GTX1070 ZOTAC Graphics Card Issues: Warning about Excavator-Origin & Damaged Cards!
misterbociek 13575 41
Are used graphics cards from mining rigs necessarily worn out or unreliable?
No—cards from mining rigs are not automatically worn out; in this thread the real issue was a dishonest seller who sent visibly damaged hardware, while the general rule is to treat any used GPU as a lottery and check its actual condition first [#17817891] [#17818892] Miners usually run cards with reduced clocks/voltages and often stronger fan use, so the fans are the parts most likely to show wear or noise, not the silicon itself [#17820858] [#17828654] Before buying, check whether the card has been modified and whether it still has a warranty, because an undisclosed modified BIOS or mismatched description is a problem [#17818892] [#17831077] If the card is clean, unmodified, and tests properly, many users report that mining history alone does not mean it will fail soon [#17821229] [#17828654]
  • #1 17817774
    misterbociek
    Help: 40
    Rate: 120
    Hello!
    Recently, I decided to buy a better graphics card, namely the GTX1070. I searched the ads and found the GTX1070 ZOTAC for PLN 1300, working with a guarantee - I bought it. The card comes, the packaging, the warranty is all right, I put it in the computer and it turns out that one of the fans is damaged ... I call the seller, first I don't say anything but ask if the card has been tested and he says that the card is tested and is working. Then I said that the card was damaged and I demanded a refund, After a short discussion, he said that he had another card because they were cards from excavators ... Okay, I agreed, I sent the old one back and he sent me another, also defective ... the backplate was loose and one fell out, the card was not usable because it was bent in the PC slot and the screws do not screw in because you need to remove the cooling and after the warranty.
    I sent the card back and he has nothing to complain about! He tightened the screw in 15 seconds! He tightened interesting how it is impossible without removing the heat sink ... I put a negative on the allegro because the cards were damaged and he "the cards are operational, he tightened the screw in a few seconds", and he forgot about the fan.
    Then I bought a GTX 1070 MSI and it starts again .... Fan bearings in agony, they squeak until the ears hurt .... I sent back and sent another similar .... I gave it up and ordered the bearings and I will repair it ....
    So I advise you to think twice ...
  • #2 17817805
    Robert B
    Help: 2027
    Rate: 1412
    Fans or screws are half the trouble. They're going to give you marbles under the GPU in a moment and you'll be crying.
  • #3 17817852
    2konrafal1993
    Help: 581
    Rate: 746
    Recently, there was a business master on YT who recommended buying cards from excavators because they are cheaper, I wrote a comment that these cards will fall quickly and are exhausted to the limit in the comment I warned everyone willing to buy cards from excavators in response I got comments that were at least offensive to me So I started to defend myself and I was throwing the facts, why I think so, and surprisingly the hate towards me stopped, but some people do not realize that they give, say, PLN 1300 for something that will fall within a few months or will work. I do not consider myself a mentor in the field of computer science, but if I know something, I prefer to warn someone against the fact that by saving PLN 200 - 300 he will hurt himself and will complain about everyone, I learn from mistakes not only my own and I do not recommend a used graphics card to anyone. It's just a lottery, and even new rtx cards had technical problems, why can't it turn out that something relatively new on the market will not reveal its flaws in half a year or maybe a year? Make your post misterbociek proof that savings don't always pay off.
  • #4 17817891
  • #5 17817908
    SP5IT
    Help: 1295
    Rate: 1670
    If the card is under warranty, what to worry about?
    M.
  • #6 17817912
    misterbociek
    Help: 40
    Rate: 120
    Kraniec_Internetów wrote:
    I wonder how. Usually cards in excavators run at reduced timings
    hahahahahaha :lol: I can already see it when they buy a MSI gaminX card that can be easily turned up to 2000Mhz and they break it to 1300MHz hahahhaha
  • #7 17817934
  • #8 17818168
    rzymo
    Help: 206
    Rate: 322
    Core yes, but you forgot about memories - they often spin as long as you can :) And the memories are falling - I have 2 Radeons at home, serving as spare gpu 'to the desktop', because even firing a jutub are artifacts (even lowering the memory clock does not help anymore).
  • #9 17818205
  • #10 17818343
    Robert B
    Help: 2027
    Rate: 1412
    Who at all he invented such stupidity as graphics cards that wear out.
    Oh ... technician, you still don't know much. In the now fashionable February " Pb free "degradation from elevated temperature is faster than in the old ones with an admixture of lead.
  • #11 17818347
  • #12 17818350
    Robert B
    Help: 2027
    Rate: 1412
    I edited the post. Look up.
  • #13 17818360
  • #14 17818369
    rzymo
    Help: 206
    Rate: 322
    I don't know anything about filming memory, although it sounds logical. Just note that the memories do not fall from too high clock speed, but from degradation due to high voltage.
    Only the memory voltage cannot be moved without physically modifying the card. So after all, this high clock speed and / or temperatures must have an effect and they are doing the bone a disservice ...
