Optical Fiber Suppliers in Bielsko Biala: Map/Resources to Discover Local Providers
david177 23496 14
How can I find fiber-optic suppliers and service availability at a specific address in Bielsko-Biała?
Use the UKE address-search website at https://wyszukikuje.uke.gov.pl/, following the linked usage guide, to check operators and planned POPC expansion for a location [#17856481] However, the database may not list every fiber or planned deployment, so a missing result does not prove that no cable exists [#17856883] You can also inspect nearby poles and buildings for labeled fiber boxes, ask neighbors, and contact local providers directly about availability [#17856356] A newly installed cable may belong to a wholesale, transit, or backhaul network rather than a retail ISP, so its presence near a home does not necessarily mean residential service is available [#17856512]
  • #1 17856313
    david177
    Rate: 30
    I am looking for fiber optic suppliers in Bielsko Biala.
    Is there any serious site somewhere to find fiber optic suppliers by location?
    Thank you.
    seb235
    Help: 98
    Rate: 74
    There is no such thing as a database of all ISPs along with the addresses that they support - sometimes the providers themselves even have a problem with something like this on their own website because, for example, the records contain something different than in real life.
    Although figuring it out is quite simple, go outside the house and walk up the street for a maximum of 500m in each direction. If any supplier has hung an optical fiber, it is likely that a white square box will hang on some pole, most likely with a sticker on which you will find the company name or contact details. It looks something like this:
    A pole with a fiber optic junction box in a white casing, surrounded by coiled cable, against a blue sky and green trees.
    If you live in a block of flats, there are certainly some leaflets, information on the cages, possibly similar installation elements with the operator's logo.
    And the last option is to call the suppliers available in your city with a question about the availability of services in your location, or you can arrange it by e-mail.
    If you are new to the area, it is worth asking what your neighbors are using and whether they are satisfied with the level of services offered.
    matek451
    Help: 4352
    Rate: 5808
    Of course it exists, I don't see the need to fly blindly around Bielsko Biała and look for an optical fiber.
  • #4 17856407
    david177
    Rate: 30
    Thanks for the info.
    From my information so far, there are two possibilities:
    1. Exactly such a pole as in the picture is under the house. I already know the operator. The operator is unknown to anyone, he only laid the cables a month ago and no one has any experience with this operator. The operator offers only 2-year contracts.
    2. Since there is another optical fiber in the sewage system (by the sidewalk, by the main road), unfortunately I cannot find the operator.
    I have already called all the operators in the city and none of them offers optical fibers at the given address.
    PS What surprises me about the operator 1. He doesn't do any advertising and he doesn't promote his optical fiber in this area.
    I mean how to find?
    jprzedworski
    Help: 758
    Rate: 828
    Maybe he's not finished with everything yet. It is not enough to pull it, it has to be connected to the backbone. Not to mention all formal activities such as wiring records, all approvals, contracts with backbone operators, etc. etc.
    seb235
    Help: 98
    Rate: 74
    This optical fiber could be located in order to connect another town / settlement / street. The optical fiber itself is used practically at every stage of building an ICT network, not only to connect the end customer. In addition, it could be some wholesale provider or a network built for the P2P connection (not to be confused with torrenting).
    matek451 wrote:
    Normally, use the UKE website dedicated for this purpose https://wyszukikuje.uke.gov.pl/ in accordance with the colleague's guide @radius (@internick) http://www.bez-kabli.pl/viewtopic.php?f= 30 & p = 590029 # p590029
    For me, I say that I can have a maximum of 20Mb / s from Netia or 10Mb / s from TP SA and zero information about the optical fiber that came to the street in the first version from 10 years ago.
  • #8 17856883
    david177
    Rate: 30
    I hit:
    1. Planned expansion (POPC) +
    2. Services
    the result of this shows me only (see screenshot):
    Unfortunately, no information about the optical fiber and no information about the planned optical fiber.
