How to Temporarily Silence Smoke Alarm While Cooking Without Disabling Safety?
342 9
How can I stop a smoke alarm from going off while cooking without disabling fire safety?
You generally should not add a temporary on/off switch; the practical fix is to move the detector away from the kitchen or replace the ionization unit with an approved photo-electric smoke detector. [#21661058][#21661061][#21661060] Ionization alarms are commonly the cheaper type and can trip on cooking steam or a little smoke, while photo-electric models are less prone to nuisance trips. [#21661064][#21661061] If you cannot relocate it because of apartment rules, check the local laws before changing detector types and only use an approved detector. [#21661061]
  • Suggesting adjustable sensitivity or timed hush switch
    #1 21661057
    Yves Lauzon
  • #2 21661058
    Scott Wohler
  • #3 21661059
    Steve Lawson
  • #4 21661060
    Scott Wohler
  • Photoelectric detector suggested as less sensitive alternative
    #5 21661061
    Steve Lawson
  • #6 21661062
    DAVID CUTHBERT
  • #8 21661064
    Mark C Nakamura
  • Dust from vacuum triggered full building alarm shutdown
    #9 21661065
    Sarah Harris
  • #10 21661066
    Steve Lawson
The discussion addresses the challenge of smoke alarms frequently triggering during cooking due to their high sensitivity, particularly ionization smoke detectors that respond to minor smoke or steam. Relocating detectors away from kitchens is suggested but may be impractical in rental apartments. Modifying or disabling alarms is discouraged due to safety and legal concerns. A recommended solution is replacing ionization detectors with photoelectric smoke alarms, which are less sensitive to cooking smoke and steam, though compliance with local regulations must be verified. Hardwired (mains-powered) alarms can also be overly sensitive, as illustrated by an incident where dust triggered a building-wide alarm system causing extensive lockdowns. Overall, selecting appropriate detector types and proper placement are key to minimizing nuisance alarms without compromising safety.
