Replacing Fuses Without a Fuse Puller - Safe Alternatives?
kowi91 26190 7
  • #1 18122805
    kowi91
    Probably a silly question, but I need to replace the fuse and I don't have a special gripper that is used for pulling and inserting. So the question is whether there is any way to replace this jig and whether it can possibly be done by hand? I guess without the ignition key there should be no intensity, but I'd rather make sure. I am completely green on the subject. Thank you kindly
  • #4 18123389
    kowi91
    Thanks, gentlemen! I was mainly just concerned with whether it was safe to pull out with my hands. I was able to do it, but it is indeed difficult without the grabber. I replaced the fuse from the directions. The manual says it must be a 15. With a 15 inserted it burns out immediately. With 20, the lights work, but they go a little crazy, i.e. faster and slower with different light intensity. The 20 burns out after two days. Should I then put fuse 25 in there? It's certainly strange because the manual says 15, but the car is an old 2003 Ford Focus tdci, so there's no point in going through the electrics.
  • #5 18123400
  • #6 18123410
    kowi91
    I wrote that I don't know, so why the silly comments? If so you will indeed need to go to an electrician and that's that.
  • #7 18123418
  • #8 18123422
    andrzej20001
    Help: 1578
    Rate: 6669
    Replacing Fuses Without a Fuse Puller - Safe Alternatives? I use such mini-fuses, the pliers have too small a grip sometimes. And it can be tight in some boxes and the pins hold the fuse tightly. The only thing I can say about putting in too big a fuse is that who can't afford to be rich...
The discussion revolves around the safe replacement of fuses without a specialized fuse puller. Users confirm that while fuse pullers exist, they are not essential for replacing fuses, and fingers can be used, albeit with difficulty. Concerns arise regarding the appropriate fuse rating for a 2003 Ford Focus TDCi, as the manual specifies a 15A fuse, but higher ratings (20A and 25A) were tested, leading to issues such as flickering lights and fuses burning out quickly. Participants emphasize the importance of using the correct fuse rating to prevent potential electrical faults or fire hazards, advising against using a higher amperage fuse than specified. Suggestions include using a threaded rod or screw as a makeshift tool for fuse removal.
