Fixed IP Address & Open Ports: Orange SIM USB Modem, Proxy, VPN Solutions & More
Darek1222 10734 10
How can I get a fixed public IP and open inbound ports on an Orange SIM USB modem?
You need a fixed/public IP service from the operator; Orange reportedly offers an additional external service with either floating or fixed IP, and a VPN is only mentioned as an alternative workaround [#17898558] [#17899518] [#17900288] This is said to work on a subscription offer, but not on prepaid [#17898571] For the port issue, the thread’s practical answer is that having a public fixed IP is the way to allow inbound access rather than being behind the carrier firewall/NAT [#17898558] [#17899518]
  • #1 17898497
    Darek1222
    Rate: 39
    Hi.
    I currently have an orange sim usb modem card.
    The problem is that the internet is only suitable for browsing the web.
    Because ip is variable So I have blocked ports and I'm behind fw.
    Is there a way I don't know, e.g. a proxy, vpn or something like that that would change me to a permanent ip address? and that ports will be open, not the other way around.
    Can only the network administrator do that?
    sosarek
    Help: 9320
    Rate: 15532
    Purchase of an appropriate fixed public IP service or playing with a VPN.
    Z
    Pka, Poznań, 60-850
  • #3 17898568
    Darek1222
    Rate: 39
    saucers
    Thank you.
    Something more about:
    Purchase of an appropriate permanent public IP service
    Where should I buy such ip?
    Generally, a variable ip address can be irrelevant.
    It's about ports.
    I want to keep them open and all GSM networks block it.
  • #4 17898571
    sosarek
    Help: 9320
    Rate: 15532
    With your operator, if it is a subscription offer, it does not work in the case of prepaid.
    Z
    Pka, Poznań, 60-850
  • #5 17898580
    Darek1222
    Rate: 39
    Oh
    I only know that.
    Well, I will ask anything from vpn operators.
    does prepaid work? There are companies that sell prepaid ip fixed god; p
    BikeBarian
    Help: 37
    Rate: 122
    Orange has the option to purchase an external service. Either floating or fixed IP. Ask u nothing.
  • #7 17900158
    Darek1222
    Rate: 39
    @BikeBarian
    Well, for 10 years it has been poisoning them to introduce it.
    Maybe something has already changed, I'll call you soon and write what and how later.
    Greetings.
    Era has had it for about 4 years with the fact that it has to be for an internet company.
    sosarek
    Help: 9320
    Rate: 15532
    Darek1222 wrote:
    @BikeBarian
    This is an ADDITIONAL option that can be purchased.
    Z
    Pka, Poznań, 60-850
  • #9 17902844
    Darek1222
    Rate: 39
    saucers
    Well, what are the nerves for.
  • #10 17906621
    aquator
    Maybe I will still ask. I have a similar problem and I'm on pre-paid PLAY. Not only does PLAY offer no such service, but also a card. I have read in forums so far that it is not possible to have outside access to your own network in that case. My router allows you to set your own DDNS as a service already included in the price of the router, so that I can connect, but the description of this service on my equipment shows that I can have a variable IP, but I must have an external one. However, I tried to set up such a connection on my link, in various ways, but unfortunately I do not connect to it, only from within my own network, and that's not the point.
    However, when I bought an IP camera, a simple, domestic production for PLN 150 (Camspot), after configuration on the smartphone application? and I calmly connect to this camera from the outside and I have a picture ...
    Could you please explain to me what this is about? Maybe I am just misconfiguring this connection by the provided ASUS service? Should I play with ports to make this work? Where to find a way?
    Or is the camera set to the VPN channel and that's why it works?
  • #11 17906626
    BikeBarian
    Help: 37
    Rate: 122
    The camera reliably connects to the manufacturer's cloud and you can access the image through an account on his portal ??. It is definitely not a point to point combination.
The discussion revolves around the challenges of using an Orange SIM USB modem with a variable IP address, which limits internet functionality to basic browsing. Users seek solutions for obtaining a fixed public IP address and opening blocked ports, with suggestions including purchasing a fixed IP service from the network operator or utilizing VPN services. It is noted that prepaid plans may not support fixed IP options, and some users share experiences with alternative services like DDNS and cloud-based camera access, highlighting the limitations of their current setups. The conversation emphasizes the need for external IP access and the potential for additional services from providers like Orange.
