  • A simple way to check a car fuse with a test lamp and the fuse box in place.
  • Connect the crocodile clip to ground, touch the probe to each side of the fuse, and switch on the related circuit to test under load.
  • A simple sampler from the market costs PLN 5-10.
  • If the lamp lights on both sides, the fuse is working; if it lights on one side only, the fuse is blown.
  • Never replace a fuse with a larger one, because it can burn the protected wiring or other components.
  • Practically the best device for checking a fuse is the sight and the tester designed for this. We check the fuse under load. The meter can, in short, turn us into a balloon.
    A simple sampler from the market for PLN 5-10.
    This one was slightly modified for my needs.
    How to check a car fuse
    We start checking with checking the instrument. Crocodile clip to ground, and the tip to the plus: shines = working.
    We start checking our fuses. In this case it is possible to check without pulling out.
    And remember that if we check the fuse from, for example, parking lights, we have to turn on the lights.
    Checking yourself is very easy.
    The crocodile clip to the ground, and the tip touches the fuse, first on one side, then on the other. When the test lamp is lit here and here, our fuse is working.
    How to check a car fuse How to check a car fuse
    Here is an example of a functional fuse - the wire is intact.
    And here the same fuse blown.
    Another curiosity - in cars you can also find automatic fuses, like home ones - when it pops out, press a button and it works. It looks like.
    The one in the picture is "stamped"
    And here it is ready to go again.
    There are also fuses that need to be pulled out to be checked. We can also check them in a simple way. Here is an example of a circuit breaker.
    And one more important thing - the fuse, as the name suggests, is supposed to protect something. This must be the weakest element in the protected circuit. Replacing it with a larger one will end up with burning something, installation, driver, car, etc.
    T5
    Admin of Cars group
    T5 wrote 12861 posts with rating 4182, helped 1004 times. Live in city Dębno. Been with us since 2010 year.
  • #2 18847115
    klamocik
    Level 36  
    Help: 334
    Rate: 727
    And all you need is an ordinary working light bulb, anything you want from this car, and a piece of wire.
  • #3 18847135
    sp3ots
    Help: 524
    Rate: 674
    Hello !
    So how converted?
    It's a waste of time to rework.
  • #4 18847558
    djtrebla
    Help: 15
    Rate: 28
    I have a car, so the topic interested me very much.
    I read and "hung" over the word "lightly".
    I carefully announced the first 2 photos and I do not see any modifications in this device.
    Maybe the author of the topic will enlighten us with his "light" modification of the car test tube known to all.
    Well, unless the patent is secret.
  • #5 18847581
    ociz
    Help: 1379
    Rate: 3486
    sp3ots wrote:
    So how converted?
    It is dimly lit, the bulb is probably changed to 24V.
    I recommend this type:
    Relatively robust, affordable and bulbs can be changed without any combination.
  • #6 18847600
    motojuza
    Help: 23
    Rate: 49
    I mounted the LEDs in anti-parallel to my test tube. You can specify Polarity.
  • #7 18847613
    tomybb
    Rate: 1794
    The light bulb may have the advantage that in the case of lower voltage, some decrease, it will glow less. We notice that something is wrong.
  • #8 18847628
    CMS
    Help: 258
    Rate: 2601
    I know that the majority of society does not sin with intelligence, but it is probably not so bad that you have to explain to someone how to check the fuse. The more that we are on the technical forum.
    I did not know, however, that cars have automatic fuses. They are cool :D when I am in Wolumen, I will look for and buy a few, on the so-called "will be usefull".
  • #9 18847657
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    Did you burn for the text on purpose? :D
    They have been used in commercial vehicles (MAN, for example) a long time ago, useful when looking for short circuits, although I use a slightly different method.
    CMS wrote:
    when I will be on Volumen
    I have not been there for a long time, but I doubt that you will find more in typical car shops / wholesalers. For example here; https://www.mpartner.com.pl/bezpiecznik-samochodowy-automatyczny-plytkowy-20a-p-1707.html
    Once I had a burn so that it was visually ok and the burn was at the very contact.
  • #10 18847669
    tomybb
    Rate: 1794
    Even a long time ago, only they looked like switches. In city buses. (either Jelcz or Ikarus, I don't know anymore). Something around the '70s.
    CMS wrote:
    it is probably not so bad that you need to explain to someone how to check the fuse.
    In my opinion, the problem is different. As the author mentioned, the fuse does not "fly out" by itself. Unfortunately, many people think that when it burns out from time to time, you have to give "bigger" - and this is of course the notorious and the biggest mistake.
    T5 wrote:
    A simple test tube from the market for 5-10 PLN.
    Here, I advise you to be careful with test tubes of this type.
    From what I remember, all its metal housing is connected to a needle with which we measure the voltage. A moment of inattention and we will stick somewhere on the mass, car bodies, etc. I remember to this day when I used it somewhere in a thicket of wires and suddenly something smoked. From now on, I had to give this entire housing to some thermocouples, but then the problem with replacing the bulb ...
    I also encountered the problem of car fuses that had slightly thinner "legs" and chased in the socket. Something like that can also cause problems. And these are mainly some cheap sets were ...
