Proper Ways to Vent a Gas Stove: Post Gas Meter Replacement Procedures
28137 4
  • #1 18034390
    Zbych034
    Help: 550
    Rate: 1419
    Air will flow through the burner instead of gas for a while. Once you get gas, fire up the burner and use it normally.
  • #3 18034409
  • #4 18034423
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    betmari wrote:
    A, so as I wrote, should I just turn on the taps in the oven for a moment without setting fire to it and that's it?
    In my opinion, it is best to turn on the tap while holding a lit match near the burner, at some point the gas will ignite - and that's it.
  • #5 18034470
    Zbych034
    Help: 550
    Rate: 1419
    I recommend a match, you can immediately see when there is gas in the burner.
