Can I smoke e-cigarettes by the smoke detector?
Bazooka123 50160 4
  • #1 17948341
    Bazooka123
    Hello, as it is written in the topic and are there any effective ways to smoke with a smoke detector or other type. Thank you in advance for your answer.
  • #2 17948548
    conrad9210
    Help: 83
    Rate: 210
    Hi. The sensors detect, among others, smoke, temperature, air ionization. Depends on what type of sensor you will be standing under. In your case, it is enough not to blow the sensor, stand in the vicinity of some air exhaust and there should be no problem. Do not try to disable / open it, because you will activate the tamper in the control panel.
  • #3 17949059
    piracik
    Help: 557
    Rate: 1977
    In my opinion, he should respect the smoking ban and go outside.
    The smoking ban also applies to e-cigarettes
    In buildings with detectors there is usually a total ban or there are smoking cabins.
  • #4 17950894
    ziemek56
    Help: 24
    Rate: 186
    exhalation from E cigarettes is a nicotine particle and water vapor, i.e. SMOKE. Each smoke detector will react because smoking is harmful !!! Ziemowit - a smoker aware of his carelessness (stupidity). e.t.c.