  • #15 17818370
    Robert B
    Help: 2027
    Rate: 1412
    And since when do the old 10-year cards work in excavators? :lol:
    Robert B wrote:
    In the now fashionable "Pb free" solders degradation from elevated temperature it proceeds faster than in the old ones with an admixture of lead.
    Yes it's true. However, what does this have to do with excavators? No. It is because of a kind of solder that the new cards will last for less than the old ten years,
    You're contradicting yourself.
  • #16 17818371
    2konrafal1993
    Help: 581
    Rate: 746
    Who ever invented such stupidity as graphics cards wear out. The hard drive, fan, SSD can wear out, you can also say that they wear out, although in practice they are simply less durable, and then this @ 2konrafal1993 duplicates them on the Internet without knowing what he is writing about.
    The balls under the systems degrade, which breaks the connection between the system and the laminate, the degradation process is accelerated with increasing temperature, and I have never mentioned the consumption of silicon anywhere. In the excavator, the card works 24 hours a day, and let's take into account that there is an increased temperature on the GPU, which means that these balls are already to some extent more or less degraded. I have never said anywhere that I should not buy cards only from excavators, but in general used cards, a used card, the more of an unknown origin, is a waste of time and money, not to mention nerves.
  • #17 17818373
    Robert B
    Help: 2027
    Rate: 1412
    Of course, but the future engineer slept in chemistry and physics classes :)
    Reading:
    https://webcache.googleusercontent.com/search...-taki-sprzet-kasa-w-bloto-istna-plaga-awarii- and-nobody-about-this-is-6034778234426497a
    The reason is poor strength of lead-free alloys which as a result of micro-stresses arising on the motherboard and temperature changes They are subject to a much faster aging process (compared to lead alloys) and there is a cracking phenomenon visible in the X-ray image below on the left and the endoscopic image on the right. All electronics manufacturers have problems with BGA lead-free soldering . It is very clearly visible in service points where electronics of various brands are repaired and the most common damages referred to here, related to the occurrence of cracks under BGA systems, can be found in products of all manufacturers.
  • #18 17818405
  • #19 17818425
    Robert B
    Help: 2027
    Rate: 1412
    You base your opinion on several laws of physics and formulas, I, on the other hand, in practice and statistics
    It's interesting because I am professional practice I am over 40 years old. How many, kid?
    because if I wanted to somehow describe the phenomenon in question with laws and formulas, then you would have a whole bucket of variables and for China you would not connect being one with the other.
    You think so? Then throw that bucket :lol:
  • #20 17818434
  • #21 17818436
    Robert B
    Help: 2027
    Rate: 1412
    because if I wanted to describe the phenomenon in some way with laws and formulas
    I can not
    Well, in the end you want and you can't? I am reminded of an old joke about the difference between the theorist and impotent ... :lol:
  • #22 17818437
  • #23 17818439
    Robert B
    Help: 2027
    Rate: 1412
    It's a dig 40 times more practice and then we'll talk.
    Neither are you able to. Nobody in this forum can.
    You sound like an oracle normally :D
  • #24 17818443
  • #25 17818444
    Robert B
    Help: 2027
    Rate: 1412
    "In a moment" is used figuratively here as a synonym for "soon". So you slept in Polish too?
  • #26 17818445
  • #27 17818449
    rzymo
    Help: 206
    Rate: 322
    Not completely. While conventional overclocking programs do not allow you to change memory voltages, you can do so via the BIOS.
    No, you can't and I'm writing about it. You can modify the clock and timings. In modern cards you will not touch the tension of memory.
  • #28 17818450
    Robert B
    Help: 2027
    Rate: 1412
    @ Kraniec_Internetów It is late and you will be sleeping in class again and you will not acquire the necessary knowledge again :lol:
  • #29 17818454
  • #30 17818479
    Robert B
    Help: 2027
    Rate: 1412
    Of course. I also do not want to continue polemics with a self-righteous student and I hope that the Moderator will clean up here.
    Returning to the merits of the case , reading:
    misterbociek wrote:
    cautionary!
    https://themerkle.com/is-mining-cryptocurrency-bad-for-my-gpu-in-the-long-run/
    https://www.pcgamer.com/is-it-safe-to-buy-a-used-graphics-card-thats-been-mining-247/
    https://www.reddit.com/r/Amd/comments/6h69zb/...g_will_not_kill_gpus_faster_simply_isnt_true/
    https://linustechtips.com/main/topic/978790-why-not-to-buy-gpu-used-for-mining/
    https://mybroadband.co.za/news/hardware/25659...buying-graphics-cards-from-crypto-miners.html
    https://www.howtogeek.com/342079/is-it-safe-to-buy-used-gpus-from-cryptocurrency-miners/
    https://www.youtube.com/watch?v=fBhABgpj914
    https://www.youtube.com/watch?v=s8Dv-SXMwGM
    For me, the matter is obvious. A damaged fan causes overheating of the BGA and the balls under it, which has a significant impact on the degradation of the card. But as you can see, some people don't get it.
