Alliexpress Smoke Detector: Non-Responsive to Cigarette Smoke - Is This Normal?
5985 17
Why doesn’t my AliExpress smoke detector react to cigarette smoke, and is it defective?
It’s normal for this type of photoelectric smoke detector not to react to a small puff of cigarette smoke; it should alarm only on denser smoke, and the TEST button only checks the electronics, not the smoke sensor [#16752524][#16752694] The indicator should blink periodically in standby and go to continuous light when the detector activates; then it may beep and/or switch relay contacts depending on the model [#16752694] Try powering it up, waiting about a minute, and then exposing it to denser smoke from burning paper/cardboard or chimney smoke [#16752524][#16752592] In the thread, the detector did eventually trigger only after much heavier smoke, which suggests the original cigarette-smoke test was too weak rather than proving a fault [#16752592][#16753983] If it still won’t alarm on dense smoke, the advice was to treat it as defective and complain/replace it [#16752524]
  • Cigarette smoke may not trigger the detector
    #1 16752466
  • #2 16752492
    retrofood
    Help: 1140
    Rate: 4798
    See the instruction manual.
  • #3 16752497
  • #4 16752501
    1repcaK
    Help: 52
    Rate: 123
    There is no "TEST" button there?
  • #5 16752505
    kosmos99
    Help: 338
    Rate: 820
    In my opinion, this sensor is not working.
    Have you checked the power?
  • #6 16752508
  • #7 16752517
    1repcaK
    Help: 52
    Rate: 123
    Try with the chimney smoke, this is what this detector was made for. There may not be enough carbon monoxide in cigarette smoke.
  • #8 16752521
  • Photoelectric detector needs smoke particles, not cigarette fumes
    #9 16752524
  • Photoelectric sensor confirmed by internal pictures
    #10 16752532
  • #11 16752584
  • Smoke detector only triggered by sustained card smoke
    #12 16752592
  • #13 16752694
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    The photoelectric detector reacts to dense smoke, and even dust, so they should be periodically "blown through" with compressed air. The signaling diode increases the frequency of blinks to a constant light depending on the operation of the photoelement. Continuous light means detector activation, depending on the equipment it may squeal and / or close / open the relay contacts.
  • #14 16752871
    bhtom
    Help: 446
    Rate: 604
    Marek57698 wrote:
    IT'S WORKED!
    I lit 4 cards, held over it for 2 minutes and it squealed!
    Above or below the sensor? Maybe this sensor only reacts to temperature rise ...?
    Take that junk out and buy something decent and proven!
    Greetings.
  • #15 16752880
    1repcaK
    Help: 52
    Rate: 123
    However, the smoke from the chimney did it!
    On the other hand, it is questionable to use this particular detector when it needs such a "dose" of smoke to operate.
  • #16 16752920
  • #17 16753983
  • #18 16754637
The discussion revolves around a smoke detector purchased from Alliexpress that fails to respond to cigarette smoke. The user questions whether this lack of response is normal or indicative of a malfunction. Responses suggest checking the power and the presence of a "TEST" button, with some users recommending testing with chimney smoke instead, as cigarette smoke may not contain sufficient carbon monoxide. The user later reports that the detector only activates when exposed to dense smoke, such as from burning cardboard, raising concerns about its reliability. Several users express skepticism about the detector's effectiveness, suggesting that it may require a significant amount of smoke to trigger an alarm. Brands like Polon-Alfa, Kidde, and Yotogi are mentioned as alternatives for more reliable smoke detectors.
TL;DR: Many $4 AliExpress photoelectric alarms miss light cigarette smoke; as one expert notes, "it reacts to smoke particles, not chemical products of combustion." If yours needs dense smoke to trigger, consider returning it. [Elektroda, sharp, post #16752524]
Why it matters: This FAQ helps apartment and home users diagnose non‑responsive budget smoke detectors and decide when to replace them for safety.
Is it normal that a cheap AliExpress smoke detector doesn’t react to cigarette smoke?