  • #9 17857641
    smaboman
    Help: 7
    Rate: 12
    And do you know how operators approach the use of existing infrastructure?
    For example, operator X has laid an optical fiber and is it possible for Netia / Orange to use their optical fibers to provide their services?
  • #10 17858159
    seb235
    Help: 98
    Rate: 74
    Such things as the use of operator X of the Y operator's link is nothing new, if you need to connect a location, e.g. 50KM, then no one will lay new cables, only a fiber is leased or a data transmission service is purchased from an operator available in a given region and provides the service closest to the expected location . However, these are services for operators that involve considerable costs. And the home user wants to pay about PLN 50 / month.
    It doesn't work either, so the operator takes X, connects to the cable that hangs on the pole and starts using it for his own purposes.
  • #11 17859461
    smaboman
    Help: 7
    Rate: 12
    Why should he pay more? If the prices for a given service are at this level, the home user will choose the service that suits him in terms of quality and price.
    I am aware of this, and I am more interested in how operator X can find out, for example, about the fiber located in a given location and about the interest in its services in a given area.
  • #12 17860396
    seb235
    Help: 98
    Rate: 74
    You just have to change the way you think about the operation of such networks today compared to what was 10 years back. By analogy to the LLU from Neti where the line was switched to the netia DSLAM and the process was done, the same could be done in bolts where the Ethernet service was provided. This was due to the fact that in the case of telecoms, each subscriber had his own copper pair that flew directly from the DSLAM to your modem, so overvoltage a single client was a formality. The same with ethernet, connect the patch panel cable to another switch from another supplier and from the head.
    Unfortunately, today it is impossible to take that and switch the subscriber to another provider. You write about optical fiber, so maybe on such an example. The device that transmits the optical signal (from the operator's side) is OLT, where one port has a bit rate of 2.5 Gb / s to the client and 1.25 Gb / s from the client (in the case of GPON). On this one port, an optical fiber is attached, which using optical splitters (in these boxes on the poles) theoretically terminate a maximum of 128 clients, the orange itself declares that they connect 64 of them. So your cable and your fiber actually end up in a splitter which you have in front of the house. In the case of such services, it is impossible to switch the subscriber to another operator because you really switch everyone on this fiber. In cable networks, there can be even more customers on one coaxial cable.
    What you are writing about works, on the basis that, for example, Netia can send a signal through their fiber from location A to location B, although this is used to connect your equipment to the network core and the next step is to build your own access network anyway. Nobody will connect such a fiber to your house / flat, if you have a company that can afford huge installation costs and a monthly subscription of, say, PLN 1500 / month, then it can be arranged.
    You don't have to pay more, the company doesn't have to connect you. Therefore, there is a separate helpline for individual clients and if they do not have everything ready, you get a refusal. This is a simple economic account the operator wants to earn. I will write more, ask your neighbors how many people are willing to switch to another operator - the interest will be small, if you say that the cost of the installation is, for example, PLN 99, half of it will crumble, once you sign a declaration, a handful will be left.
    Recently, I read an article summarizing the operation of these 3 provinces that built their fiber-optic network, the interest in using the service is negligible, so that ISPs who use it are not even able to cover the cost of the cable lease.
    There is no need to dwell on the topic more because you will not get anything done, be glad that you have the option of connecting to the infrastructure that already exists. There are people in a much worse situation.
  • #13 17873538
    smaboman
    Help: 7
    Rate: 12
    Thanks for such an explanation (from the technical side) I meant. My guess is that if a given operator does not find it profitable to do something, he will definitely not implement it. For example, Orange does not modernize its infrastructure in my area.
    As for the optical fiber, I have just such a splitter on the pole in front of the house. However, the subscription prices requested by the provider are so high that, having a fiber optic cable 5 meters from my home, I use LTE Internet. And thanks to the appropriate configuration, LTE works so well that I will wait until the prices from the supplier with fiber drop to normal.