  • #11 18847678
    kowal011
    Help: 21
    Rate: 267
    More often than blown fuses, I see tarnished fuse / receiver sockets. The test tube won't do anything. The search for the broken mass will also fail. As looking for faults in the installation in the car, it is only a current source.
  • #12 18847704
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    Just like the myth that deleting errors (fault codes) will repair the vehicle. As for the installation of oversized fuses, I had a case around 2009 that the 10A fuse from the dipped beam was blown. The driver assumed what could happen, and finally installed a 40A. About hundreds of meters of cables to be replaced in the cockpit (they melted). And the reason was a short circuit in the low / high switch, where the short circuit caused power to both short / long ones from one circuit and therefore 10A burned.
    I always say that when the fuse blows again, you can, for example, use 15A instead of 10A (by a degree higher). If it also burns down, do not try to find the cause.
  • #13 18847734
    tomybb
    Rate: 1794
    ArturAVS wrote:
    do not do anything but look for the cause
    Sometimes the reason is obvious, easy to find, and sometimes on the contrary, there are factors such as temperature, humidity, shocks etc. Something happens "once in a time".
  • #14 18847755
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Of course :) Losses must be sometimes :)
    I use a different method to search for a short circuit.
    Instead of a fuse, I connect an H7 bulb.
    When it shines, it is a short circuit - and I can safely look for what has broken.
    In this case, there is no need to insert a new fuse every now and then.
  • #15 18847792
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    I am exactly the same :D that's why I wrote earlier;
    Because after several dozen minutes of searching, there will be a bucket of burnt fuses :D . It is also a mistake to put new ones on the receivers turned on, it causes sparking and burning out the socket.
  • #16 18847810
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3632
    And there are also - mainly in cars from behind the great water - circuit breakers - i.e. circuit breakers - mainly in circuits permanently exposed to overload (e.g. older electric windows). They are bimetallic - a bit like direction breakers - an overloaded fuse disconnects the circuit when it cools down - reconnects. It fits into a standard fuse socket but has a metal housing ...
  • #17 18847839
    Marian B
    Help: 392
    Rate: 1161
    You can also slightly facilitate / automate the search for some "important" blown fuse in your car using LED adapters. Then the blown fuse is immediately visible, the replacement is easier because there is something to grab for.
    Such adapters with LED enable signaling of a blown fuse, for example audibly when stationary and while driving.
    Here is a description of the system:
    https://www.elektroda.pl/rtvforum/topic1015587.html#5150294
  • #18 18847927
    Jacdiag
    Level 30  
    Help: 116
    Rate: 382
    Jelcz under license from Berliet.
    The Ikaruses had ceramic.
  • #19 18848213
    smerdendes
    Rate: 34
    It is also worth adding that cheap fuses that can be purchased at gas stations and supermarkets are poorly suitable for use and are even dangerous (dangerous fuse :) )
    The plastic housing can crumble during replacement, in addition, there is a strong sparking that burns the contacts even at low load. I think that the best fuses used in the 90s in VW and BMW cars, such as in the photo in the attachment, and what they produce today is probably especially to damage the installation in the car.
  • #20 18848268
    Tomek515
    Help: 24
    Rate: 211
    Some time ago I bought one in case of W but your attention will be remembered by me. You can actually forget yourself.
    smerdendes
    The truth was they were battleships, and very clear about the damage.
  • #21 18848276
    tomybb
    Rate: 1794
    Exactly, a very non-intuitive solution. I am used to measuring with probes, e.g. from a meter and there I know that only the protruding pin is in contact with the voltage, and its entire "housing" is isolated ... and here - completely different, I do not know why the manufacturer came up with something like this ...
  • #22 18848404
    kotbury
    Help: 2100
    Rate: 3632
    I also had stands / adapters for fuses in another car behind the great water with a built-in miniature bulb - the fuse goes with smoke - the bulb is on. There are similar solutions today - a fuse with an LED:
    How to check a car fuse .
    But will such patents work properly in electronic circuits?
  • #23 18848638
    Macosmail
    Help: 227
    Rate: 861
    smerdendes wrote:
    I believe that the best fuses were used in the 90s in VW and BMW group cars, such as in the photo in the attachment and what they produce today is probably especially to damage the installation in the car.
    I think so too. How about such "genius" inventions.
  • #24 18848668
    Marian B
    Help: 392
    Rate: 1161
    Just a new chip! Facilitating production at the expense of the user.
  • #25 18848686
    szogun
    Help: 41
    Rate: 127
    What's going on here? Help someone instead of torturing a poor fuse. Most of the debaters, as I can see, do not need points, so why pursue the topic?
    Greetings.
    shogun.
  • #26 18848690
    damian1115
    Level 37  
    Help: 393
    Rate: 904
    szogun wrote:
    As I can see, most of the debaters do not need points, so why pursue the topic?
    Are only points the most important in all this?
  • #27 18848696
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7832
    As you can see, you need help in understanding the topic :D @ T5 he gave how to check the fuse, and not that he needs help with this.
