- Sony, JBL, Fresh & Rebels Bluetooth Headphones Low Volume: Boost Skullcandy Indy on HTC U Play
Xenon02 40344 4
  • #1 18080208
    Xenon02
    Rate: 35
    I checked a pair of headphones from Sony, JBL and Fresh & Rebels in the store. And when I connected them via Bluetooth, they sounded much quieter than on the cable.
    I was thinking about buying the Skullcandy Indy, and I would like to know if there is a possibility of increasing the Bluetooth headphones.
    I'm using HTC U play, maybe this information will help you a little.
  • #2 18080239
    ILLUMINATOR
    I used JBL bluetooth headphones some time ago and I did not notice that they sounded softer than the cable amplification on the headphones. Check somewhere in the sound options on the phone if bluetooth is not muted or some equalizer is not turned on.
    Greetings.
  • #3 18080266
    Xenon02
    Rate: 35
    I have the sound option set to the maximum and I do not have any equalizers
  • #4 18080372
    ILLUMINATOR
    I do not know about HTC, but in my phone, when I connect a bluetooth device and turn on, for example, mp3 separately, I can turn up the bluetooth sound.
  • #5 18083322
    Xenon02
    Rate: 35
    I have contacted HTC, but they do not even know what is compatible and that quiet playing should not work in bluetooth headphones.
