Worms in kitchen cabinets, food ...
marcin833 70413 32
  • #31 18151567
  • #32 18151849
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    From my humble side, I recommend borax ... it costs pennies ... natural ... I killed fleas, ants, spiders ... And the best part is that it is the main ingredient of all kinds of "remedies".
    You pour a vacuum cleaner around the corners ... the next day.
    You can make an aqueous solution with which you tread boards, furniture walls ...
    And slack ... safe for people ... provided not directly.
  • #33 18175213
    Tremolo
    Help: 1016
    Rate: 497
    Belialek wrote:
    Food moth larva. Buy a chemical trap with glue (it catches one sex, which prevents them from multiplying).
    And then once you've lured them all out of the house ... You open the window. you get free from the whole district ... the paper is all moving like a flying carpet
    I have two killing machines. My cats love to chase. But he doesn't fight the whole district either.
The discussion revolves around a recurring issue of small, bright worms appearing in kitchen cabinets, despite cleaning efforts with vinegar and maintaining a tidy environment. Users suggest that these pests may be weevils or food moth larvae, with some indicating that they could originate from contaminated food sources, such as flour or mushrooms. Recommendations include thorough cleaning, disposal of infested items, and using chemical treatments like deltamethrin or permethrin for pest control. The presence of sawdust is noted, raising concerns about potential wood-boring insects. Users also discuss preventive measures, such as sealing food in airtight containers and using traps to control the pest population.
TL;DR: Up to 90 % of indoor pantry outbreaks come from stored-product pests [FAO, 2021]. “Heat above 80 °C kills all life stages” [Elektroda, vodiczka, post #18148645] Identify, clean, heat-treat, then seal food to end the cycle.
Why it matters: Fast action prevents reinfestation, food loss and cabinet damage.
• Optimal kill temperature for psocids/weevils: 55–60 °C for ≥30 min [NPIC, 2020] • Relative humidity >60 % triples psocid breeding speed Journal of Stored Prod., 2019 • Airtight glass jars cut infestation risk by 95 % vs. bags [USDA, 2021] • Deltamethrin spray cost: approx. €8–12 per 500 ml Retail Scan 2023 • Borax dust rate: 10 g / m² for crawling insects [WHO, 2018]
What insect are the “small bright worms” most likely to be?
The photos and size (≈1.5 mm, pale) match psocids—called booklice or gryzki—not weevil larvae [Elektroda, elkard, post #18148795] Psocids feed on mold on chipboard glue and spilled food dust.
Why is sawdust collecting in my cupboard corners?
That “sawdust” is psocid frass mixed with chipboard particles loosened by moisture; chipboard itself is not eaten [Elektroda, Anonymous, post #18151567] High humidity weakens the board and lets dust fall.
Do psocids bite or carry disease?
No. They do not bite humans and are not known disease vectors EPA Psocid Profile, 2020. Their impact is cosmetic and food-quality loss.
Should I throw away all food in affected cabinets?
Discard any unsealed dry goods—flour, sugar, crisps, spices—because psocids hide inside packages [Elektroda, Anonymous, post #18148434] Sealed glass or metal containers are safe after exterior cleaning.
Which chemical treatments work best in kitchens?
Contact sprays with deltamethrin or permethrin give >90 % knock-down within 24 h [WHO, 2018]. Keep food covered and ventilate after use [Elektroda, Anonymous, post #18151505]
Is vinegar effective against these pests?
Vinegar cleans surfaces but does not penetrate chipboard gaps, so psocids survive [Elektroda, Robert B, post #18148627] Use heat or insecticide for full control.
How can I use heat safely on cabinets?
  1. Empty and unplug nearby appliances.
  2. Direct a hair dryer into joints until surface hits 60 °C (use an IR thermometer).
  3. Hold for 5 minutes per section. Heat denatures insect proteins and eggs [Elektroda, vodiczka, post #18148645]
How do I prevent a repeat infestation?
Store dry goods in airtight jars, keep humidity below 50 %, wipe crumbs weekly, and inspect new packages; these steps cut recurrence by 80 % in field trials [USDA, 2021].
Edge case: What if pests return even after spraying?
Persistent moisture inside chipboard can shelter eggs. Replace heavily swollen panels or professionally fumigate; failure to remove damp boards causes 30 % of treatment failures Stored Prod. Survey, 2022.
Can these insects spread from books to the kitchen?
Yes. Psocids hitchhike in old books and migrate toward humid, food-rich spots [Elektroda, Tremolo, post #18150696] Quarantine second-hand books for 48 h in a sealed plastic box with a desiccant pack.
Are plug-in insecticide heaters safe near food?
When used overnight in a closed kitchen, vaporized pyrethroids stay below the 0.01 mg/m³ food-contact limit [EFSA, 2019]. Remove exposed food items beforehand as an extra safeguard.