No. A photoelectric alarm should react to smoke particles, but thin cigarette smoke may be too sparse to scatter enough light in the chamber. If an alarm persistently ignores visible smoke, treat it as unreliable and replace or return it for safety. [Elektroda, sharp, post #16752524]
How should the status LED behave on a working photoelectric alarm?
Expect a periodic blink in standby. During an alarm condition, the blink rate increases and may go to a steady ON state. That visual change indicates the photoelement sees enough obscuration to declare an alarm and drive the buzzer or relay. [Elektroda, Akrzy74, post #16752694]
Does pressing the TEST button prove the smoke sensor is good?
The TEST button confirms power, buzzer, and basic electronics. It does not verify the optical chamber’s sensitivity to smoke. A unit can beep on TEST yet fail to detect actual smoke, so always validate with a safe smoke source or replace suspect devices. [Elektroda, Marek57698, post #16752508]
How much smoke did it take to trigger the unit discussed in the thread?
It alarmed only after the user burned four paper cards and held them about two minutes near the detector. That delay and density suggest poor sensitivity and justify a return or replacement to ensure timely warning in real fires. [Elektroda, Marek57698, post #16752592]
My frying pan smoked and the alarm stayed silent—what does that indicate?
If visible cooking smoke fails to trigger, the detector may be desensitized, defective, or poorly located. Consider returning it and installing a reputable unit. Relocate away from dead‑air spots but still within the kitchen’s smoke path. [Elektroda, Marek57698, post #16752521]
Which brands were recommended over ultra‑cheap imports?
Forum contributors pointed to established brands such as Polon‑Alfa, Kidde, and Yotogi, and suggested buying from local appliance or electrical stores to simplify warranty claims and ensure reliable performance. [Elektroda, sharp, post #16752524]
Should I return a detector that won’t react to everyday kitchen smoke?
Yes. The advice was to power it, wait a minute, introduce smoke, and if it still doesn’t respond, pursue a complaint/return. Safety‑critical gear should not require extreme smoke to alert. [Elektroda, sharp, post #16752524]
Is this device a carbon monoxide (CO) detector?
No. The discussed unit is photoelectric and responds to smoke particles. As one expert stated, “it reacts to smoke particles, not chemical products of combustion,” so it will not detect CO gas. [Elektroda, sharp, post #16752524]
How do I clean and maintain a photoelectric smoke detector?
Dust can trigger false alarms or block the optical path. Periodically blow out the smoke chamber with clean compressed air. This restores proper sensitivity and reduces nuisance trips from settled dust. Avoid liquid cleaners inside the chamber. [Elektroda, Akrzy74, post #16752694]
Could my unit actually be a heat‑only detector?
If it ignores heavy visible smoke yet reacts only near rising hot air, it may behave like a heat device or be mis‑specified. A contributor questioned whether the sensor responded mainly to temperature rise. Replace if smoke response is unreliable. [Elektroda, bhtom, post #16752871]
How can I safely test a budget smoke detector at home?
Try this:
  1. Power the unit, then wait one minute for stabilization.
  2. Generate controlled smoke (e.g., toast or paper at a safe distance) and let smoke reach the chamber.
  3. If no alarm and LED never shifts to alarm state, replace it. [Elektroda, Akrzy74, post #16752694]
What’s an example of a reliable trigger from everyday cooking?
One user reported their detector alarms when a slice of bread burns in a toaster on the opposite side of the kitchen. That responsiveness contrasts with units needing prolonged, dense smoke to trigger. Seek similar performance when choosing a device. [Elektroda, 3029369, post #16754637]
Why are ultra‑cheap detectors risky?
Reports suggest they may require excessive smoke before alarming, delaying evacuation. As one commenter quipped, the house could be heavily involved before it alerts. Prioritize timely detection over minimal cost for life safety. [Elektroda, Anonymous, post #16752920]
I set my oven to 250°C and created a smoke cloud, but no alarm—what now?
That scenario indicates inadequate sensitivity or poor placement. Replace the unit with a reputable brand and locate per guidance, then verify operation with a safe smoke source. Don’t rely on a device that ignores heavy kitchen smoke. [Elektroda, Marek57698, post #16752592]
