Amica ZIM 646 E Dishwasher: Fixing Error E1, Water Intake Issue & Aquastop Valve Solutions
RafiiWB 39921 8
  • #1 17595810
    RafiiWB
    Rate: 13
    Hi.
    I have a problem with the Amica ZIM 646 E dishwasher. Error E1 is displayed. When I select the program, I can't hear the dishwasher taking water and after two or three minutes it crashes the E1 error. I connected the Aquastop valve briefly and it works. Any suggestions?
  • #2 17596221
  • #3 17596280
    RafiiWB
    Rate: 13
    I checked the correct operation of the aquastop by briefly connecting it to 230v and to the water connection. When he got 230v, the water started to fly, so I exclude damage to the aquastop. Except that immediately after selecting the program in the dishwasher, it should first pump out the water, I didn't think and indeed as if the problem was starting here because I can't hear anything ...
  • #4 17596304
  • #5 17596511
    RafiiWB
    Rate: 13
    Unfortunately, the dishwasher started working. First she started pumping out the water and that wasn't there before when the dishwasher stopped working
  • #6 17637514
    Radauskas
    Rate: 14
    I have Amica, three years ago I replaced the solenoid valve (for a new one). And for two days I get the message "no water intake". Everything would indicate the same problem again, but this solenoid is "alive". Every time you turn on the dishwasher, you hear a ticking sound and then a buzzing sound. After turning off the dishwasher, the ticking and humming stops again. Is it possible to damage the valve in such a way that it is electrically "alive" and does not let the water out?
  • #7 17637695
    RafiiWB
    Rate: 13
    See if the valve gets an impulse from the short circuit. The relay on the motherboard may have failed. That was my case. 4 relays out of 7 and the integrated circuit controlling them have failed. The repair cost me PLN 26 :)
  • #8 17637847
    Radauskas
    Rate: 14
    Well, he definitely gets some impulse because he "ticks" and hums. And it makes me wonder if he can show signs of life and still not let the water out.
  • #9 17637891
    Kenworth 18
    Help: 2415
    Rate: 3702
    Usually, when the solenoid valve is damaged, it lets water in despite a functioning coil, but it also happens that due to calcification it may not open and the water will not let out.
✨ The discussion revolves around troubleshooting the Amica ZIM 646 E dishwasher, specifically addressing the E1 error, which indicates a water intake issue. Users suggest that the error may stem from insufficient water pressure or a malfunctioning flow meter. The Aquastop valve was tested and found functional, leading to further investigation of the dishwasher's internal components. One user noted that the dishwasher initially pumps out water, which was not observed previously. Another user shared their experience with a solenoid valve replacement and similar symptoms, indicating potential electrical issues with the relay on the motherboard. The conversation highlights the importance of checking for voltage at the valve and the possibility of calcification affecting water flow.
