Gas Stove Won't Turn On: Issues with Hot Water Sink, Bathtub, Kitchen - Troubleshooting & Ideas
moxia 20682 4
  • #1 16713303
    moxia
    Hello, for some time the gas five does not want to turn on after unscrewing the hot water above the bathroom sink. An interesting fact is that when I unscrew the water over the bathtub or in the kitchen above the sink turns on immediately.
    I chased the casing, dusted it, blew it with compressed air, but it did not help. What could it be? Any interesting suggestions, ideas anyone has?
    Thank you in advance
    BUCKS
    Help: 536
    Rate: 1087
    You probably have an aerator at the sink that restricts the flow of water. Assuming that the boiler is 100% efficient, this aerator is probably contaminated with scale and currently the water flow is below the required minimum flow at which your "stove" starts. Unscrew this aerator and see if the stove turns on. If so, clean the aerator of the sediment and it should help. If cleaning does not help, then you need to install a new aerator, ensuring flow above the minimum flow required by your "stove".
    Assuming that the problem is in the "stove" some have centrifuges as a water flow sensor and if it is stoned it may react worse at low flows. Descaling this rotor should restore the old oven's sensitivity to water flow.
  • #3 16714205
    moxia
    Thanks to my friend, you are the best, but the stony aerator now flashes like new ?
    I have one more question for you, what is the best way to clean this stove and what above all to clean it from time to time as a preventive measure? So far, I only dusted it and blew it with compressed air
  • #4 16714328
    BUCKS
    Help: 536
    Rate: 1087
    he he the best I am certainly not. After reading your description, I tried to draw conclusions and as you can see my analysis turned out to be accurate in this case.
    I am an ordinary Kowalski, a user of a Vaillant combi boiler (an old model with an open combustion chamber), in which I learned practice, gaining my knowledge.
    You haven't even written what kind of stove you have, but I'm not a service technician, so I won't recommend anything specific, because I just don't know it.
    Yes, I learned from my boiler and took it apart, thanks to which I got to know its construction, principle of operation and, at the same time, I descaled the whole, which gave the boiler a new life, and I am richer with new experiences and knowledge.
    There are some analogies to my Vaillant but generally it's blindfolding and at your own risk.
    Based on my Vaillant, I can say that after years it is definitely worth descaling the entire water section, because deposits accumulate over time, which reduce heat transfer, which meant dismantling the boiler and cleaning all elements.
    However, this also involves some risk, which is why laymen are advised against "burying" themselves, because the boiler can be lost or hurt itself, especially since not everyone has technical, analytical sense and the ability to do manual activities.
    In general, it is worth servicing boilers, because e.g. cleaning the heat exchanger on the fire side ensures flue gas patency and minimizes the risk of soiling. That is why I am a supporter of cyclical reviews, so that the equipment flies, and not call the service until something goes down. And most of the problems are due to the lack of service and periodic inspections, cleaning, etc.
  • #5 16714370
    moxia
    Ok thanks, best regards