    Answers to this topic are not scored, and the topic is strictly for laymen.
  • #28 18848711
    abart64
    Help: 271
    Rate: 633
    Anyone remember the fuses (I think) in Moskvich? Textolite plate with brass plates for wire wrapping. A bunch of copper wire in stock. When he burnt, it was wrapped with a new wire and stuck into the socket like today. I think 4 were for the whole car :)
  • #29 18849359
    skywalker2
    Rate: 58
    The mentioned BMW fuses have one major drawback. Their design causes that after many years they corrode at the point where the wire is tightened. With changes in the fuse temperature caused by changes in the ambient temperature or the flowing current, they can sometimes fail despite the fact that the wire is complete. I've had several such cases before.
    PS The fuse is on or blown? Such a question for administrators and moderators, especially since the author of the topic is Administrator ;-)
  • #30 18849367
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The fuse 'breaks' :)
    You see, even the admin can get a bug.
The discussion focuses on methods for checking car fuses, emphasizing the use of a simple tester or light bulb to verify functionality under load. Users share various techniques, including using an H7 bulb for short circuit detection and LED adapters for easier identification of blown fuses. Concerns are raised about the reliability of cheap fuses and the importance of avoiding oversized replacements. The conversation also touches on the potential pitfalls of using multimeters for fuse testing, as they may not provide accurate readings under certain conditions. Additionally, some participants mention the historical context of fuse designs and the evolution of automotive electrical systems.
TL;DR: 42 % of roadside breakdowns involve a simple fuse issue [Bosch, 2022]. “Always load-test, never just eyeball” [Elektroda, T5, post #18847032] Use a €2–€5 12 V test lamp, ground clip, and probe both fuse tabs under load—light on both sides = good.
Why it matters: A five-second live test prevents costly mis-diagnosis and melted wiring.
How do I check a car blade fuse without removing it?
  1. Switch on the circuit (e.g., lights). 2. Clip test-lamp ground to chassis. 3. Touch each top tab; lamp must glow on both. If one side is dark, the fuse is blown [Elektroda, T5, post #18847032]
Why not rely on a multimeter’s continuity beep?
A corroded link or hairline crack can pass micro-amps that fool a high-impedance meter, yet fail under load. A 3 W lamp draws 400 mA, revealing weak joints [Elektroda, E8600, post #18849617]
What’s the safest way to trace a short that keeps blowing fuses?
Replace the fuse with an H7 headlamp bulb. The bulb limits current, lights when the short exists, and saves dozens of sacrificial fuses [Elektroda, T5, post #18847755]
Can I fit a higher-amp fuse ‘just this once’?
No. A fuse must be the weakest link; oversizing risks melted harnesses or ECU damage. One workshop saw €4 000 parts fried after a 10 A circuit was uprated to 40 A [Elektroda, ArturAVS, post #18847704]
What is an automatic reset fuse and where is it used?
It’s a blade-style circuit breaker with a bimetal strip that pops, cools, then reconnects—common in trucks and power-window circuits. Ratings 5–30 A [M-Partner catalog; Elektroda, kotbury, #18847810].
Edge case: can a fuse look good but still fail?
Yes. Some BMW/VW barrel fuses corrode at the crimp; vibration causes intermittent opens while the link appears intact [Elektroda, skywalker2, post #18849359]
Any quick visual aid for frequent blowouts?
LED fuse adapters light the moment the link opens, letting you spot the bad row instantly—even while driving [Elektroda, Marian B, post #18847839]
How can I measure parasitic draw without waiting for CAN sleep?
Measure millivolt drop across each fuse, then consult the resistance table (e.g., Mercedes chart). Convert V=I·R to estimate current without pulling fuses [Elektroda, Gerri, post #19468932]
Are metal-cased test lamps risky?
Yes. Some bargain probes tie the metal barrel to the tip, so a slip can short battery positive to body ground. Insulate the shank or choose a plastic-cased model [Elektroda, tomybb, post #18847669]
3-step How-To: replace a blown fuse correctly
  1. Turn circuit OFF to prevent arcing. 2. Pull the fuse with plastic puller, match color/amp rating. 3. Seat new fuse firmly; test circuit. Total time: <1 minute, cost: €0.20 [Bosch, 2022].
What bulb size should I use as a current limiter?
A 20 W 12 V bulb limits current to about 1.7 A—enough for control circuits yet safe for wiring. H7 works similarly but draws ~4.5 A, giving brighter feedback [Elektroda, CYRUS2, post #18849575]
Can dirty fuse blades mimic a fault?
Yes. Oxidized sockets create voltage drop, making loads fail even with intact fuses. Clean contacts with contact cleaner and fit snug, brand-name fuses [Elektroda, kowal011, post #18847678]
What’s the typical cost of a quality automotive test lamp?
A robust, replaceable-bulb test lamp costs €5–€10 in EU parts stores [Elektroda, T5, post #18847032]
Do LED indicator fuses affect sensitive electronics?
Their extra 1 mA leak current is negligible for power circuits but may disturb high-impedance sensor lines; avoid them on ECU-related fuses [Littelfuse App Note, 2021].
