The Whirlpool BSNF 8773 refrigerator collects water under the drawers of the ref
stratoss06 22797 7
  • #1 16353625
    stratoss06
    Rate: 10
    In the Whirlpool BSNF 8773 fridge, water collects under the vegetable drawers (about 1/10 cup). Well, no Frost did not work and the water condenses in the fridge - where to look for the reason - the fans work on the panel there is no message ... :(
  • #3 16354195
    stratoss06
    Rate: 10
    1 PAWEL wrote:
    Does the panel wall have knives a tub with a drain hole it is possible that the hole is blocked.
    https://www.youtube.com/watch?v=8dMOXYqzank
    This is a newer model and there is no hole that drains water - there are only ventilation holes through which water vapor is removed (by means of a fan) from the fridge. I will try to turn off the entire fridge for 24 hours, maybe something will dry and unlock ....
  • #4 16354344
    1 PAWEL
    Help: 674
    Rate: 1364
    And you could check on a piece of paper if the door seal adheres well.
  • #5 17254717
    wilinho
    Rate: 29
    I had the same problem, and the problem is the clogged drain, it is located behind the grille that steam off, on the penultimate shelf there are 2 screw caps at the bottom. They should be pried up, and there are screws for the cross and one in the middle. The middle one is hidden under the plastic with the inscription fresh contol, the plastics are latched so we pull them out. Then we pull the whole panel with the latch, but carefully because in the upper right corner is the windmill connector, disconnect, remove with clean and ready.
    Pozdrawaim
  • #6 17342289
    wan11
    Rate: 28
    I have the same problem, but unfortunately I am not technical.
    Would you send pictures (one screw, I located)
    Best regards .
  • #7 17343099
    wilinho
    Rate: 29
    At the bottom, as the drawer is pulled out on the right and on the left, there are end caps, such squares cut in plastic must be bent and there is a screw for a cross bit
  • #8 17366682
    wan11
    Rate: 28
    Finally, today I was able to fight the element. Thank you for the hint.
The Whirlpool BSNF 8773 refrigerator is experiencing water accumulation under the vegetable drawers, approximately 1/10 cup. Users suggest potential causes and solutions, including checking for a blocked drain hole, verifying the door seal's adherence, and inspecting the drainage system located behind the grille. One user detailed a method to access and clean the clogged drain, which involves removing screws and panels. Another user mentioned that this model lacks a traditional drain hole, relying instead on ventilation holes for moisture removal. Turning off the fridge for 24 hours was also recommended to allow any moisture to evaporate.
