[Solved] 55-inch Panasonic X-55FX613E at 1.8m-2.2m: Too close or habit adjustment needed?
Mrsikorski 20841 46
Can I comfortably watch a 55-inch 4K TV from 1.8–2.2 m, or should I exchange it for a smaller size?
A 55-inch TV at 1.8–2.2 m is not inherently too close, but if it causes eye strain or you cannot relax while watching, the size is simply not comfortable for you and a 49/50-inch model may be better [#18104898][#18107397] Several users said they got used to 55 inches after some time, especially after moving up gradually, so part of the issue can be habit [#18103399][#18103919][#18107407] The picture settings matter too: people recommended adjusting brightness, contrast, color saturation, sharpness, and trying movie mode to reduce strain [#18103457][#18103919][#18107407] Another important point is source quality: 1080p or SD material, especially with low bitrate, can look rough on a large 4K screen from close range and be tiring to watch [#18105639][#18133967] So the practical advice from the thread is to first calibrate the TV and test it for a few days, but if it still feels uncomfortable at your seating distance, exchanging it for 49/50 inches is reasonable [#18107397][#18104898]
  • #31 18111359
    Ludwik XVI
    Help: 1325
    Rate: 788
    LOCOLOCO wrote:
    If you buy too small a TV, the problem with your eyes is actually bigger!
    Stop with these theories. If that were the case, 20 years ago everyone would be walking blind...
  • #32 18111398
  • #33 18111533
    Ludwik XVI
    Help: 1325
    Rate: 788
    CRT for 25 years I watched 25 inches from almost 4m and somehow nothing happened to my eyesight....
    Nonsense and all.
  • #34 18111560
  • #35 18133967
    aree1987
    Unfortunately, watching cable even in HD on a large screen from close range can be irritating.
  • #36 18135890
  • #37 18140090
    dernel1
    Conditionally unlocked
    I am 2.5m from the 55' TV and I will tell you that at first I was surprised by the size. But over time I "learned" to watch. Usually my eyes fly in action movies because I choose some points from the image. Below 1.80 is a bit too close for me... I have similar feelings too. There are fewer things I can "get" from the scenes.
  • #38 18141381
  • #39 18697286
    hagermaniw
    Did the main character finally stop TV or did he get used to it, I just rented a new apartment where there is 2.1 m from the sofa to the wall or 2.5 m to the eyes because the balcony has a built-in cavity, the woman's eyes hurt, I also get drunk sometimes from watching , tv 55 "oled 4k, the head in the tv is sometimes huge.
  • #40 18697650
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    I too, after switching from watching TV on a 21" screen to a 55" screen, had concerns about the size, but over time I got used to it. The fact is that at the beginning it's hard to watch, but the TV has the ability to change the settings of the brightness and contrast parameters, and here you should look for a setting that does not hurt our eyes. With LCD screens with UHD resolution, you have to take into account that you should sit at such a distance that you can see all the details of the displayed image.
  • #41 18700021
    velocity
    I will add to the topic, because I am facing the choice of a TV set and I do not know if I am exaggerating with the size ;) I was practically determined to buy a 65-inch TV, but the more I read, the more I have doubts. The TV will be placed in a small room (16 m2), 3.8 meters away from the sofa. Will it be comfortable to watch from such a distance, or will I have similar feelings as the author of this topic? Generally, I watch cable in Full HD (source is UPC) and Netflix. So far, I've been using a 40-inch TV for 10 years, and from this distance it's a bit too small. Thanks in advance for your advice.
  • #42 18700127
    Janusz_kk
    Help: 228
    Rate: 1481
    At 3.8m it can be, I have 3m and 55" and it's ok.
  • #43 18707407
    Mrsikorski
    Hello everyone,
    I solved the problem by changing the settings. In my case, the movie mode works, and more precisely, I made my image by observing a lot of settings from the movie mode.
