It is not possible to run the smart TV application on the LG 42lb650v TV
abramsio 51474 6
  • #1 17331830
    abramsio
    Rate: 9
    On LG 42lb650v I am not able to run any application under smart TV. The TV has the latest soft software installed from the manufacturer, is connected to the internet (the built-in web browser works nice). Lg store, youtube, netflix everything is supposed to be but I do not want to connect. After clicking on the app, he tries to connect for a while and then returns to displaying the TV picture. The TV has its years but it is working. The smart function has not been used before (TV used by an elderly person). Generally, I have no idea what might be wrong. Greetings and thanks in advance for your help.
  • #3 17335884
    abramsio
    Rate: 9
    Thanks for the hint :) Problem solved. It turned out to be trivial. There were no consents to the regulations and use of the application.
  • #4 17868804
    Rudi241
    Rate: 81
    Hello and where do you need to agree?
  • #5 19109632
    Brysia
    Rate: 21
    Anyone already know where these consents are?
  • #6 19109876
    E8600
    Help: 529
    Rate: 2518
    They are hidden in the advanced TV menu (this menu on the left side of the screen should be in a tab).
  • #7 19444438
    Sylwiaaa80
    Rate: 8
    Hello, is there anyone who can help me, I have no idea what's going on ok Everything was fine until there was some update It is not possible to run the smart TV application on the LG 42lb650v TV
✨ The user experienced issues running smart TV applications on the LG 42LB650V, despite having the latest software and a functional internet connection. After troubleshooting, it was discovered that the problem stemmed from not agreeing to the application usage regulations. Other users inquired about the location of these consent settings, which were identified as being hidden in the advanced TV menu.