  • #14 17873964
    david177
    Rate: 30
    In the location that I described, the fiber optic price list is as follows:
    1.50 MB = PLN 50 / month
    2.100 MB = PLN 60 / month
    3. 200 MB = 80 PLN / month
    4. 300 MB = PLN 100 / month
    Added to this:
    5. Connection + installation about 5 m = 200 PLN (one time)
    6. Router surcharge (AC) = PLN 100
    Contract for 2 years!
    (it scares me off, because this operator is unknown here)
    PS. For comparison, another operator in a different district nearby offers, for example,
    Contracts for only 1 year of time and costs much less from the above, i.e.
    7.100 MB for PLN 50 contract for only one year / PLN 40 for 2 years
    8. 300 MB for PLN 60 contract for only one year / PLN 50 for 2 years
    9. 600 MB for PLN 70 contract for only one year / PLN 60 for 2 years
    10. 1000 MB = PLN 80 / contract for only one year / PLN 70 for 2 years
    So you can see from this example here, the price difference is very big.
  • Wholesale source and service quality affect fiber pricing
    #15 17916128
    seb235
    Help: 98
    Rate: 74
    In fact, the prices are not small because I pay PLN 49 / month for 200Mb / s for a 24-month contract, although 50Mb / s for PLN 50 / month is always better than LTE.
    Contracts for only 1 year of time and costs much less of the above. So you can see from this example here, the price difference is very big.
    Except that you only compare the prices of the monthly subscription. It's hard to say what level each of these operators offers. The question is from which wholesale suppliers they take the connection and how much, in what technology and on what equipment they deliver it to the customer's home. To what extent does it work flawlessly and how does the service in each of these companies work in case something happened? Remember also that the throughput from the contract, i.e. 300Mb / s, is one thing, but the real achievable speed to specific servers may be different, especially during peak hours or holidays. I would be able to raise my x2 monthly commitment if I could have a better quality connection.
The discussion revolves around finding fiber optic suppliers in Bielsko Biała. Users express frustration over the lack of a comprehensive database for local ISPs and suggest alternative methods for locating providers, such as checking for visible infrastructure like white square boxes on poles or using the UKE website for service availability. Some users report difficulties in identifying operators, especially when new providers have recently installed cables without advertising. The conversation also touches on pricing for fiber optic services, with comparisons made between different operators and their contract terms. Concerns about service quality and the potential for using existing infrastructure are also raised.
TL;DR: GPON ports deliver 2.5 Gb/s down and 1.25 Gb/s up; "It is impossible to switch the subscriber to another operator." Use this FAQ to check availability, spot splitters, and weigh contracts in Bielsko-Biała. [Elektroda, seb235, post #17860396]
Why it matters: For Bielsko-Biała residents and small businesses who need a clear, practical way to discover real fiber availability and compare local options.
How do I check which fiber providers serve my exact address in Bielsko-Biała?
Use UKE’s official “wyszukiwarka” at wyszukikuje.uke.gov.pl. Search by address and review listed services. This tool centralizes operator-reported availability for consumer planning. If your address shows limited options, still contact listed providers directly. Reported data can lag deployments. Keep screenshots or reference numbers when you submit availability queries. This streamlines follow-ups with operators. [Elektroda, matek451, post #17856481]
Is there one database that lists every ISP by address?
No. “There is no such thing as a database of all ISPs.” Records can differ from actual on‑the‑ground builds. Do a quick field check and call operators to confirm. In apartment blocks, check leaflets and riser labels for operator details. Availability pages on operator sites can also be inconsistent with deployments. Always verify by phone or email. [Elektroda, seb235, post #17856356]
How can I verify fiber availability around my home without any map?
Try this quick on‑foot check:
  1. Walk ~500 m each direction and look for white square boxes on poles with operator stickers.
  2. In blocks, check stairwell notices or boxes with operator logos inside the building.
  3. Call or email the operator on the sticker to confirm your address. [Elektroda, seb235, post #17856356]
I see a white square box on a pole—does that mean I can order service?