    As several people have already written here, it is a matter of settings, image, contrast, sharpness and habit.
    I have a laptop connected to the TV and the picture is great, the eyes do not hurt even at 360p quality.
    Regards
  • Industrial 4:1 viewing-distance rule for TV comfort
    #44 19056693
    buran
    I will add to the topic as a curiosity. In industrial engineering (manufacturing) the rule of thumb is that the distance to the normal field should be less than 4:1, which means that there is no eye movement, no fatigue and work in such an area is done faster - you don't have to shift your gaze from one point to another.
    In practice, if we work on a table at a distance of 40 cm, then if we do precise work in a field of 10 cm with our hands, we work with both hands without moving our eyes from one hand to the other. So from 4 m we see a field with a diameter of 1 m and all the details without eyeball movement.
    Of course, when watching 4:1 TV, it doesn't have to be preserved, because we don't have to be precise or register and react instantly to all the details on the edges of the screen. The more so that the action takes place rather in the middle of it. A good example is a football match - the ball is always in the center of the screen and the match is watched comfortably even from 1 meter on a large TV, because we are looking at the ball, which is not too fast. With hockey it's different, from a short distance you will simply lose the puck if you sit too close.
    It is natural that we shift our eyes while watching TV. It's important not to move your head.
    Of course, resolution and distance are completely different issues explained earlier.
    Just off topic after a few bellows.
  • #45 19058506
    andres13
    Slightly off topic, but I can't help commenting on it...
    After all, nowadays all tennis broadcasts happen mainly in the vertical plane - the main camera is placed behind the back of one of the tennis players.
    And on topic - it's important that the viewer feels comfortable!!!
    For me, 50 inches with 3-4m is not enough. The next TV will be much bigger.
    quote="remot"]
    Mrsikorski wrote:
    I will drive to the store and ask for an exchange for a smaller one, i.e. 49/50 inches.
    I don't know if you will succeed.
    By the way... when one of my friends asks "how many inches to buy" - I answer that while watching a tennis match - I don't shake my head.[/quote]
  • 55-inch TV at 2 m is not too large
    #46 19069698
    Mrsikorski
    quote="remot"]
    Mrsikorski wrote:
    I will go to the store and ask for an exchange for a smaller one, i.e. 49/50 inches.
    [/quote]
    Before you write something, I suggest you check the date of the post, or read it from the beginning, and not write after a year that you don't know if I will be able to replace it.
    I'm closing this thread as no one has anything new to add.
    I will repeat once again tv 55 from a distance of 2m is not too big, it is a matter of screen settings and habit.
  • Movie mode settings solved eye strain at 2 m
    #47 19069707
    Mrsikorski
    quote="remot"]
    [/quote]
    Added after 4 [minutes]:
    eyes do not hurt even at 360p resolution.
The discussion revolves around the user's experience with a 55-inch Panasonic X-55FX613E TV, positioned at a viewing distance of 1.8 to 2.2 meters. The user expresses discomfort, stating that the large screen causes eye strain and difficulty in focusing on the content. Responses from other users suggest that the issue may stem from a lack of habituation to the larger screen size, improper calibration of brightness and contrast settings, or the quality of the video signal being viewed. Many users recommend adjusting the TV settings for optimal viewing comfort and suggest that over time, the user may adapt to the larger screen. Some participants also mention the importance of viewing distance relative to screen size, with varying opinions on what constitutes an appropriate distance for a 55-inch display. Ultimately, the user considers exchanging the TV for a smaller model, such as 49 or 50 inches, to alleviate discomfort.
TL;DR: At 2 m, a 55-inch 4 K TV covers ≈55° of your field-of-view—20 % wider than THX’s comfort limit—and “you’ll get used to it in two weeks” [Elektroda, nomudrek, post #18103919]
Why it matters: Distance, signal quality, and picture settings decide whether big screens wow or weary your eyes.
