Problem Logging In to Portal on LG TV: No Error Message, Works on Other Devices
gwiazdka130 7176 3
  • #1 17612181
    gwiazdka130
    I have a problem with logging in to the portal on LG TV I will add that on other devices there is no problem and logs in normally. After entering login and password nothing happens, no message pops up. Does anyone know what can be the reason? I tried to set up a new account but the situation is the same. Thank you in advance for your help with the solution
  • #2 17783548
    leon600v
    Hello, I will not help but report that I have the same problem.
    The vip account has been bought out and nothing has now started to pop up the pictures "prove you are not a robot"
    As you enter, only the new image pops up.
    Some 2 | 3 months ago I logged in normally and here is the end.
    Tv is: LG webOS TV UJ6517
  • #3 17830697
    malykazio
    Rate: 33
    Hello. Has someone solved the problem? I have this problem with the "robot" in the same wheel. LG TV
  • #4 17956542
    malykazio
    Rate: 33
    It helped to turn off the individual mode in the browser.
