Connecting Bluedio T5 Bluetooth Headphones to PC: Seeking Suitable USB Adapter Suggestions
Merf 16467 12
What Bluetooth USB adapter should I use to connect Bluedio T5 headphones to a PC without built-in Bluetooth?
Use a Bluetooth USB adapter that is at least CSR 4.0 and supports the A2DP profile; the headphone manual specifically recommends that for pairing or audio-lag issues [#17771656] One suggested model in the thread is the ASUS BT400 Bluetooth 4.0 USB Nano Class II, which supports A2DP and Bluetooth 4.0 [#17772276] However, another reply notes that the adapter you already have appears to meet those requirements, so the problem may be Windows pairing/configuration rather than the adapter itself [#17772354]
  • #1 17771646
    Merf
    I have Bluedio T5 bluetooth headphones and would like to connect them using a PC adapter that does not have bluetooth. I have already tried two USB adapters, but neither of them wanted to connect my headphones to the PC. What adapter would be the right one to transfer the sound from the PC to the headphones?
  • #2 17771656
    Robert B
    Help: 2027
    Rate: 1412
    Have you read the manual for your own equipment?
    https://satysfakcja.stati.pl/allegro_new/RTV/audio/Bluedio/T5BLK/T5.pdf
    If your headphones have compatibility issues (audio lag, pairing problem) with your laptop or desktop, please use the included audio cable to connect or buy bluetooth adapter in minimum version CSR4.0 and support for A2DP profile.
  • #5 17772354
    badboy84
    Help: 1197
    Rate: 1486
    The adapter you have meets the requirements, so the question is why can't you pair them?
    Have you entered pairing mode on your headphones? What's your system? The drivers are installed?
  • #6 17772425
    Merf
    Yes, the headphones are in pairing mode, windows 10. The headphones are visible in bluetooth devices, but it is not possible to pair them. The drivers are also okay, at least the system says. I will add that the headphones work without a problem with the phone.
    Brozerihno, maybe I would buy this adapter, but I would like to be sure that it will work at 100%. Looking at the properties, mine also has A2DP + V4.0, and yet it creates problems ...
  • #7 17772432
    badboy84
    Help: 1197
    Rate: 1486
    Why is it failing? Are we going to pull you by the tongue for everything?
    With this approach, you can buy 100 more adapters and you won't connect to any of them.
  • #8 17772440
    Merf
    I'll be home in the evening and I'll throw in some screenshots. This is it? I don't know what else to add :cry: . If I were the only one who knew why it was failing ...
    Added after 4 [hours] 1 [minutes]:
    And this is what it looks like. When I click "Connect" in the headphones, I hear the message: "Ready to pair" but nothing happens, the sound still comes from the speakers. Anything else you should do?
  • #9 17776481
    Merf
    Can someone else suggest a solution?
  • #10 17778711
    LED5W
    Help: 264
    Rate: 162
    Check if you have these headphones in your sound settings. If so, set as default.
  • #11 17778839
    Merf
    I only have something like this in the sound settings.
    Added after 5 [minutes]:
    When I go to the sound control panel, I have something like this:
    Added after 19 [hours] 42 [minutes]:
    I can not set them as default because they are just not connected in the settings. :|
  • Suggesting re-pairing and driver checks
    #12 17783526
    LED5W
    Help: 264
    Rate: 162
    Try to remove the partnership with Windows, shut down the system, turn off Bluetooth in other devices with which the headphones talked, pair again. Check the device manager for any warnings. If it doesn't help, write here https://bluedio.audio/kontakt/ Did you get some software for this adapter, did you install it? I also found such a topic https://answers.microsoft.com/en-us/windows/f...pairiing/66f8e970-9be8-43be-8fcc-de108b6929aa
  • #13 17785866
    Merf
    I uninstalled the adapter, the headphones themselves too, and now this problem has appeared. Well, after reconnecting the adapter, the system does not download any drivers immediately bluetooth is available, which seems a bit strange to me. But with the headphones the same problem continues, and even differently, because when I remove them from the devices and then search and add then I click "Connect" and the sound in the speakers disappears and the headphones begin to "hum".
The discussion revolves around connecting Bluedio T5 Bluetooth headphones to a PC using a USB Bluetooth adapter. The user has attempted to pair the headphones with two different adapters but has faced connectivity issues. Suggestions include checking the headphone's pairing mode, ensuring the correct drivers are installed, and verifying sound settings on Windows 10. A recommended adapter is the ASUS BT400 Bluetooth 4.0 USB Nano, which supports A2DP. The user is encouraged to troubleshoot by removing existing Bluetooth pairings, checking device manager for warnings, and ensuring no other devices are interfering with the connection. Despite these efforts, the user continues to experience problems with the headphones not being recognized as connected in the sound settings.
