Title: Electric Boiler for 2-Person Shower: Are 50L Models Enough? Tips, Recommendations & Brands
loli1987 55092 47
Is a 50 L electric boiler enough for two people to take daily quick showers, and is the Ariston Lydos Eco 50 L 1.8 kW an economical choice?
A 50 L boiler can work for two people if the showers are short and not taken back-to-back, but the thread’s safer recommendation is 80 L if you want more comfort, especially for sequential showers or a rain shower [#18161394][#18162703][#18168432] Electricity cost depends mostly on hot-water use, while standby losses are a smaller part; one reply estimated the 50 L vs 80 L difference at only about 0.36 kWh/day, or roughly 131 kWh/year, so tank size alone does not make a huge cost difference [#18161490][#18170779] To keep bills down, people suggested good insulation, a timer or programmer, and possibly using a night tariff such as G12as so the boiler heats mainly in cheaper hours [#18163268][#18172592] Shower aerators/reducers around 6-8 l/min were also recommended to lower consumption without ruining comfort [#18172592][#18170779] For hygiene, one poster advised periodic higher-temperature anti-legionella heating and, if raising tank temperature, using a mixing valve at the outlet [#18167854][#18169338] So the Ariston 50 L / 1.8 kW can be economical with moderate use, but 80 L gives more headroom if the wall and budget allow [#18168432][#18170779]
  • #31 18169451
    Kenworth 18
    Help: 2445
    Rate: 3752
    I do not approach this issue in terms of calculations, but these 40 liters are enough for me and for someone else it may not be enough and this is a very correct remark with which I fully agree.
    I know one thing, however, that making the boiler in terms of thermal insulation is the basis because having the previous boiler with a capacity of 60 liters, I could not wait for it to leak and need to be replaced. The previous boiler was turned on every 10-15 minutes, even when there was no water consumption and the electricity bills dropped significantly after replacing it with a new one.
  • #32 18169502
    BUCKS
    Help: 536
    Rate: 1087
    If you are satisfied with what you have, you do not have to count anything, except for learning purposes.
    But when planning the purchase of a boiler, such calculations allow to estimate whether a given tray will be OK for our current needs.
    The results may indicate whether and to what extent you will need to change your current showering habits, etc.
    Before that, it is worth doing a test and see how many liters of water are used on average for one shower and how many liters of hot water per minute can be flown through our faucet used during a shower.
    In such cases, it may be a matter of a damaged thermostat, because it controls the heater's activation cycles and sometimes replacing the thermostat with a new one can completely change the boiler's operating characteristics.
  • #33 18169518
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    For me, 30 liters is enough for one person. After less than half an hour, the boiler heats up again (depending on how much water was used by the previous person). I mix water with cold water anyway, because it is a bit too hot from the boiler. If I had set the temperature just for washing, maybe at the end of washing it would be too much mixed up with the cold. My water is also not very hot, so that someone gets scalded by mistake. In any case, I try not to waste water and it is not about the price of it. :wink:
  • #34 18169669
    loli1987
    Rate: 33
    I am going to buy such a boiler, it has protection against the formation of bacteria (it raises the temperature itself once a month) And as for losses, etc., I am attaching a photo ... 30 minutes before each shower.
  • #35 18170779
    BUCKS
    Help: 536
    Rate: 1087
    loli1987 wrote:
    I am going to buy this boiler.
    So 50 l has about 41.3W of standing losses, and the 80 l model has 56.3W for water with a temperature of 65 degrees.
    In other words, if there is no domestic hot water consumption, in theory 50 liters of water will cool down by about 17 degrees per day, and 80 liters of water will cool down by about 14.5 degrees.
    According to the technical data, the daily difference is 0.36kWh, which per year gives 131.4kWh of additional energy as part of the standstill losses for the 80-l model. The difference is, for me, not a significant difference to disqualify the 80-l model.
    loli1987 wrote:
    It is protected against the formation of bacteria (it raises the temperature itself once a month)
    bacteria multiplication is a matter of a few days, therefore it is customary to steam the trays once a week, not once a month.
