Temporarily Disconnecting Smoke Detector for Stage Lighting Effects in Kindergarten
kramos 19269 20
How can I temporarily disable a ceiling smoke detector connected to a fire brigade alarm system so we can use stage smoke effects in a kindergarten room?
You cannot safely disable a single smoke detector yourself; any temporary shutdown should be done only by the fire-alarm service technician, with the fire brigade and the facility manager’s approval [#15427696][#15428719] There is no simple switch for one detector; at most, a technician can disable the relevant loop in the fire control panel, but a layperson cannot do it [#15427712] Do not cover the detector with a plastic bag or otherwise obstruct it [#15427696][#15427712] If the issue is stage fog, consult the detector manufacturer or fire-protection supervisor, and consider whether the detector should be replaced with a dual or temperature detector, or use one intended for real smoke rather than steam [#15427696][#15429403][#15453348]
  • #1 15427575
    kramos
    Hello, I am asking as a complete layman - as parents in kindergarten we plan to install stage lighting - a perfect element to diversify the lighting effects is a smoke generator - and here there is a problem - a smoke detector installed on the ceiling - the detector is connected to the system that is called by the fire brigade.
    Here is my question - how can a detector located in the room be temporarily disconnected from the entire system? as if it would be the cost of making a "switch" that cuts off the detector and turns off the detector squealing. Are such solutions practiced?
    I will be very grateful for the hint on this topic. (could anyone from Warsaw who could do it?)
  • #2 15427586
  • #3 15427614
    WędkarzStoLica
    Help: 146
    Rate: 300
    full_metal_jacket wrote:
    And then someone forgets to turn on the detector, a fire breaks out, the children are burned alive
    And the guardian will be drunk in three asses asleep under the fence? and no one will bring the children out.
    Over-zealousness is worse than fascism and should be punished. You're exaggerating.
    It is enough to cover the detector with a plastic bag as above and do not worry about such opinions.
    Moderated By suworow:
    For a nonchalant approach to security, a colleague is awarded a warning.
  • #4 15427634
    kramos
    Thanks for the hint with the packaging, but it's about a more "professional" solution that the management will accept :) for example, a timer for 2 hours?
    This is a detector in the middle of the gym, children are in the rooms on the ground floor, so you can always evacuate through the window ;)
    I suggest designing escape routes, however, to professionals.
  • #5 15427640
    WędkarzStoLica
    Help: 146
    Rate: 300
    But the bag solution is professional :) Everyone does it.
    It can be done beautifully and almost imperceptibly.
    As above
  • #6 15427696
    Jar-Woj
    Help: 98
    Rate: 314
    Any sticking or other obstruction of the fire detectors is not an option. Any temporary shutdown of the fire protection system should be carried out in agreement with the Fire Brigade and the person responsible for facility management.
    The question is what type of smoke generator and on what principle of operation you want to use.
    In my opinion, this should be consulted with the person supervising the fire protection installations and with the fire brigade.
  • #7 15427712
    mawerix123
    Help: 482
    Rate: 951
    The fact that everyone does it does not mean that putting a plastic bag on the detector is professional, although it is used only temporarily.
    A switch for a given detector also cannot be installed, you can turn off the entire loop in the fire control panel, but without a system service technician you will not be able to do it.
  • #8 15428177
  • #9 15428719
    stomat
    Help: 257
    Rate: 1982
    In one sentence, CANNOT. Let preschoolers imagine the smoke. Or let them imagine the whole show.
    Don't you get the impression that you are exaggerating a bit? After all, smoke machines are always used in rooms full of people and somehow it works.
    Report to the operator of the fire panel and disable the detector. You can't do it on your own. Well, unless a plastic bag or "gum".
