Can DVB-T Decoder Receive Polish Channels in Germany: Reception Possibilities
85jogas 38730 14
Can I receive Polish channels in Germany with a DVB-T decoder and room antenna?
No: a DVB-T decoder with a room antenna will not receive Polish channels in Germany, except possibly very close to the border; for Polish channels you need satellite TV instead [#16916297][#16941891] The replies recommend using a DVB-S/DVB-S2 satellite set-top box rather than DVB-T [#16916567] For free Polish channels, no card is needed; on Hotbird there are about 20 FTA channels [#16918288][#16916567] If the rooftop dish is aimed only at Astra, you may get only Trwam, so the key is whether the building’s satellite setup also receives Hotbird [#16916567][#16941891]
  • #1 16897813
    85jogas
    Can a DVB-T decoder receive Polish channels in Germany?
  • #3 16897909
  • #4 16908446
    85jogas
    Hello, mihal 2002. Germany around Langenargen oberdorf or how to buy DVBS or DVBS-2 decoder in Poland and a good room antenna will I be able to receive Polish channels? greetings
    mihal2002 wrote:
    Germany is a big country.
  • #5 16908757
  • #6 16908890
    LeDy
    Help: 1992
    Rate: 2940
    First decide which channels do you want to receive if DVB-T or DVB-S2?
  • #7 16908924
    maksar
    Help: 177
    Rate: 1030
    LeDy wrote:
    First, decide which channels
    Neither these nor those of the room antenna will get.
  • #8 16916147
    85jogas
    . I mean for Polish channels that to receive I do not know which decoder to buy to receive from the room antenna because only the plate I have on the roof
    maksar
    Help: 177
    Rate: 1030
    85jogas wrote:
    . I mean Polish channels
    Forget it, from the room antenna! Only SAT!
    LeDy
    Help: 1992
    Rate: 2940
    85jogas wrote:
    I mean for Polish channels that to receive I do not know what decoder to buy to receive from the room antenna because only I have a plate on the roof
    It remains you only this plate and SAT set-top box . As you have on Astra it's only Trwam and on Hotbird it's about 20 FREE.
  • #11 16916605
    85jogas
    I know that Polsat digital and nc + is good, I do not want to take the decoder on the contract because I will have to pay until the end of the contract and I go to Germany twice a year for two months
    andpol 33
    Help: 513
    Rate: 1146
    Well, it's just smart hd.
  • #14 16941872
    KOCUREK1970
    Help: 3862
    Rate: 5490
    85jogas wrote:
    I only have a plate on the roof
    You understood what your friend was @LeDy suggests?:
  • DVB-T cannot receive Polish satellite channels
    #15 16941891
    tadgra
    Help: 15
    Rate: 55
    People! After all, the author of this thread wrote in the beginning about the reception in Germany of Polish channels on the dvb-t decoder. That is Polish digital terrestrial television. If it is close to the border it may be, but if it is never in my life. And you are writing about the reception of satellite television. Well, how can he pick up the channels from the SAT TV, taking from Poland, for example, a WiWa HD 90 decoder. Later, the story's author changed the concept and began to combine how to pick up free Polish satellite channels in Germany. And just like in Poland! But definitely not on the dvb-t decoder and certainly not on the room. Koniec.kropka
    When it comes to receiving satellite TV, in Germany it is usually forbidden to issue their own satellite dishes. On the roofs there are satellites and a satellite decoder for the socket in the apartment. But most often the antenna only receives Astra, but it happens very rarely that the antennas have a "squint" and the signals go from Astra to Hot Bird as well. And forget about displaying your own antennas, for example on balconies in most Länder. There are high penalties for breaking building codes. That's why I advise you to find out if this antenna in your building on the roof receives signals only from Astra (standard) or also from Hot Bird. And really, it's free to pick up anything from satellite in Germany, just like in Poland. Well, unless you are led by TV Trwam (Tadeusz Rydzyk Wam) and TV Polonia and a few music.
The discussion centers on the feasibility of receiving Polish channels in Germany using a DVB-T decoder. Participants clarify that DVB-T is not suitable for this purpose, especially with a room antenna. Instead, a satellite (SAT) setup is recommended, specifically using a satellite dish and a compatible SAT decoder. Channels like Trwam on Astra and various free channels on Hotbird are mentioned as accessible options. The conversation emphasizes the need for a proper satellite installation rather than relying on terrestrial reception methods.
