Lost Cyfrowy Polsat Signal: Troubleshooting Decoder, Antenna, Converter & Cable Settings
Melkor 110228 12
Why does my Cyfrowy Polsat HD5000 decoder show “no signal from the antenna” with 0% strength and quality even after replacing the converter and cable?
The decoder message means the dish is still not receiving a usable signal, most likely because the antenna is misaligned or there is a connector/cable fault, not because the decoder is bad [#10132967][#10133112][#10133298] Check the F-connectors again for a short circuit or break, because even a stray braid strand can cause a failure after screwing the plug in [#10132967] With the HD5000, the signal indicators should move away from 0% when the converter is connected, so if both strength and quality stay at zero while you move the dish, the antenna position is wrong [#10132967][#10133078] The dish is not adjusted “by eye” like the neighbor’s installation; it needs precise alignment, sometimes by millimeters [#10133112] If you do not have experience setting up satellite dishes, call a specialist, since they can align it quickly for a modest fee [#10132967][#10133587]
  • #1 10132851
    Melkor
    Rate: 21
    Hello, since yesterday I am a happy owner of CP: /
    After connecting the decoder and the antenna, the message no signal from the antenna is displayed check the settings and configurations of the decoder, I will add that the decoder is working, it works at the neighbor's, the converter is replaced, the antenna cable is also. I set the antenna according to the settings of the neighbor on the lower floor, I understand that it is difficult to manually determine a good signal, but that it is still zero? In the settings, both scales have 0% strength and quality, regardless of how I turn the antenna.
  • #2 10132879
    telesat1
    Help: 104
    Rate: 258
    Nothing on the forum about connecting to the converter?
    Regulations p. 3.1.16.
  • #3 10132909
    Melkor
    Rate: 21
    I read the forum topics, unfortunately it did not help me, as I mentioned the converter and the cable was replaced and checked
  • #4 10132967
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Which CP decoder? After connecting the converter, the force indication should change and be different from 0%.
    Check again the earning of the F terminals if there is no short circuit or break, sometimes the hair from the screen causes a short circuit only after screwing into the socket.
    Call a specialist if you do not have any experience in setting up satellite dishes, this type of antennas is not set "by eye", sometimes millimeters play a role. A professional will take reasonable money for just setting the antenna (if it has been properly installed), and you will save time and nerves.
  • #5 10132988
    Melkor
    Rate: 21
    The decoder is HD5000, in general, I first made the cable myself, i.e. I earned the terminals, etc. then I bought it ready with terminals and unfortunately the problem did not stop. Therefore, I have no idea why the strength is still 0% and therefore I do not know if it is the fault of the equipment or maybe the antenna settings
  • #6 10132991
  • #7 10133052
    Melkor
    Rate: 21
    mihal2002 wrote:
    Both scales are zero because you have a damaged (badly earned) cable.
    Brand new cable with ready-made tips
  • #8 10133078
    andpol 33
    Help: 513
    Rate: 1145
    The HD5000 does not show the signal level when connected to the converter, so you have a wrong antenna position.
  • #9 10133099
    Melkor
    Rate: 21
    There are two stripes in the antenna settings:
    1. Signal strength
    2. Signal quality
    Both are at the minimum level, and when the antenna is moved, they do not budge
  • #10 10133112
    andpol 33
    Help: 513
    Rate: 1145
    You miss the point. The satellite dish is not positioned by eye, as at the neighbour's. Every millimeter is important. There have already been thousands of posts about setting up antennas.
  • #11 10133259
    Melkor
    Rate: 21
    Ok, I agree that I may miss the point, but does that explain the message
    "No signal from antenna check decoder settings and configurations"?
  • #12 10133298
  • #13 10133587
    andpol 33
    Help: 513
    Rate: 1145
    Melkor wrote:
    Ok, I agree that I may miss the point, but does that explain the message?
    "No antenna signal check decoder settings and configurations"?
    You have replaced the converter, you have replaced the cable, the decoder has been checked on a different installation - it works. What other tips do you want? Set up the antenna or call a professional. You will pay from 40 to 70 PLN for the setting, depending on where you live.
✨ The discussion revolves around troubleshooting a lost signal issue with a Cyfrowy Polsat (CP) HD5000 decoder. The user reports receiving a "no signal from antenna" message despite having replaced the converter and antenna cable, and confirmed the decoder works on a different installation. Responses emphasize the importance of precise antenna positioning, as even minor adjustments can significantly affect signal strength and quality. Suggestions include checking for short circuits in the cable connections and considering professional installation services for optimal setup.
