JBL Tune 500BT headphones - the sound volume dropped significantly despite the maximum settings
Black_dave_29 23439 10
Why did my JBL Tune 500BT headphones suddenly become very quiet even though the phone and headphone volume are set to maximum?
Diagnose the speaker path and amplifier: inspect the membranes for visible damage, then unsolder a speaker and test it directly from the jack output; if it plays normally, the amplifier may be dead, and if it still plays badly, the speaker/driver is likely faulty [#19584504] Also check whether each channel plays separately, because if one channel is heard in both earcups there may be a missing ground; in that case the headphones can work in a mono-series mode and the added resistance will reduce volume [#19584718] A bad contact in the cable running through the headband between the two earcups is another possible place to look [#19405872] If the driver is defective, a replacement with the same impedance and power can be used, even from another brand [#19584504]
  • #1 19013183
    Black_dave_29
    Hello everyone, I have a problem with JBL 500BT wireless headphones, namely the headphones started playing quietly despite the volume set to the maximum on both the phone and the headphones.
    sosarek
    Help: 9320
    Rate: 15532
    Tested with another device?
    Z
    Pka, Poznań, 60-850
  • #3 19014892
    Black_dave_29
    yes checked
  • #4 19405546
    lolki517
    Hello, I also have this problem with headphones. Did you have any crackling problems before playing more quietly? Maybe the amplifier is damaged, I have to collect them and see what`s there, it`s a pity because they played very nicely
  • #5 19405862
    Black_dave_29
    My brother gave me these headphones in this condition and I was supposed to repair them, but I couldn`t find a solution to this problem anywhere on the Internet. If you find a way to fix it, let me know.
  • #6 19405872
    cuctu_P
    Rate: 10
    In my opinion, there may be a bad contact between the transmitting handset and the receiving handset. As far as I know, they have the cable between the headphones placed in the strap above the head. I would look for a problem here :D
  • #7 19405874
    Black_dave_29
    But if there is bad contact between the headphones, I think that the transmitting headphones should produce sound normally.
  • Check speaker diaphragms for bass damage
    #8 19406307
    cuctu_P
    Rate: 10
    Oh, I actually didn`t think about it. Look at the speaker diaphragms. Maybe they didn`t survive hard bass xD
  • #9 19584401
    Black_dave_29
    Well, what if there was something with the membranes, what should I do? I probably won't get separate parts for these headphones
  • Diagnose speaker damage before blaming the amplifier
    #10 19584504
    cuctu_P
    Rate: 10
    You need to carry out a diagnosis, i.e. check if there is any visible damage on the membrane, if there is no damage, unsolder the speaker and solder it to the jack output and turn on the music. If it plays correctly, it is possible that the amplifier is dead, but if the speaker does not work, you can try to use the receiver to build a DIY wireless speaker. It's hard to find speakers for JBL wireless headphones. You can also use a speaker from another company with the same impedance and power. Greetings.
  • #11 19584718
The discussion revolves around the JBL Tune 500BT wireless headphones, which are experiencing a significant drop in sound volume despite being set to maximum on both the headphones and the connected device. Users suggest troubleshooting steps, including testing the headphones with another device, checking for potential damage to the speaker diaphragms, and examining the internal connections for bad contacts. Some participants propose diagnosing the issue by checking each channel's output and considering the possibility of a faulty amplifier. Suggestions for repair include unsoldering the speaker to test it directly and using alternative speakers if necessary.