It often indicates local distribution or a splitter with the operator’s sticker and contacts. Note the company name and reach out for address qualification. In multi‑dwelling units, look for flyers or signage in common areas. Field visibility is a strong signal, but always confirm serviceability before planning. [Elektroda, seb235, post #17856356]
Why might a visible splitter not mean service is ready yet?
That run could be transit fiber to another area, a wholesale route, or a point‑to‑point link. It may not target end users. Operators also stage builds, so street hardware can arrive before customer activation. Always confirm with the operator listed on the enclosure sticker. [Elektroda, seb235, post #17856512]
Why isn’t the new operator advertising yet in my neighborhood?
They may still be finishing backbone connections and formal approvals. Back‑office tasks include records, inter‑operator contracts, and integration. Without these, sales cannot start even if cable is on poles. “It is not enough to pull it, it has to be connected to the backbone.” [Elektroda, jprzedworski, post #17856486]
UKE shows no fiber at my address—what does that mean?
Coverage portals can lag real deployments. One user saw only 10–20 Mb/s listed despite fiber present on the street. Treat the portal as a starting point, not a guarantee. Call local operators and quote your exact building details. Ask for a manual check or survey. [Elektroda, seb235, post #17856512]
Can Orange or Netia use another operator’s fiber to serve my home?
Operators can lease fiber or buy data transport to link locations. That is backhaul, not last‑mile service for a single flat. Costs are significant and not designed for 50 PLN consumer plans. “It doesn’t work that the operator connects to a cable on the pole.” [Elektroda, seb235, post #17858159]
What is GPON and how many users share a port?
In GPON, one OLT port provides 2.5 Gb/s down and 1.25 Gb/s up. The optical split can serve up to 128 clients; Orange often uses about 64. “A maximum of 128 clients” on one port is typical for the technology’s design. [Elektroda, seb235, post #17860396]
Can I switch to another provider on the same GPON splitter?
No. “It is impossible to switch the subscriber to another operator.” GPON ports serve many customers via splitters. Switching a single line would affect everyone on that fiber segment. Choose your provider within the network that serves your address. [Elektroda, seb235, post #17860396]
What fiber prices are locals seeing around Bielsko-Biała?
Reported example: 50 Mb/s for 50 PLN, 100 Mb/s for 60 PLN, 200 Mb/s for 80 PLN, 300 Mb/s for 100 PLN. Another nearby operator offered 100 Mb/s for 50 PLN and 1000 Mb/s for 80 PLN on 12‑month terms. Use these as reference points and verify current promos. [Elektroda, david177, post #17873964]
What one‑time costs and contract terms should I expect?
A sample quote showed install ≈ 200 PLN for ~5 m and router (AC) ≈ 100 PLN. Many local offers use 24‑month contracts. Shorter 12‑month terms exist with some operators nearby. Assess risk with new or unknown providers before locking in. [Elektroda, david177, post #17873964]
Should I pick based only on the lowest monthly price?
No. Consider upstream providers, equipment, and support quality. Peak‑hour throughput to real servers can differ from headline speeds. One expert noted they would pay more for better quality. Test latency and evening speeds when possible. Support response matters during faults. [Elektroda, seb235, post #17916128]
If fiber is pricey today, is LTE a viable temporary option?
Yes. One user with a splitter five meters away chose LTE due to high fiber pricing. With proper configuration, LTE performed well enough to wait for better fiber deals. Evaluate data caps and coverage before committing. [Elektroda, smaboman, post #17873538]
How do operators decide whether to expand fiber in my area?
It’s an economic decision driven by demand and cost recovery. Gather neighbors and register interest to improve the case. An expert noted some regional fiber projects saw negligible uptake, not covering cable‑lease costs. Low adoption stalls expansion plans. [Elektroda, seb235, post #17860396]
