[Solved] Boot Mode Options: Understanding Legacy + UEFI, Differences Between BIOS & UEFI Modes
ELPutinooo 42684 3
  • #1 17685806
    ELPutinooo
    As in the subject. Which gives the Legacy + Uefi option. How is it different from booting, for example in the mode with only Bios or only Uefi?
  • #2 17685898
    adamegah
    Help: 39
    Rate: 92
    Enables automatic mode selection, please refer to the disc manual for details.
  • #3 17685931
    dt1
    Admin of Computers group
    Help: 7318
    Rate: 8296
    In BIOS + Legacy mode, you can set the boot order using media compatible with both options. If you set booting only from UEFI-compatible devices - only such devices will be visible on the list when setting the order of devices (despite the presence of devices that can be booted in legacy mode - they will not be available). The other way around is the same.
  • #4 17686136
    ELPutinooo
    Thanks a lot for the explanation.