    Of course, it all depends on the temperature you will keep in the tank, because the problem of legionella increases the lower the water temperature in the boiler.
    loli1987 wrote:
    And I think I would switch to g12as and it would heat up just before the end of the cheaper rate and then 30 minutes before each shower.
    a good thought, but in practice you would have to test how long it takes to heat up the water in the boiler, then you would have a reference point at what time to turn on the heaters so that the heating process ends just before 6. At the beginning, make yourself tests to see if you have enough hot water without reheating 30 min. before each shower, because you may not have to reheat the water during the day, if you choose the 80 l model.
    If you have too high water flows in your tap, you can use aerators with a flow of approx. 8 l / min. Less flow means less water used, and the flow of 8l / min is still a comfortable flow for the shower. For the tap, you have a typical aerator, and for the shower, there are special reducers mounted at the joint of the shower hose and tap.
  • #36 18171041
    loli1987
    Rate: 33
    And so I think I will. I have just watched those pertrators that have a flow of 6l / min. Always 2 liters of savings (although they say savings of 10l on the website) because an ordinary handset lets through 16l .. I am waiting for an e-mail from ENERGA regarding changes in the tariff and price list.
  • #37 18171130
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    Well, the important issue of flow has been raised. I just did the test because I was always irritated by the time of pouring e.g. a bucket of water into the mop and it turned out that it was quite right. It took 1m 5s to fill a 5 liter tank with a GROHE hand shower. Maybe this is where the saving comes from. As for the maximum temperature, this setting in the boiler is 85 ° C.
  • #38 18171213
    BUCKS
    Help: 536
    Rate: 1087
    @ loli1987
    As for aerators, you have to buy and check whether the resulting stream of water will satisfy you. Otherwise it cannot be verified.
    I bought Neoperl aerators for my gas boiler, they were not the cheapest, but I did not regret the PLN 20 and I am satisfied.
    @teskot
    Water flows are essential.
    If you have a real capacity of approx. 5 l / min, then after mixing hot and cold water, you have a correspondingly lower consumption of water from the boiler, and this certainly has an impact on domestic hot water consumption and costs.
    I check the flows on the water meter by recording a video on the phone, thanks to which I can measure consumption within 60 seconds with an accuracy of 0.05 liters, so you can notice small fluctuations and differences that are not visible when filling the vessel.
  • #39 18171765
    loli1987
    Rate: 33
    Will such an aerator, which is mounted on the hose to the handset right next to the tap, reduce the water pressure in the handset?
  • #40 18172592
    BUCKS
    Help: 536
    Rate: 1087
    I have an aerator as an extension of the hose with a capacity of 8l / min and I do not complain. Yes, you can see the difference in the water stream with the naked eye, but it is still at an acceptable level. I heat the water through flow and on the tap water system I have a maximum of 2 bar, i.e. I can unscrew the cold water supply to the boiler to the central heating system and on the boiler I will not get more than 2 bar, so I will not even shoot the safety valve.
    With a boiler you have such a home water tower, so I wouldn't worry about serious drops.
    As for me, 8l / min aerator can be taken blind and you should be satisfied, as for the weaker performance aerators, you have to buy and check if the results will be satisfactory for you.
    In the kitchen I have an aerator with a capacity of 6l / min and it is OK, although the actual flows are a bit smaller than the catalog ones.
  • #41 18172734
    loli1987
    Rate: 33
    In that case, I found out what I wanted. Next week I am starting a renovation, so in about a month I will write what and how it came out. And in the further operation of the boiler, I will write how much water is used and what the bill came out for future inquiries. Thanks ....
  • #42 18185696
    loli1987
    Rate: 33
    I know that I should write a new topic in another section, but the matter applies to the boiler referred to in the topic.
    Renovation is in progress and I faced a dilemma whether to take 50l because it is lighter and the wall is in a dilapidated condition in the place where it will hang. In the attachment I am sending a photo of where the boiler is to be installed. url = https: //obrazki.elektroda.pl/5294439400_1569407004.jpg] Title: Electric Boiler for 2-Person Shower: Are 50L Models Enough? Tips, Recommendations & Brands [/url] Title: Electric Boiler for 2-Person Shower: Are 50L Models Enough? Tips, Recommendations & Brands
    I will scratch off the joints a little and I do not know whether to seal it with mortar or glue for gypsum boards. The fastening will be for chemical anchors with a 15 cm long threaded rod. Will it be able to withstand it?
