recorded, indicating potential problems with the SCART socket.