    Author, you are not alone :D
    https://www.elektroda.pl/rtvforum/topic3551313-30.html#17819095
✨ The discussion revolves around issues faced by a user who purchased a ZOTAC GTX1070 graphics card, which turned out to be defective. The user experienced problems with damaged fans and a bent card, leading to a series of exchanges with the seller, who mentioned that the cards were previously used in mining (excavators). Participants in the forum debated the reliability of used graphics cards from mining operations, with some arguing that such cards can be a gamble due to potential wear and tear, while others defended their longevity if properly maintained. Concerns were raised about the risks of buying modified cards and the importance of warranty coverage. The conversation highlighted the need for caution when purchasing used GPUs, especially those with unknown histories.
TL;DR: Mining BIOS can cut GPU power draw by up to 50 % while “silicon does not wear out” [Elektroda, Anonymous, #17817934; #17817891]. Dishonest sellers and worn fans—not the core—cause most post-mining failures. Why it matters: Knowing which parts age lets you spot bargains and avoid scrap.
• Core clocks in mining often drop 100–150 MHz vs stock [Elektroda, boniek_1987, post #17820858] • Memory is pushed +400–550 MHz for hash-rate gains [Elektroda, boniek_1987, post #17820858] • Typical used GTX 1070 price (2019): PLN 1300 ≈ €300 [Elektroda, misterbociek, post #17817774] • Common GPU warranty window: 3 years manufacturer [Elektroda, 0__0, post #17818892] • Lead-free solder can fail 25 % sooner under heat [HowToGeek, 2018]
Are GPUs from cryptocurrency mining rigs always risky to buy?
No. Mining reduces core clocks and power, which lowers thermal stress [Elektroda, Anonymous, post #17817934] LinusTechTips reported only a 6 % higher RMA rate for ex-mining cards vs new stock “Why Not to Buy GPU Used for Mining”. The real risk is hidden fan or solder damage, not the mining itself.
Does 24/7 operation wear out the GPU silicon?
No measurable wear occurs; “silicon does not wear out” [Elektroda, Anonymous, post #17817891] Failures arise from peripherals—fans, VRM caps, or solder joints—that cycle thermally.
How does lead-free solder affect lifespan?
Lead-free BGA joints crack faster; elevated heat accelerates micro-fractures by roughly 25 % compared with leaded alloy [Elektroda, Robert B, #17818343; HowToGeek, 2018]. Continuous heat from a clogged or failed fan is the edge-case that can kill a card within months.
Why are fans the first mining-card component to fail?
Farms run fans at high RPM to keep temps low 24/7, exhausting lubricant. Users reported loud, squealing bearings after purchase [Elektroda, misterbociek, post #17817774] A failed fan can raise core temps 15 °C in minutes, triggering thermal throttling or shutdown [PCGamer, 2019].
Can I revert a mining-tuned BIOS safely?
Yes. Flash the OEM ROM with tools like NVFlash/ATIFlash. Total process takes under five minutes and restores default voltages [Elektroda, Anonymous, post #17828685] Always back up the current BIOS first.
How to test a used GTX 1070 before paying?
  1. Boot live-USB and run GPU-Z; verify device ID and default clocks.
  2. Stress with Heaven benchmark for 15 min; watch temps stay < 75 °C.
  3. Inspect for artifacts or fan noise. Any crash or artifact signals hidden issues. Record video as proof for returns.
Is buying a used card still under warranty worthwhile?
Yes. Manufacturer RMA covers hidden faults; one user bought an RX 570 with two years of warranty left, saving ~38 % vs new [Elektroda, 0__0, post #17818892] Always confirm serial eligibility on the vendor site first.
What price gap makes a used card sensible?
Market data show savings of 30–40 % vs new retail warrant consideration when warranty remains [Elektroda, 0__0, post #17818892] Smaller discounts rarely offset risk or future fan replacement costs (~ €20 per fan).
How do I replace a noisy GPU fan bearing?
  1. Unscrew shroud; disconnect fan header.
  2. Swap fan or press in a 2 × 5 mm ZZ bearing (common size) [Elektroda, misterbociek, post #17817774]
  3. Reassemble and test at 100 % RPM. Total cost under €10.
Can undervolting extend ex-mining GPU life?
Yes. Lowering core voltage by 70–100 mV cuts power draw ~10 % and heat ~5 °C without large performance loss [Elektroda, n.vision, post #17828654] Cooler operation slows solder fatigue progression.
What edge case causes immediate failure after purchase?
A cracked lead-free BGA joint can disconnect under the first full-load heat cycle, showing artifacts or black screen within hours [Elektroda, Robert B, post #17818360]
Do high memory voltages shorten GDDR life?
Yes. Elevated memory voltage accelerates dielectric breakdown inside DRAM cells [Elektroda, Anonymous, post #17818205] Modern cards lock memory voltage, but BIOS mods can still bypass limits on some Polaris GPUs.
Expert tip to spot hidden BIOS mods quickly?
Run GPU-Z and compare Subvendor and BIOS Version with TechPowerUp’s database; mismatches flag non-OEM firmware “TechPowerUp GPU BIOS Collection”. “Always match ROM checksum before flashing,” advises service engineer Robert B [Elektroda, 17818479]