  • #43 18185827
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    This is a very bad condition of the wall and it is almost certain that it will not support the weight of the boiler (even a 50 liter boiler). If something so heavy is to be hung, the wall would have to be renovated. These anchors will not be able to sit well in this.
  • #44 18185835
    rafbid
    Help: 153
    Rate: 418
    How much space do you have to the ceiling? What's on the other side of the wall?
  • #45 18185925
    loli1987
    Rate: 33
    As you can see the groove above the bricks, the ceiling will be there (it is lowered because it is now 3.75m). On the other side there is a staircase. So far, the fixing is in the middle of these bricks.
    Added after 7 [minutes]:
    This is what it looks like. Title: Electric Boiler for 2-Person Shower: Are 50L Models Enough? Tips, Recommendations & Brands
  • Brick up the niche to stiffen the wall
    #46 18186306
    BUCKS
    Help: 536
    Rate: 1087
    it looks to me as if there was a window once and then a niche was made in which now you can see a shelf with household chemicals.
    As for me, this pseudo-cabinet is a setback and the recess should be filled with bricks to stiffen the structure.
    Fixing in the middle of the bricks is too close to the edge for me, and I would not like to collect the boiler from the floor, because it might kill someone on the occasion.
    I am an amateur and this is my private opinion based on my intuition after analyzing the visible photos.
  • Proposed threaded-rod reinforcement for boiler mounting
    #47 18186343
    loli1987
    Rate: 33
    Title: Electric Boiler for 2-Person Shower: Are 50L Models Enough? Tips, Recommendations & Brands This is the recess after the door to the staircase. On the side of the staircase, 12 cm bricked in brick. In this recess, 12 cm wooden beam reinforcements will be inserted, attached to the wall with angles so that the boiler has something to rest on. Then plasterboard.
    I am thinking of giving such a reinforcement made of thick sheet metal and chemically anchoring 6 threaded rods (black points). The red points are the place where the boiler is attached. In this recess, the beams I wrote about above.
  • #48 18188303
    loli1987
    Rate: 33
    However, it will be 50 liters. One shower less a day (one household member moves out), so 80 liters will be too much.
The discussion revolves around the suitability of a 50-liter electric boiler for two people taking daily showers in an apartment without gas heating options. Participants share their experiences, indicating that a 50-liter boiler can suffice if showers are staggered, but some suggest that an 80-liter model may be more appropriate for consistent hot water availability. Key considerations include energy consumption, tariff options (G11 and G12as), and the importance of thermal insulation to minimize heat loss. Recommendations for timers to optimize heating schedules and the necessity of maintaining higher water temperatures to prevent bacterial growth are also discussed. The ARISTON LYDOS ECO 50L is mentioned as a potential model, with users emphasizing the need to assess individual hot water usage patterns.
TL;DR: A 50 L boiler provides ~57 L of 38 °C water—about 7 min at 8 L/min [Bucks, #18169427]. “Comfort costs money” [Wojewoda82, #18161490], so compare standby loss, PLN-0.21/kWh night tariff and wall strength. 50 L works if showers are staggered; choose 80 L for back-to-back use. Add a timer for 22-06 heating to save ~PLN 300 / year. Reinforce crumbly brick before hanging the tank.
Why it matters: The right size and tariff keep bills low and water hot when you need it.
• Usable hot water: 57 L at 38 °C from a 50 L tank [Bucks, #18169427] • Re-heat time: 50 L + 1.5 kW element ≈ 1.36 h [loli1987, #18166498] • Standby loss: 50 L 41 W vs 80 L 56 W (Δ 0.36 kWh/day) [Bucks, #18170779] • G12as night rate: ~PLN 0.21 / kWh; day rate same as G11 [Bucks, #18166717] • Legionella control: keep ≥60 °C or weekly boost cycle [WHO, 2007]
Is a 50 L electric boiler enough for two quick showers?