TL;DR: For most of Germany, Polish DVB-T won’t reach; use satellite—“only this plate and SAT set-top box.” Hot Bird carries about 20 free Polish channels. [Elektroda, LeDy, post #16916567]
Why it matters: This FAQ helps viewers in Germany pick the right gear and method to watch Polish TV without wasted buys or false hopes.
Can a DVB‑T decoder receive Polish channels in Germany?
Usually no. DVB‑T from Poland reaches only close to the border. Elsewhere in Germany, signals won’t arrive, so a DVB‑T box won’t help. Satellite reception is the practical path for Polish channels across Germany. [Elektroda, tadgra, post #16941891]
Will a room/indoor antenna work for Polish channels in Germany?
No. Users report indoor antennas won’t capture Polish broadcasts in Germany. “Only SAT!” captures the reality. Plan for a satellite dish or a building feed instead of an indoor antenna. [Elektroda, maksar, post #16916297]
Which satellite should I use for free Polish channels?
Aim at Hot Bird. It carries about 20 free-to-air Polish channels. Astra typically has only TV Trwam in Polish. Use a standard DVB‑S2 receiver with your existing dish or shared system. [Elektroda, LeDy, post #16916567]
Do I need a subscription card or CAM for Polish FTA channels?
No. Free-to-air Polish channels on satellite don’t require a smart card, CAM, or contract decoder. Any DVB‑S2 receiver that supports FTA will work. [Elektroda, LeDy, post #16918288]
What’s the difference between DVB‑T and DVB‑S2 in this context?
DVB‑T is terrestrial TV from land transmitters; range limits stop it deep inside Germany. DVB‑S2 is satellite TV, receivable across Germany with the right dish/feed. Choose DVB‑S2 for Polish channels away from the border. [Elektroda, tadgra, post #16941891]
How do I check if my building’s dish gives Hot Bird as well as Astra?
Ask building management which satellites the roof system feeds. If only Astra, request Hot Bird or use a second LNB if allowed. Then scan free channels on your DVB‑S2 box. [Elektroda, tadgra, post #16941891]
I already own a DVB‑T box (e.g., WiWa HD 90). Can it get Polish channels via SAT?
No. A terrestrial decoder won’t receive satellite broadcasts. For satellite, use a DVB‑S2 receiver connected to the building’s satellite outlet or your dish. [Elektroda, tadgra, post #16941891]
What equipment do I need for free Polish satellite TV?
Use a DVB‑S2 receiver, a dish/LNB aligned to Hot Bird, and a TV. No card or subscription is needed for FTA channels. [Elektroda, LeDy, post #16918288]
Is installing my own balcony dish allowed in Germany?
Often not. Many buildings restrict individual dishes, and violations can incur penalties. Verify building codes and house rules before any installation. [Elektroda, tadgra, post #16941891]
How many free Polish channels can I expect?
About 20 on Hot Bird, according to user guidance. Lineups change, but FTA availability remains solid for news, culture, and religion. [Elektroda, LeDy, post #16916567]
What if my building feed is Astra‑only?
You’ll get TV Trwam in Polish but miss broader Polish lineups. Request Hot Bird access or consider alternative viewing arrangements within building rules. [Elektroda, LeDy, post #16916567]
Is there a pay‑lite option without long contracts?
Some suggest prepaid or light offers, but for strictly free channels, stick to FTA on Hot Bird with a DVB‑S2 receiver. [Elektroda, andpol 33, post #16916969]
Can I mix room antenna for local German TV and SAT for Polish?
Yes. Use your TV’s DVB‑T/T2 tuner or a small indoor antenna for German locals, and a separate DVB‑S2 receiver for Polish FTA. [Elektroda, tadgra, post #16941891]
Give me a quick setup checklist for Polish FTA via building satellite.
  1. Confirm the building feed includes Hot Bird, not just Astra.
  2. Connect a DVB‑S2 receiver to the satellite wall outlet.
  3. Scan for Polish FTA services and save favorites. [Elektroda, tadgra, post #16941891]
What’s a common failure case I should avoid?
Buying a DVB‑T decoder hoping to get Polish TV deep inside Germany. It won’t work without border‑adjacent signal. Choose DVB‑S2 instead. [Elektroda, tadgra, post #16941891]
Expert tip for quick success?
“Only this plate and SAT set‑top box” if you want Polish TV across Germany. Prioritize Hot Bird in your setup. [Elektroda, LeDy, post #16916567]