TL;DR: For Windows 10 PCs pairing Bluedio T5, use a Bluetooth 4.0 A2DP USB dongle; ASUS USB‑BT400 is “Bluetooth Smart Ready” and reaches up to 10 meters. [ASUS USB-BT400 product page]
Why it matters: It helps you avoid pairing loops and the “connected but no sound” problem on PCs without built‑in Bluetooth.
Quick-Facts
  • Bluedio advises using a CSR 4.0 adapter with A2DP if pairing or lag occurs. [Elektroda, Robert B, post #17771656]
  • ASUS USB‑BT400: BT 4.0 (LE), up to 10 m range, up to 3 Mbps, A2DP profile support. [ASUS USB-BT400 product page]
  • After pairing, set the headphones as Default in Windows Sound to route audio. [Elektroda, LED5W, post #17778711]
  • If pairing fails, remove the device, disable other paired sources, re‑pair, and check Device Manager. [Elektroda, LED5W, post #17783526]
  • Use A2DP for stereo music; HFP/HSP is for calls with mono audio. ["Supported Bluetooth profiles in Windows"]
Which USB Bluetooth adapter works best with Bluedio T5 on a PC?
Choose a Bluetooth 4.0 adapter that supports A2DP. The T5 instructions recommend CSR 4.0 with A2DP for reliable pairing. Models meeting that spec, like ASUS USB‑BT400, are common and inexpensive. Prioritize the spec; the brand is secondary for audio streaming. [Elektroda, Robert B, post #17771656]
How do I fix Windows 10 showing “Ready to pair” but it never connects?
Remove the headphones in Bluetooth settings, then re‑add them. Put the T5 in pairing mode before clicking Add device. If it still fails, restart the PC and check for Bluetooth driver updates. 1. Remove device 2. Enter pairing mode 3. Add device again. ["Fix Bluetooth problems in Windows"]
After pairing, there’s no sound—how do I set the T5 as default output?
Open Settings > System > Sound. Select Output and choose your Bluedio “Headphones (Stereo)”. For classic panel, open Sound Control Panel. On Playback, right‑click the headphones and set as Default Device. This routes all audio to the T5 automatically. ["Change sound settings in Windows"]
Why do I see both “Headphones” and “Headset” entries, and which should I use?
Windows exposes two profiles. A2DP is “Headphones” for stereo music. HFP/HSP is “Headset” for calls and is mono with mic. Pick “Headphones” for music and videos. Switch to “Headset” only when you need the microphone for calls. ["Supported Bluetooth profiles in Windows"]
Do I need a CSR chipset specifically for Bluedio T5?
Follow the vendor guidance: “buy bluetooth adapter in minimum version CSR4.0 and support for A2DP profile.” This ensures stereo audio and stable pairing with PCs. It matches the headphones’ documented compatibility advice for computers. [Elektroda, Robert B, post #17771656]
Windows sees the T5 but won’t connect—what driver steps help?
Install the latest driver for your Bluetooth dongle, or let Windows use its built‑in stack. Remove and re‑add the headphones. Then check Device Manager for any warning icons and resolve driver issues before pairing again. ["Fix Bluetooth problems in Windows"]
Can the ASUS USB‑BT400 solve this, and what specs does it offer?
USB‑BT400 is a BT 4.0 (LE) nano dongle with up to 3 Mbps EDR and up to 10 m range. It’s backward compatible with older Bluetooth versions and lists common audio profiles like A2DP. It’s a compact, stable pick for PCs. [ASUS USB-BT400 product page]
The T5 connects but hums or sounds thin—what should I change?
Select the “Headphones” (A2DP) playback device in Sound settings. The “Headset” profile uses narrowband mono audio for calls. Choosing the A2DP endpoint restores full‑band stereo for music and video. Avoid the “Headset” endpoint during media playback. ["Supported Bluetooth profiles in Windows"]
How far can I sit from the PC with a nano dongle?
With an adapter like USB‑BT400, expect up to 10 meters line‑of‑sight. Keep the dongle unobstructed for best results. Move closer if audio drops or stutters. This matches Class II performance targets for compact adapters. [ASUS USB-BT400 product page]
My T5 is paired to my phone—can that block PC pairing?
Yes. If the headphones auto‑connect to another device, the PC pairing fails. Turn off Bluetooth on other paired devices. Remove old pairings and then pair the headphones with the PC again. ["Fix Bluetooth problems in Windows"]
Windows installed the Bluetooth driver automatically. Is that normal?
Yes. After you add a Bluetooth device, Windows sets it up automatically. You can install the manufacturer’s driver if features or profiles seem missing. This is the expected behavior on Windows 10. ["Connect a Bluetooth device in Windows"]
Bluetooth still won’t cooperate—can I just use the cable?
Yes. The T5 documentation suggests using the included audio cable when you have pairing issues or audio lag on computers. This bypasses the Bluetooth stack entirely and restores immediate sound. [Elektroda, Robert B, post #17771656]
