Using Cyfrowy Polsat Decoder in Germany: Will it Work without Internet? (Abroad)
dawlis1427 26142 9
Can I use a Cyfrowy Polsat decoder in Germany without internet?
Yes, according to the thread the decoder itself should work abroad because the provider only communicates with the set-top box and not your physical location, so it cannot directly tell where you are watching from [#18064443] The licensing/legal remarks in the thread apply to Polsat GO, not to the decoder [#18063951] One reply says they may block access randomly, which would force you to contact support and prove you are abroad [#18064576] Another reply says there is no known case of anyone being tracked or punished for using it abroad, only that the provider has the customer account [#18065864]
  • #1 18063906
    dawlis1427
    Hello, I'm going to Germany soon and I would like to ask if it will work when taking Cyfrowy Polsat decoder with me abroad? I know that there is Internet TV, etc., but unfortunately I will not have the Internet from a router or cable, and I am curious if such something would work. Numerous answer
  • #3 18063938
    dawlis1427
    Are there any consequences of this? I read that it is simply not very legal, but the sender of no penalty, or who exactly receives the TV abroad, does not know and does not give
  • #4 18063951
    Tommy82
    Help: 455
    Rate: 1074
    This applies to Polsat GO.
  • #5 18063966
    dawlis1427
    Okay, I understand, but I'm asking for a decoder, because as I mentioned, internet TV is not an option, but thanks for the answer
  • #6 18064443
    LeDy
    Help: 1990
    Rate: 2938
    It does not matter . The sender only has contact with the set-top box and not with his location.
    If he blocks it and you call Info from abroad, he will guess.
  • #7 18064464
    dawlis1427
    And when it comes to blocking, they block everything that works abroad or is it more unlucky to get caught with something like this?
  • #8 18064576
    LeDy
    Help: 1990
    Rate: 2938
    They block randomly to make you speak up, make a call. Such fun.
  • #9 18064623
    dawlis1427
    What then? Calling when you are in Poland or not, is there any punishment or something like that?
  • #10 18065864
    LeDy
    Help: 1990
    Rate: 2938
    Irrelevant. I have not heard anyone "tracked", that they did something abroad. After all, they have a client.
The discussion revolves around the feasibility of using a Cyfrowy Polsat decoder in Germany without an internet connection. Users express concerns about the legality and potential consequences of using the decoder abroad, noting that while internet TV options are limited without a router, the decoder itself may still function. Responses indicate that the service provider may block access to the decoder if it detects usage outside the licensed area, but there are no confirmed reports of users being penalized for using the service abroad. The conversation highlights the ambiguity surrounding the legality of such actions and the random nature of service blocking.