  • A small fan can reduce detector sensitivity during fogging
    #10 15428898
    kortyleski
    Help: 957
    Rate: 3860
    The first question is, what is the point of fogging the room in such a way that the detector would work? After all, the end of the nose will not be visible. For another steam from the fuming machine, it is less effective at the optical sensor than by the combustion products. But for the wolf to be full and the sheep in full, you need to inform the guards about the experiment being carried out and smoke the room to the required level, possibly canceling the alarm. Also remember about possible coincidences, a party, smoke from the machine and a fire to match. With the sensor off and the room steamed up, no one will notice any smoke that some mummy will say that the smoke is a bad idea because it is burning terribly. Tragedies usually arise through a combination of several seemingly unrelated circumstances.
    Now I earn a warning, but if you have to figure it out, hang a small fan next to the detector. It will greatly reduce the sensitivity.
  • Consult detector documentation and notify guards before fogging
    #11 15429033
    Jar-Woj
    Help: 98
    Rate: 314
    kortyleski wrote:
    The first question is, what is the point of fogging the room in such a way that the detector would work? After all, the end of the nose will not be visible. For another steam from the fuming machine, it is less effective at the optical sensor than by the combustion products. But for the wolf to be full and the sheep in their entirety, you need to inform the guards about the experiment being carried out and smoke the room to the required level, possibly canceling the alarm.
    There is no place for experiments here, rather, you should read the technical documentation of the detectors, the best way to ask is to the manufacturer.
  • #12 15429403
    riddyk
    Help: 34
    Rate: 109
    There is no need to consult and agree with the SAP system explorer.
    One of the technical solutions is to replace the smoke detector with a dual one or a temperature one. Perhaps it is already dual or temperature.
    Enter what the control panel is and what the detector is, Model, type.
  • #13 15430418
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    After all, the author of the thread is a parent, he has no knowledge, and even less appropriate qualifications, to rummage in the fire protection system.
  • #14 15430455
  • #15 15430531
    Łukasz-O
    Help: 654
    Rate: 4292
    15kVmaciej wrote:
    besides, the first fast is either a provocation or a provocation. The machines do not call the services.
    How can the author know about it (if not provocation). A lot of people not dealing with a given topic have their own imaginary knowledge.
    But that's not the problem here. It is us who should filter the data in this case.
  • #16 15430884
    kj1
    Electrician specialist
    Help: 278
    Rate: 850
    And yes, they do. The control panel may have an automatic fire brigade call function implemented. Nevertheless, it is always possible to block this signal (the alarm signaled by the detector may be false and should be verified by the cantral staff)
  • #17 15431534
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    And someone thought about the composition of this "smoke"?
    After all, all generators produce fog, not smoke.
    Otherwise people would trip.
    Try to blow into the detector from the e-cigarette.
  • #18 15432976
    mawerix123
    Help: 482
    Rate: 951
    Tell this to the chick who had to pay 5k PLN for the guard's arrival when he sweetly kimał on duty ;)
  • #19 15433177
    Alana
    Level 37  
    Help: 361
    Rate: 245
    And approach the matter "from behind" and replace the smoke generators with an ultrasonic humidifier, one that generates fog. There is a "smoke" effect on the stage and the detector should not react to it.
  • #20 15433331
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    I suggest temporarily refrain from discussing because the subject begins to evaporate in smoke. And our author fell silent.
  • #21 15453348
    Rtęciówka94a
    Help: 7
    No problem. Look for the sensor for the actual "smoke" and not for the steam. They exist.
The discussion revolves around the challenges of temporarily disconnecting a smoke detector in a kindergarten setting to facilitate stage lighting effects using a smoke generator. Concerns are raised about safety and legality, emphasizing that any obstruction or disconnection of fire safety systems should be conducted in consultation with fire safety authorities. Suggestions include using a plastic bag to cover the detector, although this is deemed unprofessional. More viable solutions involve consulting with fire protection experts or considering alternative devices like ultrasonic humidifiers that produce fog without triggering alarms. The importance of adhering to fire safety regulations and the potential consequences of improper handling are highlighted throughout the conversation.
