Dishwasher Amica ZIM446E: Error E1, Continuous Water Pumping, No Flooding Traces
a77rt 15306 9
  • #1 16337995
    a77rt
    Hey!
    I have a problem with the Amica ZIM446E dishwasher.
    All the time pumping out the water, after a while after turning on the error E1 appears.
    After unscrewing, no traces of flooding are visible. All clean pumps, hoses on site.
  • #2 16338166
  • #3 16338412
    a77rt
    Can you check the solenoid? Measure with a gauge or something (before I exchange it)?
  • #4 16339063
  • #5 16341502
    a77rt
    And there is a break. :(
  • #6 16408455
    a77rt
    CD ....
    After a month, AMICA has provided a hose but unfortunately it is a replacement and I do not know how to connect it.
    It differs from the original in principle. Namely, there is no wires coming from the coil ... :( The entire Aquastop system is enclosed in a casing at the valve.
    you can somehow get around it or better to return the wire and look for a new dishwasher ??
  • #7 16408765
  • #8 16409021
    a77rt
    It is not so bad - I hope. There are simply no wires. in addition, the new one on the dishwasher side is ended with a nut.
    The replacement part symbol 1017042
  • #10 16438291
    a77rt
    And it's ok
    I pay special attention when clamping the hose with a hose clamp so that the tank entrance does not break.
✨ The Amica ZIM446E dishwasher is experiencing an E1 error and continuous water pumping without visible flooding. Users suggest that the issue may stem from a faulty Aquastop valve, specifically a break in the coil. Recommendations include checking the solenoid for resistance (3.5k - 4k) and ensuring proper connection of the replacement hose, which may differ from the original. There are concerns about compatibility with replacement parts, and users discuss the need for specific part numbers to resolve the issue effectively.