• Optimal 55” 4 K distance: 1.0-2.3 m (THX, Viewing-Distance Chart). • Average TV size sold in EU 2020: 55” [Statista, 2021]. • Polish broadcast bitrate: 2-4 Mbit/s @1080i [Elektroda, Ludwik XVI, post #18105639] • Reported eye-adaptation time: 2-4 weeks [Elektroda, nomudrek, post #18103919] • In-store purchases lack automatic 14-day return; rely on retailer policy (UOKiK, 2023).
Is 2 m really too close for a 55-inch 4 K screen?
For 4 K, 2 m sits within THX’s 1.0-2.3 m range, so sharpness is fine. However, the 55° field-of-view beats THX’s 40-45° comfort band, causing eye-scanning for some viewers. Users who felt strain moved back to ≈2.5 m or downsized [Elektroda, Mrsikorski, post #18107309]
Why do my eyes hurt when I sit close?
Common triggers: high brightness/contrast, low-bitrate HD upscaled to 4 K, and continuous eye movement across the wide field. Several posters fixed discomfort by switching to Movie mode and lowering backlight [Elektroda, Anonymous, #18103457; Elektoroa, Mrsikorski, #18707407].
How long will it take to get used to a bigger TV?
Most users adjusted in 2–4 weeks after tweaking picture settings [Elektroda, nomudrek, post #18103919] If discomfort persists beyond a month, reconsider distance or screen size.
Will reducing brightness and contrast really help?
Calibrating with lower backlight, modest contrast, and warm color temperature reduces glare and eye strain. One user eliminated pain by copying Movie mode values [Elektroda, Mrsikorski, post #18707407]
What if my signal is only SD or 1080i?
At 2 m, SD channels (720×576) will look blocky on 55”. 1080i @2-4 Mbit/s shows compression noise [Elektroda, Ludwik XVI, post #18105639] Consider sitting ≥2.5 m or upgrading to HD/4 K sources.
Can I exchange a too-large TV bought in a physical store?
Polish law grants 14-day returns only for distance sales. Brick-and-mortar returns depend on store goodwill; the original poster managed to keep the set after adjusting settings [UOKiK, 2023; Elektoroa, Mrsikorski, #19069707].
What is the recommended distance for 49/50-inch TVs?
THX comfort band for 50” 4 K is roughly 1.2-2.0 m; SMPTE’s 30° guideline permits up to 3 m. Many forum users watch 50” from 2–3 m without issue [Elektroda, leonov, post #18103399]
How do I quickly calibrate a Panasonic FX613 for comfortable viewing?
  1. Select Menu > Picture > Mode > Movie.
  2. Lower Backlight to 35–45 and Contrast to 80.
  3. Set Color Temp to Warm and activate Adaptive Backlight. This three-step tweak solved eye strain for the thread starter [Elektroda, Mrsikorski, post #18707407]
Does sitting slightly off-center reduce strain?
Yes. The original poster felt better at a 2.5 m diagonal seat, which narrows effective field-of-view and lowers eye movement [Elektroda, Mrsikorski, post #18107309]
Are big screens harmful to eyesight?
There’s no evidence calibrated large TVs damage adult eyes. Discomfort stems from brightness or focusing effort, not screen size itself [American Academy of Ophthalmology, 2022].
Edge-case: When can a big TV still feel overwhelming?
Fast-moving sports like hockey make the puck hard to track if the screen spans over 60° FOV at <2 m, leading to lost details [Elektroda, buran, post #19056693]
What size suits a 3.8 m viewing distance?
A 65” delivers ~35° FOV at 3.8 m, matching SMPTE’s 30–40° sweet spot, so comfort should be high [SMPTE, Distance Guide; Elektoroa, velocity, #18700021].
Does 4 K upscaling fix low-res YouTube clips?
Upscaling fills the screen but can’t add lost detail. Users report acceptable 360p once contrast and sharpness are dialed down [Elektroda, Mrsikorski, post #18707407]
