Gas Stove Replacement: Main Valve Closed, No Gas Flow - Role of Pressure Regulator?
Kamil1987 55438 5
  • Does the gas pressure regulator need resetting after shutoff?
    #1 8159573
    Kamil1987
    Rate: 27
    I am in the process of replacing the gas stove, disconnecting the old kitchen, I closed the main valve before the counter and after turning on the main valve, there is no gas passage, the day before I had a similar problem but I closed the valve, opened it, moved some regulator on the "reducer" (or whatever this is - photo) and it started to work and today, unfortunately, it fails. The gas installation is 15 years old, the meter is outside the house, the pipes are slightly rusty, but does this have any effect?
    I made:
    1. I closed the main valve
    2. I turned on the gas in the stove to let out what is in the pipes
    3. Unscrewed the cooker, screwed it on again
    4. I opened the main valve, but there is no gas in the stove (at the outlet of the pipe)
    There is some regulator (pressure regulator?) At the top of the reducer, maybe I should do something with it? Maybe you need to do something appropriate, such as priming the hydrophore pump, so that it draws water and draws water from the well?
    • Gas Stove Replacement: Main Valve Closed, No Gas Flow - Role of Pressure Regulator? gz.jpg (430.5 KB) You must be logged in to download this attachment.
  • Safety checks and utility referral for neglected gas piping
    #2 8159623
    Zombek
    Help: 18
    Rate: 13
    1 Read what the reducer is for (Google)
    2 Watch out for fire sources (cigarettes etc.)
    3 Replace the seals, if present, at the connections to the reducer
    4 Check the tightness of connections (in domestic conditions, water with detergent)
    5 Check the pipes and paint them, because there is probably no rust inside. Check if they are all seamless if it is steel. The same applies to fittings.
    Ideally, consider calling in someone who has an understanding of this :!:
    Regards
    Little edit. I don't know why I haven't seen the attachment. If nothing has changed, then everything in front of the meter belongs to the gasworks and report to them. Let them go through everything and list what is needed. it is terribly neglected. As much as asking for a good paint, because there is probably terrible dampness there.
  • #3 8159644
    Kamil1987
    Rate: 27
    The question is whether after closing the main valve and reopening it, the gas should "flow" in the pipes without any problems or whether something else should be done. As for me, a strange phenomenon that after closing the valve (probably ball) and re-opening it, there is a problem in the form of a lack of gas at the end of the kitchen.
    Pressure regulator safety shutoff requires manual reset
    #4 8160004
    lopr_pol
    Level 32  
    Help: 164
    Rate: 491
    There is a reducer at the gas meter, it has a built-in protection. After the pressure in the network drops, it blocks the gas flow, if you turn the gas off in front of the regulator, you have a 100% blockage. Look at the reducer somewhere has some windbreaker to unlock.
    PS. I just saw the photo, you do not have a valve behind the meter, then look for unlocking on the reducer or call the gas workers, they know what to press-pull to get the gas to go (in my neighborhood they already had an action that after the gas pipeline was interrupted, they had to fly to each reducer and unblock it)
  • #5 8160798
    Kamil1987
    Rate: 27
    As it turned out, the reducer was damaged, I called the ambulance and they replaced it with a new one, thanks for the response from LOPR.