Yes, if showers are at least two hours apart. One 5-7 min shower uses about half the stored heat, leaving enough for a second later [Bucks, #18169427; loli1987, #18161413]. Consecutive back-to-back showers may run lukewarm.
How much usable hot water does a 50 L tank deliver?
Mixing 65 °C tank water with 10 °C mains yields ~57 L at 38 °C—enough for 7 min at 8 L/min flow [Bucks, #18169427].
Should I pick a 50 L or 80 L boiler for two people?
Choose 50 L if showers are staggered and space or wall strength is limited. Pick 80 L when two people often shower consecutively; standby loss rises just 0.36 kWh/day or ~PLN 70/year [Bucks, #18170779].
How long does a 50 L boiler need to re-heat?
With a 1.5 kW element it reaches set temperature in about 1 h 20 min after full draw-off [loli1987, #18166498]. A 2 kW heater cuts this to roughly one hour.
What are standby heat losses?
Heat slowly escapes through insulation even when no water is drawn. A 50 L tank loses ~41 W; an 80 L about 56 W [Bucks, #18170779]. That equals 0.98 kWh and 1.35 kWh per day respectively—roughly PLN 16 vs PLN 22 per month at G11 rates.
How much will a 50 L boiler add to my electricity bill?
Users report PLN 70–100/month for two daily showers on G11 [Wojewoda82, #18161490]. Night-only heating on G12as can cut annual hot-water cost by ~PLN 300 [Bucks, #18166717].
Does switching to the G12as tariff really save money?
G12as keeps daytime price equal to G11 and charges ~PLN 0.21/kWh between 22-06 [Bucks, #18166717]. If the boiler heats only at night, 2000 kWh of hot-water energy drops from ~PLN 1040 to ~PLN 470, minus ~PLN 50 higher fixed fees [Bucks, #18166717].
Which compact electric boilers are well-reviewed?
Forum users favour Ariston Lydos Eco 50 L and 80 L (1.8 kW) for reliable thermostats and monthly anti-Legionella cycle [arturdip, #18161394; loli1987, #18169669]. Other cited LPG-ready options: Ariston SGA 50 [Wojewoda82, #18161490].
How do I program the boiler for lower costs?
  1. Install a 16 A electronic timer (≈ PLN 40) [Wojewoda82, #18161514].
  2. Set ON 04:00–06:00 and 22:30–23:30 (G12as window).
  3. Optionally add a 30-min boost before evening shower. This keeps 90 % of kWh in cheap hours [teskot, #18162703].
What temperature stops Legionella?
Bacteria growth slows above 55 °C and dies at 60 °C within minutes. Set the thermostat ≥60 °C or use weekly 70 °C boost [WHO, 2007; teskot, #18167854].
Are flow-through heaters cheaper or more convenient?
Gas or electric flow heaters save 30 % energy but need higher water flow to trigger and often fluctuate in temperature—“totally inconvenient when washing dishes” [Łukasz.K, #18162864]. Boilers give stable temperature at the cost of standby losses.
My brick wall is crumbling—will it hold a 50 L tank?
Not safely. Recessed bricks and mortar voids can fail under 100 kg load [Zbigniew Rusek, #18185827]. Rebuild the niche or anchor six M12 rods into solid masonry and add a steel spreader plate [loli1987, #18186343].
How can I cut shower water use without losing comfort?
Fit 6–8 L/min aerators at the hose outlet. Users saw flows drop from 16 L/min to 6 L/min while maintaining pressure [loli1987, #18171041].
What happens if two people shower back-to-back with a 50 L boiler?
After the first 7-minute shower, tank temperature falls about 20 °C. The second person gets lukewarm water unless they mix heavily with cold or wait 40–60 min for reheating [Bucks, #18169427].
What problems arise if I oversize the tank?
Larger tanks mean more heat loss. An unused 150 L unit wastes ~2 kWh/day, adding PLN 30/month at G11. In rare cases, long idle periods can breed Legionella despite weekly cycles.
How do I install a time-switch?
  1. Switch off power at the breaker.
  2. Wire the timer between boiler plug and socket (follow schematic).
  3. Program ON periods, then restore power. Whole job takes 15 min with a screwdriver [Wojewoda82, #18161514].
